11th March 2006, 02:34 | #42 | Link |
BTW, here is an archive with all the matrices listed in this thread. If you don't want your matrix in this archive, tell me so and I will remove it.
http://home.nc.rr.com/oline61/x264_custom_matrices.7z I am currently planning to generate several clips designed to test for specific behaviors, and then encode with different quant matrices, and test PSNR and SSIM. What settings should I use to do this? I don't think --qp or --crf will work because they produce different sizes with different matrices which is no good for SSIM and PSNR testing. Should I do 2-pass or 1-pass ABR? For 2-pass do I need to do a new first pass for each matrix? Should I use slow high quality settings, or faster settings? What bitrates would you like to see represented? Last edited by Oline 61; 11th March 2006 at 02:46. |
11th March 2006, 03:16 | #44 | Link |
For low bitrates MP4Guy's Low Bitrate v2 and v3.
They are in the archive I posted and in this thread. Look at the numbers. Bigger numbers = more compressibility. Generally...... Last edited by Oline 61; 11th March 2006 at 03:21. |
11th March 2006, 09:23 | #45 | Link | ||
12th March 2006, 15:53 | #46 | Link | |
Huba Huba
I am asking for this because in many posts the bitrate is often not declared at all or only as eg. 'low', which imho can anything from 100 to 1000 or even above. Furthermore, one wondersDue to this, it's quite difficult to try them out, which is not the case with names like "Jawor's 1CD Matrix".
"The innocent have nothing to fear" :stupid: Last edited by Marsu42; 12th March 2006 at 15:58. |
13th March 2006, 01:00 | #47 | Link |
Marsu42, I plan to test these matrices at different bitrates and determine their PSNR and SSIM. By objectively determining the best matrices for each bitrate I plan to determine which matrices perform well at which bitrate.
Here are the results for 4000kbit/s. I only included matrices designed for high bitrates. I may add more matrices at this bitrate later. These are just preliminary results, and the commandline settings may be refined later. *EDIT: Added clip info.* The clip is from Friday Night Lights. I am using the script that I set up for a 1 DVD5 backup of the movie. Code:
MPEG2Source("VTS_01_1.d2v") Telecide(order=1,guide=1,post=0) Decimate() ColorMatrix() LanczosResize(640,480,taps=9) BlockBuster(method="noise",detail_max=20) Trim(1030,169045) Trim(0,1000) Code:
#pass 1 x264 --pass 1 --stats stats.log -B 4000 --subme 1 --me dia --analyse none --cqmfile matrix.cfg --progress --fps 23.976 -o output.264 input.yuv 640x480 #pass 2 x264 --pass 2 --stats stats.log -B 4000 --subme 3 --me hex --analyse all --8x8dct --cqmfile matrix.cfg --progress --fps 23.976 -o output.264 input.yuv 640x480 Code:
audionut_hr.cfg Average SSIM= 80.18 PSNR Mean Y:44.478 U:56.815 V:58.696 Avg:45.883 Global:45.565 kb/s:4021.56 eqm_avc_hr.cfg Average SSIM= 80.41 PSNR Mean Y:44.415 U:56.814 V:58.672 Avg:45.826 Global:45.480 kb/s:4000.45 flat Average SSIM= 80.83 PSNR Mean Y:44.941 U:56.329 V:58.114 Avg:46.257 Global:45.925 kb/s:4022.82 jvt Average SSIM= 80.76 PSNR Mean Y:44.581 U:56.905 V:58.775 Avg:45.985 Global:45.685 kb/s:4007.02 soulhunter_6of9.cfg Average SSIM= 81.11 PSNR Mean Y:44.875 U:56.324 V:58.119 Avg:46.197 Global:45.877 kb/s:4010.98 Last edited by Oline 61; 13th March 2006 at 02:19. |
14th March 2006, 14:01 | #51 | Link |
Mr. Sandman
lets be serious... no one encodes at 4mbps with h.264...
sagittaire shown even HD do not need such bitrates...
14th March 2006, 14:43 | #52 | Link | |
Bored...
My aim is a PSNR ~50dB (visual lossless) Bye |
14th March 2006, 14:50 | #53 | Link |
Mr. Sandman
then use xvid
what you do is like encoding a 640x480 source at 20mpbs with xvid... it's useless, just use MPEG-2...
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 14th March 2006 at 14:55. |
14th March 2006, 14:58 | #54 | Link | |
14th March 2006, 14:58 | #55 | Link |
retired developer
WHAT?!?!?!?!?!
4mbps for 640x480
Detritus Software |
14th March 2006, 15:06 | #56 | Link | ||
Mr. Sandman
however Quote:
14th March 2006, 15:10 | #57 | Link | |
x.264 is excelent codec but can't do magic. QT H.264 Baseline Profile +1b (Low complexity) for 1280x720 uses 5-6mbit/s. I would repeat another time for H.264 MP/HP 3,8-4,5 Mbit/s is a normal bitrate for 1280x720. Last edited by IgorC; 14th March 2006 at 15:19. |
14th March 2006, 15:27 | #58 | Link |
Mr. Sandman
ok.. but he encoded a 640x480 source at 4mbps....
14th March 2006, 16:01 | #60 | Link |
I have encoded movies at ~1500kbps with X264, the encodes have a lot of artifacts, and texture is never kept perfectly. ~3000 kbps is better, but most of the time its still not "Perfect". Theres no harm in trying to get transparent results from X264, and mpeg2 doesn't look transparent on most sources at 4mbps.
