15th April 2011, 11:43 | #1404 | Link | |
Software Developer
http://wiki.videolan.org/SoC_x264_2011
16th April 2011, 07:59 | #1406 | Link |
It seems that bluray-compat put weigthp to 1 ? If i add a command line to put weightp to 2, will it work ?
I don't understand this choice. I thought weigthp 2 was bluray compliant according the specs, and problem was only because of some broken chipset ? In the same good way, bluray-compat seems to put pict-struct only on interlaced content, and not on progressive content, wich seems to be strictly compliant to the spec, even if some people suggest to always put pict-struct, because some authoring software required it. So, why chose to strictly follow the spec in one case, and not in the other ? (Unless i am mistaken and understood things wrongly). |
16th April 2011, 08:29 | #1407 | Link |
Has anyone ever had problems with the --zones function when the beginning frame is set to when the screen is blank (black)? Say at the very beginning of a video/movie (frame 0), or a few frames after a fade-to-black?
The problem is that, when that beginning frame of the set zone is reached, there is a 'gray' screen displayed for about a second or two, then the video resumes normally. The gray screen doesn't flash, it's simply static gray screen displayed in lieu of what is meant to be, in this case, a black screen. This has happened with two seperate encodes with two different video sources, with x264 revisions of r1913 and r1924 respectively. Both gray screens occurred when the zone started during a black screen (intro/credits). The zones in this case were nothing special; the only setting used was a bitrate multiplier. I've used zones successfully many times without any problems, but now that I think about it, the start frame for the zone didn't happen to start on a black screen. I am using the x264 CLI with the lastest x264 revision. The 1st and 2nd passes used exactly the same settings (I am aware that unless --slow-firstpass is specified, the 2nd pass settings aren't used for the 1st pass), and that includes the zone settings. The decoder I use is ffdshow w/ mpc-hc. Any ideas? Is this a bug, or have I done something wrong? PS- I don't think posting my x264 cl is relevant in this case, as I cannot fathom how any setting could cause such a weird bug. |
16th April 2011, 08:54 | #1408 | Link | |
BluRay Maniac
pic-struct is not mandatory for progressive content in specs, only for (fake)interlaced and pulldown. But verifiers complain about (probably due bad interpretation of specs) D_S already update x264 to use pic-struct on (fake)interlaced and pulldown in case bluray compat, we now just wait for next revision.
ChapterGen - manipulate with chapters in various i/o formats, with CLI support Official website or Doom9 thread |
16th April 2011, 10:09 | #1414 | Link | |
I am asking because the --slices are still included here |
16th April 2011, 10:14 | #1415 | Link |
BluRay Maniac
no just reduce bframes=3, ref=4 for 1080, ref=6 for 720/576/480, bpyramid=strict, weightp=1, aud=1, nalhrd=vbr
coding, development, x264 dev |
