Old 25th October 2020, 12:50   #18721  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Originally Posted by Pauly Dunne View Post
Atak, something's wrong
2020-10-25 22:15:47 : Update for [mkvtoolnix] detected
2020-10-25 22:15:47 : Downloading file http://atak-snajpera.5v.pl/ripbot264...mkvtoolnix.zip to D:\RipBot264v1.26.0\updates\mkvtoolnix.zip
2020-10-25 22:15:50 : [ERROR] File http://atak-snajpera.5v.pl/ripbot264...mkvtoolnix.zip could not be downloaded!
However, if you click on the link, it will download successfully, and when placed in the Update folder, it DOES install without error.
No problem here
2020-10-24 16:19:00 : =========================[UPDATER ACTIVATED]=========================
2020-10-24 16:19:00 : Looking for correct UUID link in http://forum.doom9.org/showthread.php?t=127611
2020-10-24 16:19:00 : [SUCCESS] http://forum.doom9.org/showthread.php?t=127611 has correct UUID link 6c966b28-e0dd-48f6-b1c7-a56e8a275ec0
2020-10-24 16:19:00 : Downloading update file http://atak-snajpera.5v.pl/ripbot264update/update.zip
2020-10-24 16:19:00 : [SUCCESS] C:\Users\Dave\Documents\Delphi_Projects\RipBot264\_Compiled\Updates\update.zip saved!
2020-10-24 16:19:00 : Update for [core] detected
2020-10-24 16:19:00 : Downloading file http://atak-snajpera.5v.pl/ripbot264update/core.zip to C:\Users\Dave\Documents\Delphi_Projects\RipBot264\_Compiled\updates\core.zip
2020-10-24 16:19:02 : [SUCCESS] File C:\Users\Dave\Documents\Delphi_Projects\RipBot264\_Compiled\updates\core.zip saved!
2020-10-24 16:19:02 : CRC32 value has not changed for [aften]. Update is not required.
2020-10-24 16:19:02 : CRC32 value has not changed for [avs2pipemod]. Update is not required.
2020-10-24 16:19:02 : CRC32 value has not changed for [avs2yuv]. Update is not required.
2020-10-24 16:19:02 : CRC32 value has not changed for [avsmeter]. Update is not required.
2020-10-24 16:19:02 : CRC32 value has not changed for [bdsup2sub]. Update is not required.
2020-10-24 16:19:02 : CRC32 value has not changed for [chapterxtractor]. Update is not required.
2020-10-24 16:19:02 : CRC32 value has not changed for [dgindex]. Update is not required.
2020-10-24 16:19:02 : CRC32 value has not changed for [downloadposter]. Update is not required.
2020-10-24 16:19:02 : CRC32 value has not changed for [eac3to]. Update is not required.
2020-10-24 16:19:02 : CRC32 value has not changed for [ffmpeg]. Update is not required.
2020-10-24 16:19:02 : CRC32 value has not changed for [fhgaacenc]. Update is not required.
2020-10-24 16:19:02 : CRC32 value has not changed for [mediainfo]. Update is not required.
2020-10-24 16:19:02 : Update for [mkvtoolnix] detected
2020-10-24 16:19:02 : Downloading file http://atak-snajpera.5v.pl/ripbot264update/mkvtoolnix.zip to C:\Users\Dave\Documents\Delphi_Projects\RipBot264\_Compiled\updates\mkvtoolnix.zip
2020-10-24 16:19:23 : [SUCCESS] File C:\Users\Dave\Documents\Delphi_Projects\RipBot264\_Compiled\updates\mkvtoolnix.zip saved!
2020-10-24 16:19:23 : CRC32 value has not changed for [modifychapters]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [mp4box]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [mpc]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [opus-tools]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [pgcdemux]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [remuxtool]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [setacl]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [ssatosrt]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [tsmuxer]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [vjoin]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [vsrip]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [wolcmd]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [x264]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [x265]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [autocrop]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [ffms]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [flash3kyuu_deband]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [hqdn3d]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [scripts]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [tivtc]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [vsfilter]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [yadif]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [knlmeanscl]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [openclinfo]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [masktools]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [mvtools]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [nnedi3]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [detectborders]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [avisynth]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [rawsourceplus]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [rgtools]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [nicaudio]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [plugins_jpsdr]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [waitforprocess]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [avsresize]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [dgtonemap]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [lsmash]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [7z]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [srttossa]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [hdrtools]. Update is not required.
2020-10-24 16:19:23 : CRC32 value has not changed for [matroskasplitter]. Update is not required.
2020-10-24 16:19:23 : Downloading finished.
2020-10-24 16:19:52 : =========================[UPDATER ACTIVATED]=========================
2020-10-24 16:19:52 : Installing updates...
