18th May 2009, 01:28 | #4901 | Link |
Hi Atak,
I know your releasing a new version soon. I was wondering if it was going to allow to keep a HD audio without conversion for BD-R. Your program is the best and fastest and really only needs that (with newest TSMUXER) to be near perfect for most needs. |
18th May 2009, 14:25 | #4903 | Link | |
19th May 2009, 01:50 | #4904 | Link |
I would like this feature too, great as MKV now supports HD audio tracks (via mkvtoolnix), and, i will be buying a Dune prime which reads HD audio tracks within MKV containers. (if you plan on adding this option for both BD output as well as MKV output)
19th May 2009, 05:49 | #4905 | Link | |
Is this setting good for anime for PS3
19th May 2009, 11:44 | #4906 | Link |
Feature Request
Aside from being able to add the HD audio others have mentioned:
- Ability to add multiple audio tracks - Ability to mux to mkv/ts/m2ts without encoding. I currently use MakeMKV and/or Clown_BD for my Blu Ray/HD DVDs that I don't want to encode. Since Ripbot264 demuxes the file anyhow, it would be nice to use ripbot264 as a one stop shop. |
19th May 2009, 12:07 | #4907 | Link | |
I dont care so should you
Plus as you mentioned you can use those other tools to get what you want... HD Aud might be an option *Don't Know* but the multiple audio track and demux/remux ideas are things that were not addressed the last time they were mentioned because your taking and trying to get titanic luxury out of a tug boat. It wont happen. MeGUI is the best titanic multipurpose app on these forums and tries its best to include every tool to help in all encoding circomstances. It might be a better fit you and others. ~DarC
My Installer's || Last edited by Ajax_Undone; 19th May 2009 at 12:13. |
19th May 2009, 12:41 | #4908 | Link | |
Cheers, Damian Blog - http://www.adigitalhomeblog.com MSS.net blog (contributing editor) - http://www.mediasmartserver.net |
19th May 2009, 16:13 | #4910 | Link |
HDConvertToX author
[SPAM]or HDConvertToX, it support multiple audio and multiple subs.. [/SPAM]
BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
20th May 2009, 13:35 | #4912 | Link |
I have 2 problems:
1. If I choose the Denoise option to FILM, Ripbot does not encode the movie. Moreover, I can't choose better audio quality (192kbps or 256 kbps). Why and how? 2. mkvtoolnix released version 2.8.0. I downloaded and extracted 7z file to replace all the files in folder \RipBot264v1.13.3\Tools\mkvtoolnix. Is it ok? |
20th May 2009, 13:45 | #4913 | Link |
1. Install latest DirectX, 128kbps is enough
2. yes
20th May 2009, 13:52 | #4914 | Link |
Thank you for your quick reply. I have just installed Windows Vista Enterprise SP1 with DirectX 10. I think it is the latest version, right?
I want to rip HD music video clips so I need a bit higher audio quality. Is it possible? Last edited by jindo; 20th May 2009 at 13:55. |
20th May 2009, 13:54 | #4915 | Link |
20th May 2009, 14:23 | #4917 | Link |
Hey Atak,
I've noticed a new strange bit of behaviour, the first time I go to transcode an h264 mp4 from VOB's ripbot will skip the video encoding step after it finishes the audio, mux into an mp4 and announce everything is complete. However the next time I run the same project (and any others in the queue) it completes perfectly. Is this common? I have never used it for VOBs before now v1.13.3
Q6600 @ 3.2Ghz -Asus P5Q-Pro 4Gb DD2, GTX260 core 216 Win 7 64bit Home Premium |
20th May 2009, 18:19 | #4918 | Link | |
20th May 2009, 18:59 | #4919 | Link |
Problems in Vista and XP - Logfiles Included
I'm trying to use v1.13.3. I have a Vista partition and an XP partition. I installed Ripbot264 on both.
On the Vista partition, RB started, indicated I had all the necessary subprograms it requires. AnyDVD HD was running. I put in a Blu-ray disc, RB analyzed, and I selected the largest .mt2 file for processing. Then nothing happened at all. It wouldn't do a thing - extraction never started. In XP, did all of the above, and extraction was successful, but right after extraction got to 100% Media Player Classic popped up with the error message: "DirectShowSource: Couldn't open file c:\temp\ripbot264temp\job1\video.mkv An object or name was not found (\Job1\Getinfo.avs, line 2)" Getinfo.avs says this: [blank line] DirectShowSource("C:\temp\RipBot264temp\job1\video.mkv",audio=false).ConvertToYV12() WriteFile("C:\temp\RipBot264temp\job1\info.txt","Framecount") WriteFile("C:\temp\RipBot264temp\job1\info.txt","Framerate") WriteFile("C:\temp\RipBot264temp\job1\info.txt","AudioRate") WriteFile("C:\temp\RipBot264temp\job1\info.txt","AudioChannels") WriteFile("C:\temp\RipBot264temp\job1\info.txt","AudioLength") WriteFile("C:\temp\RipBot264temp\job1\info.txt","Width") WriteFile("C:\temp\RipBot264temp\job1\info.txt","Height ") Trim(0,-1) MKVInfo.txt says this: Error: The source file 'C:\temp\RipBot264temp\job1\video.mkv' could not be opened successfully, or retrieving its size by seeking to the end did not work. Video - Log.txt says this: eac3to v3.12 command line: "C:\Program Files\RipBot 264\Tools\eac3to\eac3to.exe" "C:\TEMP\52918285_MAD_MAX_2\" 1) 2: "C:\temp\RipBot264temp\job1\video.mkv" -seekToIFrames 3: "C:\temp\RipBot264temp\job1\audio.1.ac3" 7: "C:\temp\RipBot264temp\job1\subtitle.1.sup" 1: "C:\temp\RipBot264temp\job1\chapters.txt" -progressnumbers ------------------------------------------------------------------------------ M2TS, 1 video track, 4 audio tracks, 4 subtitle tracks, 1:35:30, 24p /1.001 1: Chapters, 33 chapters 2: VC-1, 1080p24 /1.001 (16:9) 3: AC3, English, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB 4: AC3 Surround, French, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB 5: AC3, Spanish, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB 6: AC3, English, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB 7: Subtitle (PGS), English 8: Subtitle (PGS), English 9: Subtitle (PGS), French 10: Subtitle (PGS), Spanish Creating file "C:\temp\RipBot264temp\job1\chapters.txt"... [v02] Extracting video track number 2... [s07] Extracting subtitle track number 7... [a03] Extracting audio track number 3... [a03] Removing AC3 dialog normalization... [v02] Muxing video to Matroska... [v02] Getting "Haali Matroska Muxer" instance failed. <ERROR> Aborted at file position 1048576. <ERROR> The same thing happened with multiple discs, both when ripping directly from the disc, and also after ripping the disc to my hard drive with AnyDVD HD and pointing RB at that directory. Anyone have any ideas why this is happening? |
21st May 2009, 04:45 | #4920 | Link |
I have a bit of a noob question i have TS MPEG2 file that is 1920 x 1080i, 29.970 fps, 14 Mbps.When i encoded to avchd using ripbot,playback picture was moving too fast and audio was way out of sync.Can anyone tell me the correct settings for this type of file?Also i had a 720p mkv file that was 10gb but when i encoded it to avchd after ticking the 8150 tab output size was 12.2gb can anyone help with this also.Any info would be great.
