Old 18th August 2009, 09:12   #5521  |  Link
holy_reds
holy_reds's Avatar
Originally Posted by froggy1 View Post
Revealing the site has nothing to do with this. The forum rules explicitly prohibit any discussions or help on content which you don't hold the rights to and is illegally downloaded. I suggest you go read the rules before getting banned or this whole very useful program development and support thread getting closed because of you!
Okay sorry for falling into senior member trap question
Also isn't it wiser to report my post than asking a trap question ?
Edited all previous post
holy_reds is offline   Reply With Quote
Old 18th August 2009, 09:41   #5522  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
It wasn't a trap question, you only interpreted it like one . There's a reason, well one of them, why rules are written and not passed on in other form from mods to users. It's so that one does not need to repeat and describe them in length each time a violation occurs. Asking a user to just read the rules which points out such things is easier than each time writing 2-3 full sentences and explain that such things are not allowed here and why that is.
Anyways, back on topic
Old 18th August 2009, 10:16   #5523  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Love how you say small, when it requires you to download a bunch of software to work
Whole gui is just one .exe (less than 600 KB). So I guess you prefer to download all tools manually??? Next time don't bother me with that useless posts, ok?
Old 18th August 2009, 13:04   #5524  |  Link
mrdutchie
hi there.
i tried your program, and LOVE IT!!!!
1 thing though... is it possbile to have some defaults settings set after the file get's loaded?
i did change the default profile, but
still need to change manually for every file
the
Size under properties, to psp,ipod
De-interlace to ttf -->29.97 (not sure what it does but makes my movies without lines in it)
it would be great if there was a profile for that
also if i change the mode from CF to 2-pass then i can set the bitrate for that movie. is it possible to change it to 1 pass?
keep up the good work
mrdutchie is offline   Reply With Quote
Old 18th August 2009, 23:32   #5525  |  Link
kenwheeler77
ripbot264 v1.14.3 hangs on x264_x86.exe
I have a fresh install of Windows 7 RC1, Core 2 Quad, 2 GB Ram and plenty of drive. I am trying to convert .m2ts files to stream to my ps3. I was having no problems on my Vista box (but haven't tried v1.14.3 from Vista) with these video sources (blu-ray .m2ts files). The issue I'm now having is this:
It gets through the "Encoding Audio" but seems to get stuck on the "Please Wait - Initializing".
I show a process by the name of x264_x86.exe using 25% CPU and 700k RAM. Nothing shows up in the Ripbot Logs folder.
Any ideas to get me going in the right direction would be greatly appreciated.
I've installed ffdshow_rev3052
Thank you,
Ken
kenwheeler77 is offline   Reply With Quote
Old 18th August 2009, 23:39   #5526  |  Link
Atak_Snajpera
Install Windows 7 RTM instead of unfinished RC
Old 19th August 2009, 01:12   #5527  |  Link
m0nkie
Originally Posted by m0nkie View Post
whenever input file contains vbr mp3 audio track, the output file always has out of sync problem. what should i do? should i use EnsureVBRMP3Sync() as megui does for every audio track?
thanks.
i'm still waiting for some kind of solution for that...
also tried EnsureVBRMP3Sync(). didnt help.
m0nkie is offline   Reply With Quote
Old 19th August 2009, 02:26   #5528  |  Link
JimmyFace
Can someone tell me why Ripbot only uses about 40% of the processor on Pass 1 of an encode with an i7 920 CPU?
JimmyFace is offline   Reply With Quote
Old 19th August 2009, 17:13   #5529  |  Link
mrdutchie
I have several VOB files, ripped from a Season DVD
they all work fine, except for 2.
I am getting an error message about, cannot open in HIDE
mode.
what does it mean?. searched around but didn't find anything
thanks
Old 19th August 2009, 19:05   #5530  |  Link
It probably means that RipBot is handing a bad file name to DGIndex via the CLI.
Old 19th August 2009, 19:06   #5531  |  Link
mrdutchie
hmm.. let me check if there are weird chars in the filename.
yep you we're right... had , (comma) in the filenames
took them out, and now it's working
Old 20th August 2009, 03:44   #5532  |  Link
JimmyFace
Do I need to do anything special to add the forced subs in when ripping a bluray? For example, English film, with short sequences of foreign dialogue? Or do I have to specifically add the subtitle tracks?
