30th July 2008, 13:15 | #1 | Link |
Problem after ripping John Rambo BD
Hi Guys
I have ripped Rambo to my hard drive using anydvd (newest version) the main movie is on separate m2ts files... i have went through them all and cant work out which ones i should use because the the commentary audio is on so then on others there is the proper movie audio.. Has any1 joined the right m2ts files together and if so whats the correct order??????? Thank You |
30th July 2008, 15:30 | #4 | Link |
look at my guide. there are various ways to join m2ts files, the easiest way is in there using TSmuxer.
Really Easy Blu-Ray/HD-DVD Decryption Guide!: http://forum.doom9.org/showthread.php?t=137151 |
30th July 2008, 16:19 | #6 | Link |
It's very simple:
eac3to.exe i: < replace i: with the letter of your BR drive. This is the resulting output from eac3to..... eac3to v2.41 command line: d:\vidtools\eac3to\eac3to.exe i: ------------------------------------------------------------------------------ EVO, 2 video tracks, 5 audio tracks, 12 subtitle tracks, 2:23:26 "Main Movie" 1: Joined EVO file 2: Chapters, 23 chapters with names 3: h264/AVC, 1080p24 /1.001 (16:9) 4: VC-1, 480p30 /1.001 (3:2), -84ms 5: E-AC3, English, 5.1 channels, 1536kbit/s, 48khz, dialnorm: -27dB, -84ms 6: E-AC3, Italian, 5.1 channels, 768kbit/s, 48khz, dialnorm: -27dB, -84ms "Italian" 7: E-AC3, Spanish, 5.1 channels, 768kbit/s, 48khz, dialnorm: -27dB, -84ms "Castilian" 8: E-AC3, English, 2.0 channels, 192kbit/s, 48khz, dialnorm: -27dB, -84ms "Director Commentary" 9: E-AC3, 2.0 channels, 192kbit/s, 48khz, dialnorm: -27dB, -111ms 10: Subtitle, English, "UK" 11: Subtitle, Italian, "Italian" 12: Subtitle, Spanish, "Castilian" 13: Subtitle, Turkish, "Turkish" 14: Subtitle, Modern Greek, "Greek" 15: Subtitle, Polish, "Polish" 16: Subtitle, Hungarian, "Hungarian" 17: Subtitle, Portuguese, "EU" 18: Subtitle, English, "UK Director Commentary" 19: Subtitle, Italian, "Italian Director Commentary" 20: Subtitle, Spanish, "Castilian Director Commentary" 21: Subtitle, English, "HUD" If the disc has multiple titles it will show each title seperately. Last edited by dat720; 30th July 2008 at 16:22. |
31st July 2008, 22:31 | #8 | Link |
Just use TSSplitter then. If you use the method in my guide of opening the correct .mlps file in TSMuxer you will not need to use TSSplitter. Either way TSSPlitter will join your TS files for you.
1st August 2008, 00:22 | #10 | Link |
There should only be one or two M2TS files that contain the actual movie. Get those. Then find out what order they go in. The reason you're getting commentary on some is probably because the main audio is only available in a format your PC can't decode. Once you have your files and know which comes first, run eac3to on them together (xxxxx.m2ts+yyyyy.m2ts). It can also handle some re-encoding.
1st August 2008, 01:51 | #12 | Link | ||
b4k3d
Use Eac3to_And_More_GUI -> Use your BD-Rom as 'source' folder -> go to 'Eac3to Audio' tab and in the upper right corner select your BD-Rom drive as source -> Eac3to will then scan the disc and show you the MPLS files with the corresponding M2TS files -> Done or what dat720 said: Quote:
1st August 2008, 02:12 | #13 | Link |
If you we're confused about not seeing any M2TS related info in my post that is because the log was for a HD DVD not a BluRay, i dont have any BR's on hand or any log's to actually show you what the output of eac3to is, but it does show you which m2ts make up a playlist and which order they are in.
3rd August 2008, 20:07 | #15 | Link | |
b4k3d
You may have to give it a few seconds or even up to a minute on some machines to start reading. I know on my old P4 ripbox it could take a while. |
blu-ray, brd, john rambo, ripping |
