16th May 2012, 17:37 | #7461 | Link | |
NY Frame of Mind
Btw, I just drag and drop files into the "input" box of tsmuxer. If you use the "add" button, be sure change the "Files of type" to "all files (*.*)" in the "Add Media Files" dialog box.
"Talk to me Goose" Last edited by rapscallion; 16th May 2012 at 18:15. |
18th May 2012, 16:08 | #7463 | Link |
Great program! I need some help, PLEASE!
I am trying to burn home movies from AVCHD camcorder to AVCHD disc to play on blu ray player with dvd-r (or dvd+r). The movies play fine but I am trying to get sliding static menus to work. When the menu is on the first item of the sliding menu it looks great, you can see the poster which I hand selected from the video and used the "poster" button to select. You can also see the next few posters after as you should with a sliding menu. When I press the right arrow to go to the next movie on the menu (total of 19 short 3-5 minute movies), all I get is a black screen with only the blue selector arrow (presumably at the "play" button) shown. The "play", "chapters" buttons are not seen. Same if I go on to the next movie to the right. If I go back to the first movie, i see everything again. A little history. I have done this before about 2 years ago. i remember having similar issue but eventually i resolved it somehow. i still have a disc from back then to prove it, and works perfectly on this blu ray player. Since that time, i am sure I have messed with ffdshow settings for other things. I think that is what the problem is. here is what i have tried: In FFDSHOW, i have set h.264/avc to libavcodec and MPEG2 to libmpeg2...still happens. I have changed h.264/avc to ffmpeg-mt, leaving mpeg2 alone, still same problem. i am burning with AVCHD strict by the way. Also, is there a way to test the results on the PC without burning it to disc? What software can play the AVCHD folder structure with menus? i tried POWERDVD Ultra that can play HD DVD and no success. Lastly, when previewing menus, i don't see any of the pictuyres, just a blue poster with the word multiAVCHD on it. Can i use this as an indicator as to whether it will work or not, or is it the way it is suppose to be? |
28th May 2012, 10:58 | #7464 | Link |
after ive inserting succesfuly subtitle in 15-20 blu-rays using multiAVCHD, im experiencing this issue , "some" is "contracting" the length of the movie, with aproximatly 4%, everythings still syncronised (subs, audio) just the chapters are messed-up, and also the size of the output file is with the same aprox 4% smaller!!!
so, the movie still complet, but the duration and the size are shorter/smaller. some ideas pls? thx |
30th May 2012, 08:20 | #7466 | Link |
Why multiAVCHD creates exactly 55 entries in a playlist for a menu?
It struck me this when I was trying to "shorten" the duration of the menu, before it looped. Actually I put a 6-7 seconds long song as the background sound, yet the produced menu was 33 seconds long.
Born in the USB (not USA) |
2nd June 2012, 22:49 | #7467 | Link |
NY Frame of Mind
I reauthored a retail BD of Rambo First Blood, and the resulting movie stutters. Did it twicw to confirm.
This is what I did, and have done for many others without a problem: 1. Blanked the previews 2. Blanked the FBI warnings 3. Blanked the commentary disclaimer 4. Made the DTS-HRA the default audio track ( Dolby is in the original) by moving it "up' one position in the properties dialog. Any thoughts why the reauthor is screwing up playback (both in TMT and Power DVD) Edit: Tried it with Clown BD copier with the same result, so there's something in this disc that doesn't like reauthoring. Oh well.
"Talk to me Goose" Last edited by rapscallion; 2nd June 2012 at 23:14. |
4th June 2012, 15:51 | #7470 | Link |
NY Frame of Mind
Thanks for the suggestions guys. No, I haven't tried either of those.
I believe neither program can change the default audio, but I'm not sure. Will take a look at them again.
"Talk to me Goose" |
4th June 2012, 16:20 | #7471 | Link | |
BD-RB will let you blank audio but not change it's order. However, if you were to only keep the HD audio, instead of the DD 2.0 or DD 5.1 if the main title has one of those as the first audio, and perhaps keep other directors commentary tracks, it will change the order then. Another option that might work is to use multiAVCHD in "Re-author" mode, go to the main title's available audio, delete them and then add back external audio in the order you wish. The movies audio menu page may not be accurate though! |
4th June 2012, 16:34 | #7472 | Link | |
NY Frame of Mind
Same with blanking previews, warnings, etc. Multiavchd has always processed the mpls and clpi correctly. In the properties dialopg box is where, in the audio tab, the audio tracks are displayed. There're "up" and "down" buttons to the right. Multiavchd uses that to process the mpls and clpi accordingly.
4th June 2012, 16:53 | #7474 | Link | |
I usually use BD-RB first, then multiAVCHD to blank warnings since I am unable to "see" the warnings with BD-RB to blank them. |
7th June 2012, 23:46 | #7475 | Link |
Subtile SRT problem
Guys,
I'm having a subtitle problem, hope you guys can give some insight. I'm using MultiAVCHD 4.1, on Win 7. I have a French substitle srt file that I can view correctly on Notepad, with all the accents displayed correctly in Arial font. In fact, I can see SRT text in any language with no problem using Arial font, using Notepad. When I authored DVD or Blu-ray disk, this subtile file was not converted correctly, all text were displayed in weird graphics. I know it's an indicator of a Unicode display problem. Questions: does MultiAVCHD use the default Windows Arial font, or does it have its own font emmbeded? could that be the problem? I used GoSub and EasySub (from the MultiAVCHD directory) to convert it separately, but the output showed the same problem. BTW, GoSub and EasySub don't have preview window any more, so I can't test the conversion in advance. Is there a version for either GoSub or EasySub out there that shows preview? TIA Last edited by bodhi78; 7th June 2012 at 23:53. |
8th June 2012, 02:40 | #7476 | Link |
Quality Freak
Multiavchd is giving me the error "Avsrecursion is missing from your system".
Problem is, I already have Avsrecursion in my System folder. Any thoughts? It also won't give me any video preview at all: http://i45.tinypic.com/zt9k0n.jpg |
14th June 2012, 23:18 | #7477 | Link |
Hey guys, I've got a question about creating menus. So for example, I've got a TV show that I'm making a BD of, that has anywhere from 13 to 24 or so episodes in total.
SO what my issue is, is that when I make a menu, usually set on static, flipping through the episode is a huge pain in the ass. I basically have to wait each time for it to flash/load a new screen that has the next episode in the list. Can anyone tell me how I'd go about setting it up so that the scrolling is animated, so that it's not loading screen after screen just to sort through the episode lists? Any help would be greatly appreciated. Thanks! |
15th June 2012, 08:22 | #7479 | Link | |
Yes, it doesn't solve the problem, the only solution is to add manually videos that fade from one page to another, and change the navigation by hand. That means you'll get used to the flip/flop pages , at least until you change the player .
15th June 2012, 09:50 | #7480 | Link | |
You can see if MKV's header is compressed or not with MediaInfo : if you see "header stripping" in the video characteristics, it means that header is compressed. Last edited by Music Fan; 15th June 2012 at 09:59. |
