6th January 2010, 03:39 | #981 | Link |
Yeah, whurlston is using another player, but I'm using MPC-HC. Different renderers yield different degrees of this problem for me. madVR doesn't seem to have it, but VMR9 seems to make it worse. This doesn't seem to happen at all with 4000 cards.
6th January 2010, 07:40 | #982 | Link |
I still can't get m2ts files with TrueHD to be bitstreamed (using 5850 w/ latest mphc svn, ffdshow svn, all from xvidvideo.ru). DTS-MA is passed through no problem. In FFA I only have DTS-MA and TrueHD checked in the passthrough options. Where should I start reading to try and fix this? Thank you.
6th January 2010, 12:22 | #985 | Link |
Media Control author
Okay, I had a quick look on it with a great tool (araxis merge) that makes comparisons, and guess what...
1/ The media types are identical except the mediasubtype but I don't think this is the cause (as the ATI receives different media types) 2/ The timestamp are identical : they are different in values but this is not what matters. The important is the delay between 2 consecutive timestamps and it is even BUT : 3/ The bitstreams are mostly identical but not all the time : For example FFDShow : Code:
72F81F4E1104CC290001000000000000FEFEC029FE TMT Code:
72F81F4E1104D8290001000000000000FEFEC029FE I will work on this later Cheers Damien |
6th January 2010, 12:50 | #986 | Link |
Hi Damien
Cool that the log are usefull And you find the way to make working, great and great again And the log for DTS-MA and HR will it be usefull too ? Thx again And have a good launch and have a nice day too Seb.
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355. |
6th January 2010, 15:02 | #988 | Link | |
6th January 2010, 17:26 | #989 | Link | |
6th January 2010, 17:36 | #990 | Link |
It's very possible. It looks as though albain found the difference that's likely to be causing the problem, so, hopefully tomorrow he'll release an updated build for us to try. If this leads to better compatibility then it was worth the effort IMO.
6th January 2010, 17:43 | #991 | Link |
Hi, for now I didn't find out what makes that difference and that doesn't sound logical to me.
There are 4 hexa (2 bytes) after 72F81F4E1104 which is the size. The bytes have to be swapped. For example : 72F81F4E1104 C828 gives 28C8 = 10440 bytes = 12 extra bytes (0001000000000000FEFE just after) + size of the DTS block + size of DTS-HD block This rule sound right and is respected most of the time. But sometimes there is a difference on TMT logs : there are a few more bytes (4, 8, 12 it depends) I thought that this was some kindof modulo but this isn't. Weird.... Last edited by albain; 6th January 2010 at 17:46. |
6th January 2010, 17:50 | #992 | Link |
Uhhhh, that's not good. How do we figure out what those extra bytes are and what they should be and when they should be used?? Yikes.
6th January 2010, 19:20 | #993 | Link |
Those extra bytes are always there : they are 12 bytes long,
I made a little program to calculate the difference between the FFDShow size (size of the buffer actually) and TMT size which is higher sometimes : Here is an extract. Value 1 : length that is different sometimes Value 2 : length of the buffer Value 3 : value 2 - value 1 - 12 (the extra bytes) When value 3 is 0, this is normal Code:
3256;3236;8 5272;5248;12 5240;5220;8 5288;5264;12 5256;5240;4 5240;5220;8 5304;5280;12 5800;5776;12 5784;5764;8 5800;5788;0 5784;5764;8 5832;5820;0 5880;5864;4 5816;5792;12 5864;5848;4 5816;5792;12 5864;5852;0 5784;5764;8 5720;5704;4 5768;5744;12 5768;5752;4 5736;5720;4 5768;5744;12 5768;5744;12 5752;5740;0 5736;5720;4 5784;5760;12 ... ... 17544;17520;12 17048;17036;0 17528;17508;8 17608;17592;4 17720;17700;8 17688;17664;12 18120;18104;4 17432;17416;4 17736;17716;8 17752;17728;12 17432;17420;0 17960;17940;8 17752;17728;12 17272;17248;12 18136;18116;8 17560;17544;4 17256;17244;0 17384;17360;12 17720;17704;4 17624;17612;0 17272;17256;4 17496;17476;8 17624;17612;0 16824;16812;0 17160;17140;8 17000;16984;4 17448;17424;12 17448;17436;0 17176;17164;0 16616;16596;8 17160;17136;12 17080;17064;4 Last edited by albain; 6th January 2010 at 19:26. |
6th January 2010, 19:54 | #997 | Link |
How is the buffer size calculated? I'd like to take a peak at this and see if I can see any kind of pattern in it that may help.
6th January 2010, 20:24 | #999 | Link | |
Each buffer is formatted as follows : 1/ 72F81F4E1104 : IEC header including format type 2/ calculated size (2 bytes or 4 hexas) : the size which is wrongly calculated by FFDShow. This size corresponds to the bytes starting at 3/ (so it starts with the extra bytes) 3/ 0001000000000000FEFE : extra bytes (12 bytes) 4/ data size (2 bytes) sum of size of the DTS block + the DTS HD block. => normally this data size + 12 = calculated size. After this data size (starting at 4/) you will get zeros to fill in the rest of the buffer which is always 32768 long 4/ DTS block starting with FE7F 5/ DTS HD block following starting with 58642520 68160001000000000000FEFE5016 |
