2nd November 2009, 04:24 | #1 | Link |
Megui x264. Argument Error for every b-pyrimid option
I am using version 0.3.1.1056 of MeGUI. I tried updating to the newest version of x264 (1318) at x264.nl. I've been getting an argument error no matter what I set the b-pyramid option to. Here is an example:
An error occurred: x264 [error]: invalid argument: b-pyramid = --b-bias Here is another: An error occurred: x264 [error]: invalid argument: b-pyramid = --direct Do you know whats wrong? Or even better, do you know a fix? |
2nd November 2009, 04:31 | #2 | Link |
You can use latest 0.3.1.1057 which has been updated to reflect the latest x264's changes, but it has a bug and will delete all your x264 profiles. The best would be to stop using MeGUI until it gets fixed, or use another GUI, or even better don't even use a GUI; encode via command line.
2nd November 2009, 04:34 | #3 | Link |
Is it worth updating to the latest version of x264? Are there substantial quality or speed gains? Aside from moving files around and compiling java applications, I don't have much experience in the DOS command line (i have some more experience in unix). Is there a good guide somewhere for the the command line version of x264?
2nd November 2009, 04:43 | #4 | Link |
x264 IS a commandline application. MeGUI is a GUI for x264. Personally I always update to the latest version of x264. Not so many speed gains, since it's already optimized, but quality improvements. Take a look at some of the commits in the GIT repository to just get an idea of its development. First thing you should do if you want to encode via cmd, run x264 --help and you'll see all the various choices. You can even use the builtin presets to make things easier.
2nd November 2009, 15:38 | #5 | Link | |
So getting back to your example x264 is taking as value for --b-pyramid the next parameter in the commandline, in your examples "--direct" and "--b-bias" |
26th November 2009, 07:41 | #10 | Link |
Software Developer
Actually the eyeroll was because it's now 26/11 and last response here was 2/11, so it was more in the lines of "how longer do we have to wait". Check your trolling decoder for spec-violation bugs.
26th November 2009, 12:24 | #11 | Link | |
26th November 2009, 14:12 | #12 | Link | |
It's not that I don't want to switch to another GUI but the GUI's mentioned above don't give me the amount of control I want (RipBot), or I don't like the way they work (StaxRip, HDConverttoX). Having said that I see there's a new version of Handbrake with the latest x264 build, I'll try that out again. |
26th November 2009, 23:37 | #13 | Link |
HD-Fan
MeGUI doesn't suck. It's probably the best or if best is not a good word, then the most useful app than any other GUI I've seen on Doom9. It's really advanced and less CPU usage where others put things you don't know in the scripts and take more CPU usages. Super annoying. MeGUI is like set up the x264 you want, set up the script you want and go convert. Done!
I am also having that problem the b-pyramid -direct and please with respect do not reply here just to suggest another GUI. It's really not helping the problem. If x264 is too new for the MeGUI then will using an older x264.exe help? I'll try and see and reply back but I asked because I don't know how the details will be like if latest MeGUI is suppose to be used with one of the older x264.exe files or not etc. |
27th November 2009, 00:21 | #14 | Link |
Why don't you grab sources and fix this syntax error???? Everybody is crying but at the same time everybody has two left hands.
27th November 2009, 04:57 | #15 | Link | |
Software Developer
Excuse me? So now anyone that doesn't have a GUI can't criticize? Yeah, that shows real maturity and real confidence in what you do. |
27th November 2009, 05:52 | #16 | Link | |
Still I'm hoping someone will take your suggestion at heart and pick up MeGUI development again Would be sad to see this GUI go down the same path as GordianKnot which I liked in the past for Xvid encoding. |
29th November 2009, 02:23 | #18 | Link | |
http://forum.doom9.org/showthread.ph...60#post1347860 Last edited by Schra; 29th November 2009 at 02:36. |
1st December 2009, 00:46 | #19 | Link |
Regarding the error, the syntax mismatch in 1056 can easily be got around by unchecking 'Keep some B-Frames as reference' in Frame Type and entering a custom parameter for x264 in the Misc tab. For b-pyramid it would be --b-pyramid strict or --b-pyramid normal (depending on if u want a strictly hierarchical pyramid or not).
BTW is it really a bug in 1057 coz I compared the scratchpad profile xml in 1057 with a profile xml in 1056 and found that the elements for mixed frames and the value types for BFramePyramid were different. On changing those, 1057 accepted the profile as a valid one & didnt delete it. Took me 6 days to encode an hr long video with 2pass insane settings in build 1057 (Yea I know I have a bad processor. Moreover, it's a laptop). Cool huh. |
error, invalid argument, megui, x264 |
