Old 4th September 2017, 22:40   #2681  |  Link
lansing
Originally Posted by Myrsloik View Post
Does ot work properly with R38?
Just tried it, it works fine in R38
Old 4th September 2017, 23:23   #2682  |  Link
Are_
Latest update to zimg fixed this for me, no more segfaults here.
Are_ is offline   Reply With Quote
Old 5th September 2017, 14:22   #2683  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
R39 test4
I miscompiled test3 so that's why it didn't work. That's what happens when you have to reinstall everything on a new computer...
Myrsloik is online now   Reply With Quote
Old 5th September 2017, 14:50   #2684  |  Link
lansing
R39 test4
Yes the problem is fixed now, thanks
Old 7th September 2017, 10:40   #2685  |  Link
deniskx
Hello. You can call me stupid, but I broke my head. I'm pretty good in Avisynth, but in Vapoursynth is a beginner. I have Xubuntu 16.04 x86, Vapoursynth from PPA. I need to connect avisynth TIVTC.dll plugin, because of 2-pass mode=2 and mode=4 (I have a complex video), which is not in VIVTC. And I can not.
import vapoursynth as vs
core = vs.get_core()
core.avs.LoadPlugin(TIVTC.dll)
video = core.ffms2.Source(source=input.mkv)
video = core.avs.TDecimate()
video.set_output()
vspipe --y4m script.vpy - | ffmpeg -i pipe: output.mkv
writes errors like that:
No attribute with the name avs exists. Did you mistype a plugin namespace
Help me, please.
deniskx is offline   Reply With Quote
Old 7th September 2017, 16:00   #2686  |  Link
tuanden0
video.set_output()
Help me, please.
Try add "-" after output:
vspipe --y4m script.vpy - | ffmpeg -i pipe: output.mkv -
tuanden0 is offline   Reply With Quote
Old 7th September 2017, 17:34   #2687  |  Link
Myrsloik
Myrsloik's Avatar
video.set_output()
Help me, please.
You can't load avisynth plugins in linux. If that's what you're trying to do.
Old 7th September 2017, 19:38   #2688  |  Link
LigH
LigH's Avatar
Maybe not yet ...
New German Gleitz board
Old 7th September 2017, 19:41   #2689  |  Link
Myrsloik
Myrsloik's Avatar
Originally Posted by LigH View Post
Maybe not yet ...
Not by me. Proper ports are better anyway. You'd still need x64 versions of everything which not all things have.
I have a dream that one day an avisynth user will suggest doing the right thing and not just another shitty compatibility hack.
Old 7th September 2017, 19:46   #2690  |  Link
LigH
LigH's Avatar
Of course. A cross-platform portable loadable library format ... sigh ... Mono?!
Old 7th September 2017, 19:47   #2691  |  Link
Myrsloik
Myrsloik's Avatar
It's called C. With a system compiler. Works everywhere.
Old 7th September 2017, 20:03   #2692  |  Link
LigH
LigH's Avatar
May there be no system dependent function calls. Or references to external libraries (like FFT3D). Do it yourself ... everything ... from scratch. Or from other OpenSource projects. Rely on the community! Closed Source is so ... last millennium.
Old 8th September 2017, 13:56   #2693  |  Link
deniskx
Thanks. This should be specified here so as not to mislead people.
What the point of Vapoursynth then? Another fork? Windows has a working learning Avisynth. Linux does not have avs plug-ins, so Avisynth under Wine is the best solution then.
Old 8th September 2017, 14:02   #2694  |  Link
Myrsloik
Myrsloik's Avatar
Native binaries are native only. You should definitely know this since you've heard about wine.
VapourSynth also isn't a fork. The point is code quality, portability and proper multithreading support. And more flexible scripting too.
And no, not caving in to your documentation demands. It shall remain unchanged.
Old 8th September 2017, 14:59   #2695  |  Link
feisty2
I'm Siri
feisty2's Avatar
vaporsynth got the ability (std.Expr) to evaluate RPN expressions on 32 bits floating point precision video clips and take (practically) arbitrary amount of clips as the input, while avisynth got the naïve mt_lut(xyz) that takes up to 3 clips and only works with 8 bits low precision clips
that's enough for me to sentence avisynth to death
feisty2 is offline   Reply With Quote
Old 8th September 2017, 16:14   #2696  |  Link
TheFluff
Excessively jovial fellow
Unlike Avisynth, VS isn't completely awful.
Old 8th September 2017, 16:55   #2697  |  Link
poisondeathray
But avisynth has things that vapoursynth can't do right now. Like audio.
So not completely aweful
Old 10th September 2017, 14:46   #2698  |  Link
mparade
feeding x265 via Vapoursynth
Can someone help why it is not possible to feed a HDR10 encoded content to x265 to reencode using DGDecNV (latest with HDR10 support) and Vapoursynth?
Error message as follows:
x265 [error]: unable to open input file
Author of DGDecNV suggested asking the Vapoursynth guys about it. What information should be provided for support?
I am not a programmer, not using Vapoursynth directly but perhaps can provide all the info required to find the reason for the problem.
Please help.
mparade is offline   Reply With Quote
Old 10th September 2017, 15:03   #2699  |  Link
stax76
stax76's Avatar
@mparade
Your VS script would be a start.
Old 10th September 2017, 16:00   #2700  |  Link
mparade
Originally Posted by stax76 View Post
@mparade
Please find as an attachement.
http://mammutmail.com/hu/download/b4...8fff07f65d0611
speed, vaporware, vapoursynth
