27th May 2011, 17:08 | #461 | Link |
Well, I very much doubt that can happen, because it sounds like a very big undertaking.
Honestly, if you are so reliant on virtualdub plugins, your best option is probably to use virtualdub for them (or try to find native avisynth plugins that can achieve the same purpose) By the way, here is a wrapper function for your colormill, which looks like it should do the trick. Just put this as an avsi file in your plugins folder, and call it with Colormill(number) Then you can set up a user slider for it, with values from -100 to 100. Code:
function colormill(clip c, int "darklevels"){ darklevels = default(darklevels, 0) video = c.ConverttoRGB32(matrix="rec601",interlaced=true) LoadVirtualdubplugin("C:\Program Files\VirtualDubMod\plugins\colormill.vdf", "colormill_vdf",1) darklevels = (darklevels * 256) + 25700 video = video.colormill_vdf(25700, 25700, 25700, 25700, darklevels, 25700, 25700, 25700, 25700, 25700, 25700, 25700, 25700, 1124, 5) return video } Last edited by Zarxrax; 27th May 2011 at 18:00. |
27th May 2011, 22:41 | #462 | Link |
Small bugfix release:
Version 2.1.7 - Fixed garbage data displayed on shortcut labels - Fixed wrong checked/unchecked status for 'Flip' menu items. - Improve menu item 'Hide the preview' to 'Show/Hide the preview. - Fixed missing customized function presets (This situation happened if an uninstalled plugin is not in filterdb.dat and has no customized definition. Now, avsp will check and keep its definiton as customized definition to avoid missing its preset. If the reason is from renaming, you can copy old preset to new one and then delete. But, leaving it there is also harmless.) |
28th May 2011, 02:18 | #463 | Link |
Totally unexpected awesomeness, Im looking forward to hard use this version. Just only fix this little issue when changing shortcuts:
Traceback (most recent call last): File "AvsP.pyo", line 7557, in OnMenuConfigureShortcuts NameError: global name 'GetTranslatedShortcut' is not defined
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread |
28th May 2011, 02:33 | #464 | Link | |
28th May 2011, 05:00 | #465 | Link |
I'm testing this new version and there is an error window log:
Traceback (most recent call last): File "AvsP.pyo", line 7215, in OnMenuVideoToggle File "AvsP.pyo", line 10594, in ShowVideoFrame File "AvsP.pyo", line 11052, in UpdateScriptAVI File "wx\_core.pyo", line 9744, in ReleaseMouse wx._core.PyAssertionError: C++ assertion "GetCapture() == this" failed at ..\..\src\common\wincmn.cpp(2536) in wxWindowBase::ReleaseMouse(): attempt to release mouse, but this window hasn't captured it This script work perfectly with version 2.0.2 you have some work on the table... |
28th May 2011, 07:33 | #467 | Link | |
31st May 2011, 16:30 | #470 | Link |
hey, some notes by using this version:
-this one -remember save mp4 last paremeters (quality,sar...). Remember its settings inside options.dat too, for reusing in next versions. -on-cache processing option; that is, work over the cached fragment. -some crashings are not detected (task termination, etc), thus session is not autoloaded -disable autocomplete calltip when navigating inside function parameters. (This one could be argued) -when autocomplete calltip is on you can't move cursor -tab labeling
31st May 2011, 18:25 | #471 | Link |
Can I request some event to refresh the "preview frame" like as avsp do?
I mean refresh by: - click on preview, - focus on preview, - "return" pressed on changing parameters into the "separate video preview window". I also noticed that in some cases seems to refresh only after be moved backward/forward one/some frame. |
2nd June 2011, 17:13 | #473 | Link | |
I have another error today:
Edit: Yeah i think it's related i'm trying a simple script with the neat video filter only and i can't get a preview, it's working perfectly with the v 2.0.2. Please fix asap thanks Last edited by Mounir; 2nd June 2011 at 17:23. |
2nd June 2011, 22:48 | #474 | Link |
Version 2.1.8
- when text has changed, left-clicking the video preview will refresh the preview - fixed pressing enter while in a text box in slider window not updating the video preview - add an option 'Refresh preview automatically' to 'Options|Program settings|Video 1'. If disabled, switching focus to the video preview or changing sliders wont cause a refresh - fixed an issue with mouse release errors |
3rd June 2011, 13:04 | #478 | Link |
User of free A/V tools
Yes, I understand that it is an ugly approach to ask the user to rename some files manually but I remember a while ago there was an issue with these filenames and ANGEL_SU (AvsPmod contributor) advised to do so.
Perhaps there was a fix released meanwhile but I really can't tell, I'm not using these new builds (yet) myself. |
3rd June 2011, 17:21 | #479 | Link |
This is not really a limitation of avspmod, but one of avisynth itself.
Generally, you can specify a function name by using its "long name", which includes the name of the dll itself in the function call. For instance, lets say I want to use the function named "Deen" from the dll Deen.dll. I could call it with the short name Deen(), or I could also call it with the long name, Deen_Deen() However, if there is a hyphen in the filename, the ability to call it with the long name breaks. If you don't care about this, you can just tick the box so that it wont bother you again. By the way, if you are wondering why anyone might ever want to use the long names, I think that this would allow you to use multiple versions of the same plugin. (im just guessing... this is the only logical reason I can think of) Last edited by Zarxrax; 3rd June 2011 at 17:29. |
3rd June 2011, 17:58 | #480 | Link | |
Avisynth language lover
http://avisynth.org/mediawiki/Plugin...on_names_v2.55 |