2020-10-24 16:19:53 : [SUCCES] C:\Users\Dave\Documents\Delphi_Projects\RipBot264\_Compiled\updates\core.zip has been correctly extracted!
2020-10-24 16:19:57 : [SUCCES] C:\Users\Dave\Documents\Delphi_Projects\RipBot264\_Compiled\updates\mkvtoolnix.zip has been correctly extracted!
2020-10-24 16:19:57 : Installation complete.
I suspect that your antivirus is blocking downloading files by updater.exe
Old 25th October 2020, 13:14   #18722  |  Link
Pauly Dunne
Grumpy Old Man.
Pauly Dunne's Avatar
No problem here
Only running the OEM/default AV that is part of W10.
Not poorly done, just doin' it my way !!!
Pauly Dunne is offline   Reply With Quote
Old 28th October 2020, 11:55   #18723  |  Link
archiel
FLAC output speed bug I had already fixed yesterday in my personal version.
Track names I will try to add this weekend. Currently I'm too tired mentally after my real day job...
Both tested and working as hoped. Thank you for fixing these
archiel is offline   Reply With Quote
Old 30th October 2020, 16:22   #18724  |  Link
Spasm
Originally Posted by activoice View Post
I've been running RipBot for years with no major problems, but this morning I opened RipBot and it did an update, and now EncodingServer.exe just hangs.
First when I did the update, launching EncodingServer.exe just opened a Command Line window, and the message Encoding Server is not Responding just kept scrolling by over and over... so I deleted Ripbot and did a fresh install.
I can run Ripbot264.exe fine, I can also run EncodingClient.exe fine, but when I try to run EncodingServer.exe it never opens, and I look in task manager and the task is just stuck.
Any ideas?
I also did a Malware Scan, and a SFC scannow to fix any corrupted system files.
LTTP but, do you have an AMD video card? Go to Task Manager and go to the Details tab. Find one of your EncodingServer tasks, right-click on it and Analyze wait chain. If you see something like AUP.exe in there, that's AMD's User Experience Program messing you up.
If that's the case, go into AMD drivers, Settings, General, AMD User Experience Program, and opt out of that crap post-haste. Do a reboot just for good measure.
Edit: Guess I should have read further that this is solved. Interesting that both NV and AMD drivers have their own version of the culprit.
While I'm here, might as well ask, will hardware decoding ever be supported for AMD cards? I will never be able to get my hands on an RTX 30XX, but I think I could get an RX68XX.
Spasm is offline   Reply With Quote
Old 31st October 2020, 13:42   #18725  |  Link
GZZ
I reported this issue back in post #18679
I have now added an image: https://ibb.co/FH9qKQT
What happens is if you have first have selected a custom script from the list and want to remove it again, then selecting "Do not use custom script" dosnt remove it, either from the preview script or the output if you select OK. I think it only happens for Custom scripts.
GZZ is offline   Reply With Quote
Old 3rd November 2020, 02:49   #18726  |  Link
Pauly Dunne
Grumpy Old Man.
What happens is if you have first have selected a custom script from the list and want to remove it again, then selecting "Do not use custom script" doesn't remove it, either from the preview script or the output if you select OK. I think it only happens for Custom scripts.
Hi GZZ, I didn't want to comment until I tried this for myself...which I just did, and mine changes "before my very eye's", instantly.
Have you tried changing it, then backing out of RB, and see if it's changed upon opening RB ??
Old 4th November 2020, 13:34   #18727  |  Link
GZZ
Yes. What I see in the video script window for preview is what I get if I press ok. I can remove the lines from that window and I will get it without (thats my temporary fix). I got several custom MDegrain script in my custom script dropdown and I can change between them and video script window reflect my selection, but nothing happens if I select "Do not use custom script". I have tried going in and out of the program, restart it, update it and so on.
Old 4th November 2020, 14:39   #18728  |  Link
Pauly Dunne
Grumpy Old Man.
Hi, OK, I didn't try that option, but I just tried something else, that seems to work.
However, it might be something the Atak might need to address.
So, if I have a "Custom Filter" enabled, and I then select "Do not use custom script", the Custom Filter indeed does not get removed, HOWEVER, if I choose one of the 3 default "Custom" filters, THEN go back to "Do not use custom script", then it's clears the custom filter.
Old 4th November 2020, 23:02   #18729  |  Link
Atak_Snajpera
I will fix that this weekend
Old 5th November 2020, 15:28   #18730  |  Link
Ryushin
I've starting to encounter the issue that I had a couple of years ago or so but finally went away after Atak fixed it. I think it started occurring again after the last update.
