27th June 2011, 10:12 | #1 | Link |
help with a video encoder
Please i need encode a video with the next especificacion:
--------------------------------------------- Format : MPEG-TS OverallBitRate/String : 3500 Kbps ----------------------------------------- Video Format : MPEG Video Format_Version : Version 2 Format_Profile : Main@Main Format_Settings_BVOP/String : Yes Format_Settings_Matrix/String : Default Format_Settings_GOP : M=3, N=12 BitRate_Mode/String : CBR BitRate/String : 2910 Kbps Width/String : 720 pixel3 Height/String : 576 pixel3 DisplayAspectRatio/String : 4:3 FrameRate/String : 25.000 fps3 Standard : PAL ColorSpace : YUV ChromaSubsampling : 4:2:0 ---------------------------------------- I'm encoding with "Super" but do not know what parameters to use ... you recommend me another encoder or this is good? if so, which use parameters to adjust my specifications? thanks |
29th June 2011, 19:11 | #6 | Link | |
Posts: n/a
Open your file in DGIndex. File-->Open Video-->Field Operation-->Honor Pulldown Flags (You can usually use Force Film if your source is 95% film or higher.) File-->Save Project-->Save as Type: DGIndex Project File (*.d2v) Open Notepad. File-->Save As... MyScript.avs -- do not forget to add .avs to the end. Type the following, adjusting it to fit your directory structure. Code:
Mpeg2source("C:\Wherever\Whatever.d2v") |
encode, encoder, encoding, video |
