9th July 2007, 16:57 | #601 | Link |
Where I can download the newest version of behappy ?
BeHappy Workspace (http://workspaces.gotdotnet.com/behappy )has been phased-out. |
9th July 2007, 19:20 | #602 | Link | |
The last 'official' release is from 2006-07-19, but there are mod's here and here. Search always in this thread. BTW, I make a copy of GotDotNet info, if anybody need old sources ... |
16th July 2007, 01:27 | #604 | Link | |
2007-03-24 Last Shon3i BeHappy package Last BeHappy mod. About enc_aacplus you can see this thread. I think you have all the necessary. |
16th July 2007, 07:34 | #605 | Link | |
What's in a name dude !
16th July 2007, 09:30 | #606 | Link |
HDConvertToX author
@tebasuna51
why not open a new thread , with the new links .. and ask for developers support? BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
16th July 2007, 11:43 | #607 | Link | |
What is the TODO list for BeHappy? BeHappy is only a GUI to write avs's and encoder parameters for inexpert users. We never can replace a expert user writing avs's and never can put all parameters (see Aften for instance) of a encoder without confuse the newbies. Actually my only doubt about BeHappy is use the last enc_aacplus or not (see the thread mentioned). Other question is AviSynth Audio Encoding with more general issues, common with others tools to convert avs's to audio like BePipe, Wavi or SoundOut. I'm testing Bass libraries 2.3 with a new BassAudio.dll and there are some improvements about aac multichannel decoding. To be continued... |
17th July 2007, 17:43 | #608 | Link |
Decoding the aac multichannel (in .mp4 container), with Bass_aac 2.3.0.1 the channel mapping is ok. But ...
- Decoding .aac, instead .mp4, SoundOut and BeHappy/BePipe crash (Fatal stack overflow error with BePipe). Wavi work but there are some artifacts. - Decoding .mp4, Wavi and SundOut work with a few artifacts but BeHappy/BePipe have a lot of artifacts. - Also I get artifacts decoding two channel aac, Bass 2.2 works fine. I can't recommend the use of Bass 2.3 for aac or ac3. I can't see changes with Bass 2.2 decoding wav (WAVE_FORMAT_EXTENSIBLE), ogg, mp2, mp3 or wma then using Bass 2.2 at least aac stereo can be used. |
18th July 2007, 09:47 | #611 | Link | |
I'm trying to convert ac3 file on raw pcm.
It show this error: Quote:
Thanks EDIT: I've tried also Last BeHappy mod, but there is an windows error crash (I think is AvisynthWrapper.dll ) EDIT2: Oh my bad! I used Directshow and now works Last edited by Bluedeep; 18th July 2007 at 11:54. |
9th August 2007, 16:28 | #612 | Link |
Hello, I'm italian and I'm trying to convert some audio tracks with BeHappy (I'm sorry about some mistakes for the language).
Unfortunately, I'm having problems. Everytimes I try to convert (from some format to another one), an error occurs and the tool is closed by windows XP. Here's a screenshot before the quit of the tool. I have 0.1.9.35190 version, with Avisynth 2.8 and Net Framework 2.0. How can I resolve? Thanks. |
9th August 2007, 17:42 | #614 | Link | |
But I have installed 2.57 version and the problem has occurred again. What can I do? |
13th August 2007, 20:40 | #616 | Link |
A new release of Behappy, for shon3i request.
Maybe shon3i can offer a new full release, but here are sources, last .exe's from BeHappy team and links to external free tools. The changelog is: 2007-08-13 (Tebasuna) + New changes to support new enc_aacPlus.exe from Shon3i: select between Mp4Box and Mp4Mux. (CodingTechnologiesAAC.cs) + New FraunhoferMp3.extension to support free mp3sEncoder.exe from Fraunhofer (http://www.all4mp3.com/tools/sw_fhg_cl.html). + New wavSplit.extension and wavSplit.exe to replace wav2mono and wav2stereo + Only literals changes. (AssemblyInfo.cs, OggVorbisEncoder.cs) The test are welcome. |
24th August 2007, 09:29 | #617 | Link |
Is there any Way/ Plugin/Mod to output mono waves instead of mutichannel interleaved wave ?
I use NicsAC3Source and Timestretch on PAL AC3s and it would be nice to have 6 mono wave Output . For now i use wavewizard to split interleaved to mono |
24th August 2007, 13:15 | #618 | Link | |
In the new release in my precedent post there are WavSplit .exe and .extension to replace Wav2mono and Wav2Stereo. You need only put the files in BeHappy folder, run BeHappy, select WavSplit in BeHappy (4) Destination, instead Wav Writer, and configure (...) mono/stereo. Last edited by tebasuna51; 4th September 2007 at 12:40. |
24th August 2007, 20:28 | #619 | Link |
THX
what is the difference to old wave2mono Output ? Outputs 6 mono waves too... I found Wavesplit.extension ins \Behappy\src Folder, works fine..nice. Thats all i need Behappy Default Wave output is 32Bit right ? For AC3 i set it to "Convert Sample to 16bit" Other Question : Now i prefer NicAC3Source 1.92 over Azid, because Behappy/NicAudio is more Updated Is there any Quality Difference in AC3 to Wave decoding ? I dont think so... And with NicDTSSource compared with Tranzcode 0.4 ? Last edited by ACrowley; 24th August 2007 at 20:52. |
25th August 2007, 03:39 | #620 | Link | |||||
The 32 bit float come from NicAc3Source. AviSynth can change also the bitdepth if any function don't support the actual. Quote:
Let the 32 float. Quote:
behappy |