The issue is sometimes (happens about 1 in 5 to 1 in 10 times) when click OK to finish modifying a job (not sure about adding as I'm currently using batch to add the jobs) the "Encoding Settings" window stays open with some things clickable and other things that are not.
If I click "Done" again a second time in the Encoding Settings nothing happens in the window and it does not close, but clicking "Done" the second time wipes out the avisynth script when I got back in to edit the job after closing Ripbot as that is the only way to get control back. I can still use the main window to stop the "Encoding Client" before closing Ripbot
If the "Encoding Settings" window does not close and if I then close Ripbot without clicking "Done" a second time on the "Encoding Settings" window then the Avisyth script is still there.
This bug recently came back after the last update. It's been a good couple of years (or more since time flies) since I've seen this happen.
Ryushin is offline   Reply With Quote
Old 7th November 2020, 18:11   #18731  |  Link
legend
How do I increase video sharpen with Ripbot. Is there any command to add in the script ?
Can any one help me.
legend is offline   Reply With Quote
Old 7th November 2020, 19:54   #18732  |  Link
Atak_Snajpera
Activate "EnhanceFineDetails.avs" under custom script option
BEFORE
AFTER
Old 8th November 2020, 08:51   #18733  |  Link
sixthofmay
source code?
Atak,
I'm developing a distributed encoder and would like to see how you implemented the feature. Is source code available?
sixthofmay is offline   Reply With Quote
Old 8th November 2020, 10:53   #18734  |  Link
userx
userx's Avatar
Hi Atak.
There were some changes within the muxing step. Parameters are now packed into the jobX_MuxFiles.json. I noticed the title tag is not handled anymore.
Sure, i can create a script for that, but can you please append them automatically.
Thank you.
userx is offline   Reply With Quote
Old 8th November 2020, 14:10   #18735  |  Link
Atak_Snajpera
Add section marker to your custom script
#Custom
That marker is needed for my code to determine which section of script to remove.
Old 10th November 2020, 14:41   #18736  |  Link
legend
Yes activate it. Thanks for that. But I have to know that how to decrease or increase sharpness as my taste. Which parameter need to change to this effect.
Old 10th November 2020, 16:16   #18737  |  Link
Atak_Snajpera
Reduce that value
Old 12th November 2020, 22:33   #18738  |  Link
userx
userx's Avatar
DE failed
Hello!
I dig into an issue why EncodingClient is always restarting jobs (1.cmd) after it is finished.
I switched ffmpeg loglevel to debug and saw an error:
encoded 1440 frames, 95.87 fps, 2393.23 kb/s
    Last message repeated 47 times
av_interleaved_write_frame(): Broken pipe
No more output streams to write to, finishing.
Error writing trailer of pipe:: Broken pipe
frame= 1442 fps= 95 q=-0.0 Lsize= 1945359kB time=00:01:00.14 bitrate=264972.9kbits/s speed=3.95x
video:755kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 257632.718750%
Input file #0 (\\USERX-MASTER\RipBot264temp\job1\Chunks\1.avs):
  Input stream #0:0 (video): 1442 packets read (1993420800 bytes); 1442 frames decoded;
  Total: 1442 packets (1993420800 bytes) demuxed
Output file #0 (pipe:):
  Output stream #0:0 (video): 1442 frames encoded; 1442 packets muxed (772912 bytes);
  Total: 1442 packets (772912 bytes) muxed
1442 frames successfully decoded, 0 decoding errors
[AVIOContext @ 0000027b54da5c00] Statistics: 0 seeks, 62006 writeouts
[AVIOContext @ 0000027b54da6f80] Statistics: 927 bytes read, 0 seeks
Conversion failed!
I splitted the commands in 1.cmd and wrote ffmpeg output to 1.pipe. Afterwards I piped the output to x264_x64.exe which finished without errors.
Last lines:
encoded 1440 frames, 20.82 fps, 2393.17 kb/s
Ein Prozess hat versucht, zu einer nicht bestehenden Pipe zu schreiben.
Is it possible that 'process tried to write to a nonexistent pipe' leads to the abortion?
I altered the opencl device (0 or 9) which leads to the same result but with cldev 9 (not exists) EncodingServer complete this chunk without restarting it.
Edit:
Appended Full log.
Old 14th November 2020, 16:41   #18739  |  Link
yuryna
@Atak_Snajpera
Any news about 3 pass support?
(I know i'm quite pricky but is the only thing i miss from using it massively on my collection )
yuryna is offline   Reply With Quote
Old 14th November 2020, 19:38   #18740  |  Link
blacksapprow
@Atak_Snajpera
Is there a way of using CQ mode with 20000kbps setting?
I need this 20000kbps setting to prepare a BD standard m2ts.
blacksapprow is offline   Reply With Quote
