29th November 2017, 13:53 | #2841 | Link |
Professional Code Monkey
Interesting observation. Does it crash on script evaluation, first frame request or later? There's probably some locking/shared resource in the dll that's causing it. I'll try to debug it just to see but these things are hard to figure out without the source.
29th November 2017, 15:25 | #2842 | Link | |
I tried the same actions on virtualdub filtermod, no problem on navigate and seeking. I tried running "video analysis pass" and abort it and no crash. The program only crash on close. Here's the crash info. https://pastebin.com/3LY0zMrA |
2nd December 2017, 18:43 | #2843 | Link |
Small question: Is there a source filter which can handle movs which only link to the tracks?
On ffmpeg I can play such files by adding '-enable_drefs 1', but I don't know of any option in FFmpegSource2, LSMASHVideoSource or LWLibavVideoSource which supports this. -> is there some to me unknown option or source filter which could be used for this? Cu Selur Ps.: Background: A user asked me (see: https://forum.selur.net/showthread.php?tid=162) whether I could add support for this in Hybrid which is why I'm looking into it. |
2nd December 2017, 18:45 | #2844 | Link | |
2nd December 2017, 19:34 | #2846 | Link |
Do you have some small sample to go with it? I think it's just a simple option to change but need to be able to test it.
2nd December 2017, 19:36 | #2847 | Link |
There's a download link (google drive) to a test folder with the files in the first post over in my board. -> https://forum.selur.net/showthread.php?tid=162
Cu Selur |
4th December 2017, 09:42 | #2849 | Link |
If you call imwri insode frameeval ypu should be able to do it.
5th December 2017, 04:07 | #2850 | Link |
I have problem with the syntax on appending clips reading from text file. I need to reorder a clip like this:
clip[500:600] + clip[400:450] + clip[601:700] Right now my text read like this: Code:
500 600 400 450 601 700 Code:
clip = core.ffms2.source("abc") accum_clip = clip[1] with open(file) as f: line = f.readline() for line in f: start, end = (int(x.strip()) for x in line.split()) accum_clip += clip[start:end] clip = core.std.Trim(accum_clip, 1) |
6th December 2017, 04:58 | #2852 | Link |
Just starting to learn VS, but can't find links to any 64 bit plugins to test a script. Trying to find RemoveGrain.dll and Repair.dll to test finesharp script. Anyone got links?
update - ok, I read they are not needed anymore but I would like to know where the 64 bit plugins reside? Last edited by tyee; 6th December 2017 at 05:12. |
6th December 2017, 06:26 | #2853 | Link | |
6th December 2017, 07:10 | #2854 | Link |
Updating on my issue with loading multiple instances of a virtualdub filters. I did more testings on a few more vd filters, the problem should be coming from either avisynth or virtualdub. (I highly believe that it's avisynth)
Loading multiple instance of any vd filter in an avs script will result in an "out-of-bound memory access" crash on program close, which is the same behavior I had in vapoursynth earlier. This will crash in avisynth: Code:
LoadVirtualDubPlugin("Autolevels.vdf", "Autolevels", 0) src = AVISource("sample.avi").ConvertToRGB32() a = src.Autolevels(40, 46, 50, 0, 0, 0, 0, 0) b = src.Autolevels(40, 80, 50, 0, 0, 0, 0, 0) a+b Code:
LoadVirtualDubPlugin("Autolevels.vdf", "Autolevels", 0) LoadVirtualDubPlugin("Autolevels_copy.vdf", "Autolevels_copy", 0) src = AVISource("sample.avi").ConvertToRGB32() a = src.Autolevels(40, 46, 50, 0, 0, 0, 0, 0) b = src.Autolevels_copy(40, 80, 50, 0, 0, 0, 0, 0) a+b |
6th December 2017, 08:54 | #2855 | Link | |
9th December 2017, 04:46 | #2857 | Link |
Is there a function that can replace a range of frames with another range of frame of the same clip?
I want to replace frame 200-250 with frame 0-150. It's not remapping, the length of the resulting clip should be different to the original. I looked into remapframes but it doesn't have it. |
9th December 2017, 08:20 | #2859 | Link | |
I have another question about slicing, is there a short form to get a clip of N frame to the end of the clip? "clip[50, -1]" only gets frame 50 to the second to the last frame, is there a flag that represent the last frame of the clip? |
9th December 2017, 09:51 | #2860 | Link |
clip[50:]
Of course [:-1] is only giving the second to last. That's what negative slice indexes do. As for wrapping three trims and a splice to do arbitrary replacement of unrelated clips, that kind of really small helper function isn't the sort of thing people share libraries of. A naive implementation is probably about five lines. It's barely even syntactic sugar if you have to define the trim points of the input and replacement separately. |
speed, vaporware, vapoursynth |
