15th May 2011, 16:14 | #13564 | Link |
Could somebody take a look @ this and maybe try to reproduce ? http://forum.doom9.org/showpost.php?...&postcount=559
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 |
15th May 2011, 20:38 | #13565 | Link | |
Can you please integrate this fix? Just tryed 3853 and it is still crashing :/ DXVA working now again, thanks for fixing it!
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin |
16th May 2011, 14:26 | #13566 | Link |
i find ass 4.0++ is not support in ffshow
get info here http://code.google.com/p/vsfiltermod/ http://docs.aegisub.org/manual/Attac...itles_to_video http://asa.diac24.net/ http://dl.dropbox.com/u/3668343/Scre...16%2021.18.jpg http://dl.dropbox.com/u/3668343/Rain...e%20_GomTV.ass h264 i use 3842 is work ,other is black or hang.. Last edited by god_md5; 16th May 2011 at 14:54. |
16th May 2011, 21:36 | #13568 | Link |
Broadband Junkie
If a new thread is started, there should be some sort of landmark dividing the two. Revision ranges? New beta released? Significant new features landing? Splitting for length alone isn't a great reason, unless the forum software on Doom9 has issues with massive threads.
If you want an excuse to start a new thread, wait for all the FFDshow-specific coding to complete (hopefully very soon if not already) which will bring full-support of High10 H264 decoding to FFDshow. There appears to be an push by Dark Shikari and others for people to code what is necessary for FFDshow ASAP. That would be as good a landmark as any to start a new thread. Last edited by cyberbeing; 17th May 2011 at 10:18. |
17th May 2011, 16:35 | #13570 | Link |
Those changes have already been integrated.
MPC-HC 2.1.7.2 |
17th May 2011, 17:13 | #13571 | Link |
Strange, it still crashing for me :/
MPC-HC decoder working fine. Only difference is, that it will now popup some kind of VC++ error message.
18th May 2011, 07:11 | #13573 | Link |
I made a commit to ffmpeg-mt which should fix the problem with 'Avatar-Bluray-ffmpeg-mt-corruption.m2ts'. However, since the problem doesn't reproduce with ffplay, I haven't actually tested this. Also, I suspect it's made the decoder noticeably slower per thread :/
10-bit is also merged in, but one of the tests fails with threading on, and I haven't spotted the problem yet. |
18th May 2011, 14:18 | #13574 | Link |
recent tests i did showed the libavcodec mpeg-2 part is much faster in a multithreaded framework then the libmpeg2 decoder in the current ffdshow (4 cores), ffdshow_rev3853_20110512_xhmikosr_icl12.exe <- tested, does this include the newest ffmpeg-mt ?
Dscaler IVTC mod was surprisingly being such old the fastest (+ 3 fps) , though Dscaler differs output wise from libavcodec/libmpeg2 in ffdshow on interlaced material with it's field selection it seems (it's not identical to ffdshow)
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 18th May 2011 at 14:24. |
18th May 2011, 14:45 | #13575 | Link |
@hoborg
Wasn't that a broken file? Can you upload it for me? Then I can try to fix the crash. @TheRyuu I will have a look at it this weekend. @Mr VacBob Great! I will update asap. @CruNcher The libavcodec mpeg2 decoder uses slice based threading. It has done that for ages already. It doesn't use frame based threading like ffmpeg-mt does.
MPC-HC 2.1.7.2 |
18th May 2011, 20:11 | #13576 | Link | |
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 18th May 2011 at 20:24. |
18th May 2011, 20:25 | #13577 | Link | |
19th May 2011, 17:07 | #13579 | Link |
I have a specific issue in PowerPoint 2010 which seems to be caused by ffdshow. Starting with builds > 3763 PowerPoint freezes when trying to play dv files (at least dvsd) in the 2010 native mode (the mode in which the PowerPoint displays a timeline for the videos).
I tried several other decoders (Medialooks, Microsoft - among others) and they do not exhibit this behaviour. Also, I tried it on different computers with Win7 64 bits (e. g. Intel H55 - Intel Graphics, Intel P35 - AMD ATI Graphics, etc.). Maybe someone here using PowerPoint 2010 (or the free player) can help me with this. I already posted this issue in the bug tracking system and I would be very grateful for a solution. The following 2 files demonstrate the problem: http://www.mediafire.com/?3q2wxwne4bxnxb5 (DVSD_Example.avi) http://www.mediafire.com/?gcarlp7h4k66vbh (DVSD_Example.pptx with linked video) Beside the PowerPoint 2010 issue, I came across the following two files which could not be decoded at all by ffdShow (using LAVSplitter): http://www.mediafire.com/?8fwcaxepy3xca4v (Apple_DVCP_small.mov) http://www.mediafire.com/?ch5rgnqbam6gi1v (WMV3_WMV9.wmv) Could this just be a matter of a missing media type or are these formats simply not implemented? If they are not available at all, does someone know which ds decoders support these? (while not being dmo decoders/source filters/splitters at the same time as I would very much prefer to keep using LAVSplitter as my default splitter for wmv/mov files) Last edited by Sven75; 19th May 2011 at 17:11. |
19th May 2011, 20:40 | #13580 | Link |
I noticed this error popup with a lot of *.TS HD/FullHD recordings too, even if i disable FFDShow DXVA decoder and use FFMPEG-MT.
