Old 1st January 2021, 07:22   #1  |  Link
lansing
Unicode filename support for DGIndexNV?
Any news on this?
Old 1st January 2021, 18:11   #2  |  Link
stax76
stax76's Avatar
Does it have a resource file embedded? You can check with Resource Hacker.
Old 1st January 2021, 20:08   #3  |  Link
lansing
I'm referring to the regular file name in windows. The program pretty much couldn't open any file with non-English filename/file path.
Old 2nd January 2021, 04:26   #4  |  Link
stax76
stax76's Avatar
I like the topic text encoding but since it's not open source and another reason... (not related to you) I think it's not the right thread for me.
I suggest using the support forum of the author:
http://rationalqm.us/board/index.php
Old 2nd January 2021, 21:57   #5  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Looking at a vanilla "DGIndex.exe", it seems like it contains an empty manifest.
You may wish to replace that with the following content, e.g. by using Resource Hacker, in order to enable UTF-8 support:
(requires Windows 10, Version 1903 or later!)
<?xml version="1.0" encoding="utf-8" standalone="yes"?>
<assembly xmlns="urn:schemas-microsoft-com:asm.v1" manifestVersion="1.0">
    <assemblyIdentity type="win32" name="avisynth.dgindex" version="1.0.0.0"/>
    <application xmlns="urn:schemas-microsoft-com:asm.v3">
        <windowsSettings>
            <longPathAware xmlns="http://schemas.microsoft.com/SMI/2016/WindowsSettings">true</longPathAware>
            <activeCodePage xmlns="http://schemas.microsoft.com/SMI/2019/WindowsSettings">UTF-8</activeCodePage>
        </windowsSettings>
    </application>
</assembly>
In my test this worked fine. Even though not all characters may display correctly in the GUI, the input file was opened and the output file was generated without problem:
https://i.imgur.com/n3DokZn.png
Old 3rd January 2021, 01:32   #6  |  Link
lansing
        <windowsSettings>
        </windowsSettings>
    </application>
</assembly>
I tried it on my dgindex, it doesn't work with Japanese. It just crashed like before the modification.
おめでたい
Old 3rd January 2021, 02:00   #7  |  Link
LoRd_MuldeR
Software Developer
Seems to work for me:
https://i.imgur.com/CKrFHaA.png
Sure the manifest was patched correctly? And you are on Windows 10 version 1903 (May 2019 Update) or later, right?
FWIW, here is "my" patched DGIndex binary:
https://easyupload.io/zp2sjx
Old 3rd January 2021, 03:02   #8  |  Link
lansing
I am using Windows 10 version 2004. Your mod worked. How do you save it? I opened the exe -> edit the manifest -> compile script -> save.
Old 3rd January 2021, 03:35   #9  |  Link
LoRd_MuldeR
Software Developer
So did I
(Be aware through, that if the EXE is located in "C:\Program Files" or "C:\Program Files (x86)", then Resource Hacker may not have write access, unless it was launched with "run as administrator" option)
Old 3rd January 2021, 06:06   #10  |  Link
lansing
So did I
Thanks I finally got mine working, don't know why it doesn't the first time. I copied the <application> tag into my manifest and dgindexNV also working now.
Old 3rd January 2021, 09:26   #11  |  Link
lansing
I encountered another problem, seems like dgdecodenv.dll couldn't read unicode as well, DGSource couldn't read the unicode file path in my vapoursynth script, and then it couldn't read the file path in the dgi file also. Modifying the manifest for the dll didn't help.
Old 3rd January 2021, 15:07   #12  |  Link
stax76
stax76's Avatar
Only staxrip, x264 and mpv.net use a UTF-8 manifest, since a week. But you can enable UTF-8 support system wide in the administrative language settings of Windows 10 v1903.
Old 3rd January 2021, 16:27   #13  |  Link
LoRd_MuldeR
Software Developer
Things like "long path" awareness and the ANSI codepage are per-process settings. You'd have to set that in the manifest of the "main" EXE file. TTBOMK, you cannot do it for individual DLLs.
BTW: Windows has been supporting the "Unicode" (UTF-16) API ever since Windows 2000. So any application/library written in the past ~20 years should actually be using the "Unicode" (UTF-16) API – instead of the old "ANSI" API – and thus should not need to be concerned with ANSI codepages at all. The whole idea of enforcing a certain codepage via manifest is just a workaround for "legacy" code. The "proper" fix is updating the code to the modern "Unicode" (UTF-16) API.
Old 3rd January 2021, 16:53   #14  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Interesting, good to know.
"Data reduction ? Yep, Sir. We're working on that issue. Synce invntoin uf lingöage..."
Old 7th January 2021, 22:53   #15  |  Link
videoh
Useful n00b
Currently, Unicode is not supported, but you should be able to achieve the desired result by appropriately setting your system locale. If not, let me know. Probably something can be done about it.
Old 8th January 2021, 07:14   #16  |  Link
lansing
Changing system locale is a Windows XP thing. DGIndexNV works now with manifest mod, it's just that it's doesn't work for DGDecodeNV.
Old 8th January 2021, 11:25   #17  |  Link
videoh
Useful n00b
No.
https://www.isunshare.com/windows-10...indows-10.html
Try the system locale.
Old 8th January 2021, 18:34   #18  |  Link
lansing
Nobody should be changing their system locale just to run a non unicode program because it's very annoying, it requires a system reboot every time you changed it while the keyboard were also changed. That's why there was AppLocale back in the XP days.
Old 8th January 2021, 20:55   #19  |  Link
videoh
Useful n00b
AppLocale still works for Win10:
https://github.com/xupefei/Locale-Emulator
Is that working for you?
Old 8th January 2021, 21:57   #20  |  Link
lansing
This one only supports 32 bit program, all my programs are 64 bit.
