6th September 2010, 16:11 | #14501 | Link |
MPC-HC Project Manager
Stable build Release Candidate ready for testing.
Hello Everyone.
We have a Release Candidate ready for testing. VS2008 builds: http://xhmikosr.1f0.de/index.php?fol...hjX21zdmMyMDA4 VS2010 buils(SSE2 cpu required): http://xhmikosr.1f0.de/index.php?fol...hjX21zdmMyMDEw Please test for codec regressions specifically(so files that worked before). Please only report regressions compared to recent nightly builds.
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC Last edited by tetsuo55; 6th September 2010 at 16:33. |
6th September 2010, 16:31 | #14502 | Link | |
not related: I tried the monkey clip with a 4500MHD. Using the Microsoft DTV-DVD Decoder(DXVA), I can't recall exactly what happened, but either it didn't play properly or it was lagging. Using the MPC Decoder (DXVA), it can play at ~60fps, but the 4500MHD + MPC Decoder has a bug where it produces artifacts on certain videos. I think it's skipping deblocking which would mean that it's skipping a step and load would probably be less when decoding. Last edited by namaiki; 6th September 2010 at 16:34. |
6th September 2010, 16:35 | #14503 | Link | |
Congrats! |
6th September 2010, 17:39 | #14504 | Link | |
I thought VP3 would be able to play it as well. |
6th September 2010, 17:43 | #14506 | Link | ||
I have not. I might try it tomorrow if I can get my hands on the laptop with VP3 again. (Mine is the 9600M GT(VP2)/4500MHD - annoying hybrid graphics) With the VP2 card, it looks like the video goes fast and slow. However in splash player (also no stats) it looks fine and the system doesn't even sweat.
edit: Quote:
Also, curiously enough, Splash player seems to be able to play the monkey file(ken_ross_02-1920x1080_60fpsRef4.mts) very smoothly with the VP2 card, but Splash player doesn't have stats. Last edited by namaiki; 6th September 2010 at 18:17. |
6th September 2010, 18:09 | #14508 | Link | |
http://forum.doom9.org/showpost.php?...ostcount=14495 |
6th September 2010, 20:13 | #14509 | Link | |
Splash Pro v1.2 is faster with AVCHD clips. It uses - I think - some kind of buffering and is moving between 40 fps to 60 fps, in loops. You can benchmark Splash, using FRAPS. Last edited by NikosD; 6th September 2010 at 20:16. |
6th September 2010, 20:23 | #14510 | Link |
LOL FRAPS reports a frame rate of ~39-42fps for Splash Lite player + VP2. Now this is funny.
Splash Player lite + 4500MHD is ~39-45fps. MPC-HC (MPC Decoder - DXVA) + 4500MHD is ~59-60fps. Last edited by namaiki; 6th September 2010 at 20:26. |
6th September 2010, 21:06 | #14512 | Link |
That is what I have done. I will post VP3 results later, but that should be it. As far as I can tell, MPC-HC's DXVA doesn't seem to have a performance issue.
edit: the PC with VP3 which I have access to has Windows Vista, so I don't think there is any point in testing it's WMP. Last edited by namaiki; 7th September 2010 at 07:01. |
6th September 2010, 21:43 | #14514 | Link | |
If you come on IRC maybe someone else can help. We would also like to ask you, do you want to come on the mpc-hc team?
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC |
7th September 2010, 09:17 | #14515 | Link |
Been using MPC-HC as a media player a long time now, but now decided to try and use it to view DTV.
My conf is Win 7 Ultimate 32bit, Terratec Cinergy T XXS USB DVB-T card and v2491 mpchc (using EVR for the testing). Haven't used any previous ver of mpchc for dtv playback, so I'm not quite familiar with it. Anyway, after some fiddling around, I still haven't quite got it to play dtv. As a remark, MCE7 and other DVB BDA players (DVBDream 1.5 for instance) play dtv very well. Under Options, I have selected the following: http://img715.imageshack.us/img715/9655/optionsm.jpg Under Network providers, there are also options like: Microsoft ATSC NP (=Network provider ), Microsoft DVBC np, Microsoft DVBS NP and Microsoft NP. I have also tried the last one (MS NP). Under Tuner and Receiver there are no other options. Now, the scanning doesn't receive any channels using the default range of 474000-858000 (BW:8000), even though during the scan the F-meter (F stands for what? ) seems to pick up signal, although the Q-meter doesn't show anything and no channels are found. If I set the range to 666000-666000 (that's MUX1 here, CH45), it doesn't also find any channels, if i set the range to smth like 642000-666000 (ch42-ch45), it finds programs on CH45 (on 2nd or 3rd attempt), but doesn't stop there, it still scans up to 858000 or smth. Now, the programs/channels found, the viewing part. This picture should be worth more than a 1000 words: http://img225.imageshack.us/img225/2931/57141836.jpg Should there be so many filters loaded? |
7th September 2010, 11:10 | #14517 | Link | |
1) The values set for the frequency range and the bandwidth are currently not taken into account. It not a big problem : this one line patch should correct the problem. 2) Sometime all the channels of a multiplex are missed by the scan, I don't know why because it works when I try to do step by step debugging. |
7th September 2010, 12:10 | #14518 | Link |
Is akapuma required to post his request for supporting long description tags in the bug tracker to get any reply?