Old 20th August 2009, 04:06   #5533  |  Link
8ternity
8ternity's Avatar
O.M.G... I don't know how he will feel to use, demux, convert file size, video, audio, delay, convert video and cacul rating with video, audio size to fit on a standard disc? how many dos commands he need to do to optain an great gui and easy application make everthing we need in a couple of clics.
GUI = Graphic User Interface
it does all hard work for you! to snajpera!!!
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating.
8ternity is offline   Reply With Quote
Old 20th August 2009, 04:06   #5534  |  Link
prettyboy85712
You must add each track.
prettyboy85712 is offline   Reply With Quote
Old 20th August 2009, 04:10   #5535  |  Link
8ternity
8ternity's Avatar
-Did you check "LOW PRIORITY" in the main page application?
-Did you have installed any application control and tunned windows?
Old 20th August 2009, 13:11   #5536  |  Link
JimmyFace
I tried with both low priority checked and unchecked. When it does the 2nd pass it works 100% but not 1st pass. I found another thread with another i7 owner complaining of the exact same thing with no resolution.
Also when I do the x264 HD benchmark, it runs at 100%. I'm not sure what's different with the first pass, but I think I could be getting much faster encodes if it would encode at 100%.
Old 20th August 2009, 13:52   #5537  |  Link
Blackwalker
Blackwalker's Avatar
Hey, dunno if all of yuo are out for holiday, but i have a problem with 2 mkv files
and dunno what to do...
its a: 1920x816
Video
Format : AVC
Format profile : High@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 8 frames
Muxing mode : Container profile=Unknown@5.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 10mn
Bit rate : 7 964 Kbps
Nominal bit rate : 8 329 Kbps
Width : 1 920 pixels
Height : 816 pixels
Display aspect ratio : 2.35
Frame rate : 25.000 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.203
Writing library : x264 core 56 svn-667C
Encoding settings : cabac=1 / ref=5 / deblock=1:-4:-4 / analyse=0x3:0x133 / me=umh / subme=6 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=2 / deadzone=4,6 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=8329 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / zones=187687,195786,b=0.15 / aq=1:0.3:15.0
Language : English
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 2h 10mn
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Title : Italiano
Language : Italian
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Title : Italiano
Language : Italian
here are the Mediainfo of move 2:
its a: 1920x816
Video
Format : AVC
Duration : 2h 16mn
Bit rate : 7 597 Kbps
Nominal bit rate : 7 940 Kbps
Height : 816 pixels
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.194
Encoding settings : cabac=1 / ref=5 / deblock=1:-4:-4 / analyse=0x3:0x133 / me=umh / subme=6 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=2 / deadzone=4,6 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=7940 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / zones=195498,204910,q=26 / aq=1:0.3:15.0
Language : English
Audio
Format : AC-3
Codec ID : A_AC3
Duration : 2h 16mn
Bit rate : 448 Kbps
Title : Italiano
Language : Italian
Text
Format : UTF-8
Title : Italiano
Language : Italian
both are 1920x816.
i try with RIpBot but wont accept this resolution...
i try with Clown_BD but give me error....
i try with Tsmuxer (i try with any settings), i hear the audio but no video!!!....
I try with mkv2vob looks ok, but the output its a .mpg file, if i remember well...and looks ok, but i'd like to
have it in m2ts. I try to rename the .mpg to m2ts and on my computer looks like it play ok (strange) with
mplayerc (media player classic).
I'd like to know, if there is a way to convert it to m2ts (that work!) without
loosing any wuality of the sound or video!
any suggestion?
Hope someone can give me a hand, thx
byez =)
Blackwalker is offline   Reply With Quote
Old 20th August 2009, 13:56   #5538  |  Link
We cannot help you with rule 6 material and you should not be posting about it.
Old 20th August 2009, 14:31   #5539  |  Link
mrdutchie
is it possible to increase the volume for the sound within the program?
I converted one dvd and you can hardly hear the sound.
(when the DVD plays itself, i need to crank up the volume
on the tv also)
Old 20th August 2009, 15:18   #5540  |  Link
DarkZell666
aka XaS
DarkZell666's Avatar
This is expected behavior (no matter what CPU) when using --b-adapt 2, which isn't optimally threaded yet.
Q9300 OC @ 3.2ghz / Asus P5E3 / 4GB PC10600 / Geforce 8600 GTS
DarkZell666 is offline   Reply With Quote
