21st November 2006, 13:31 | #141 | Link |
Professional Lemming
There is even more to test: The latest beta5 series of ELDER contains x264 modes. I'll integrate a keyframe accurate 2pass mode soon.
Oh, and there is a fancy GUI as well bis besser, T0B1A5
projects page: ELDER, SmoothD, etc. |
6th December 2006, 08:33 | #142 | Link |
i have an issue with the import() function within the made up avs scripts
import("default.avs") is all it loads in and not the path to the avs? so it doesnt find the script and exits. so my stageA-0.avs has: import("default.avs") trim(0,15370) my cmd log is below: C:\ELDER>perl ELDER4X264_start.pl -a default.avs -o ELDER.mp4 -p "-b 2 -r 1 -m 4 " -q "-b 2 -r 5 -m 4" The system cannot find the file specified. ### encode job 363586 set up successfully ### starting encode now C:\ELDER>perl -w ELDER4X264_acrf.pl -t 363586 -a default.avs -o ELDER.mp4 -p -b 2 -r 1 -m 4 -q -b 2 -r 5 -m 4 detected fps = 59.94 detected frames = 122958 using 4 threads to encode 8 chunks with about 15370 frames each. Total size will be 525146 bytes. ### starting process 0 ### starting process 1 ### starting process 2 ### starting process 3 ### stage A issued C:\ELDER>perl -w ELDER4X264_c2.pl 363586 ####### Stage A Progress: 1/8 chunks done (12%) ####### ####### Stage A Progress: 2/8 chunks done (25%) ####### ####### Stage A Progress: 3/8 chunks done (37%) ####### ####### Stage A Progress: 4/8 chunks done (50%) ####### ####### Stage A Progress: 5/8 chunks done (62%) ####### ####### Stage A Progress: 6/8 chunks done (75%) ####### ####### Stage A Progress: 7/8 chunks done (87%) ####### ####### Stage A Progress: 8/8 chunks done (100%) ####### ### Stage A completed ### Stage C generating jobs Illegal division by zero at ELDER4X264_c2.pl line 52. C:\ELDER>perl -w ELDER4X264_d.pl 363586 i looked at that line and it has this: $chunktarget = ($totalbytes * $chunksizes[$i]) / $total_chunksize; then my head exploded... Last edited by woah!; 6th December 2006 at 08:42. |
6th December 2006, 15:40 | #144 | Link |
Wow! Nice.
I decided to include x264 2pass into beta5 in one of the next releases. bis besser, T0B1A5
7th December 2006, 02:46 | #145 | Link |
its doing 2pass ok right now for me?
i added some default x264 settings to your ELDER4X264_acrf.pl and it is works great with all the settings i need at 210fps total on the 1pass for this setup at 448x336 reizing. seems i have found my tool of choice thank you heres the 2pass result of 80fps total: rate control seems good aswell. Last edited by woah!; 7th December 2006 at 03:03. |
7th December 2006, 11:32 | #146 | Link | |
OTOH there were vague plans to include it into the beta5 and 6 branch again (and even better ) with a GUI, better rate control, pause/resume feature. I decided a week ago to actually _do_ that. So you could already try to get beta5 working on your setup since I'll add x264 2pass real soon bis besser, T0B1A5
10th December 2006, 00:02 | #147 | Link | |
12th December 2006, 23:57 | #148 | Link |
Any chance to have a theora/dirac(and, why not, snow)-enabled version ?
Those codecs needs this power !
HYbrid Multimedia Production Suite project @ GitHub |
13th December 2006, 15:59 | #149 | Link |
I experimented with theora already. The missing part is the muxing.
15th December 2006, 14:49 | #150 | Link |
beta5f reunites x264 2pass with the main branch. See first post for a download link.
Enjoy the GUI PS: x264 3pass and theora encoding will come soon (in beta6). bis besser, T0B1A5
24th January 2007, 11:37 | #151 | Link |
Just a question is it open source ?
If so, i hope to see some kind of collaboration with MediaCoder that is planning a distributed encoding support.
24th January 2007, 12:47 | #152 | Link | |
I've been busy inventing my very own codec lately so I didn't spend much time on ELDER. Of course it would be good to see ELDER integrated into GUIs/frameworks since the GUI I provide is rudimentary at best. bis besser, T0B1A5
19th February 2007, 10:21 | #153 | Link |
I'm having trouble getting this to work. All I get is this:
using 2 threads to encode 1 chunks of about 0 frames warning: less chunks than available threads! Illegal division by zero at functions.pl line 334. collecting stage A results ( chunks in total) stage A import done stage B jobs issued collecting stage B results (-1 chunks in total) stage B completed stage B imported 1st pass fps = 0 Modification of non-creatable array value attempted, subscript -1 at functions.p l line 565. collecting Stage C1 results ( chunks in total) Stage C generating jobs stage C jobs issued collecting stage C results ( chunks in total) stage C completed 2nd pass fps = 0 total time for encoding: 1171876680 seconds overall fps = 0 now merging the chunks... invalid suffix. using .mp4 instead. "2>" ist syntaktisch an dieser Stelle nicht verarbeitbar. chunks merged Illegal division by zero at functions.pl line 937. |
25th April 2007, 19:21 | #154 | Link |
Dear ELDER gurus,
sorry but I do have the same problem. This is the default.avs script: AviSource("e:\elder\e.avi") ConvertToYV12() And this is the command prompt used to star encoding: perl functions.pl xvid -a e:\elder\default.avs -m 4 -b 800 -c 64 -o e:\elder\blafu.mp4 Then start with control.bat The result is: using 4 threads to encode 1 chunks of about 0 frames warning: less chunks than available threads! Illegal division by zero at functions.pl line 334. collecting stage A results ( chunks in total) stage A import done stage B jobs issued collecting stage B results (-1 chunks in total) stage B completed stage B imported 1st pass fps = 0 Modification of non-creatable array value attempted, subscript -1 at functions.p l line 458. collecting stage C results ( chunks in total) stage C completed 2nd pass fps = 0 total time for encoding: 1177524182 seconds overall fps = 0 now merging the chunks... invalid suffix. using .mp4 instead. "2>" ist syntaktisch an dieser Stelle nicht verarbeitbar. chunks merged Illegal division by zero at functions.pl line 937. What am I missing? Thanks a lot and best regards Andrea |
26th April 2007, 13:27 | #155 | Link | |
I did not do anything on ELDER the past half a year but I do have an unfinished version of a new detection algorithm. I'll see what I can do but the weather is just too good bis besser, T0B1A5
26th April 2007, 13:29 | #156 | Link |
I somehow missed that post. But the reply is the same as to the other poster.
18th June 2007, 11:30 | #158 | Link |
Still the same reason as most of you guys have: The video length is detected as 0 frames! To help you guys I will package my incomplete rewrite of the detection. ETA is about a week so hang on
bis besser, T0B1A5
29th June 2007, 15:02 | #159 | Link | |
Here is a intermediate version where -f should be handled well but -s and -b are broken! It's not a trade-off, just a bug that happens when you look at code just once in several months for a couple of minutes I'll announce the link in the first post of this thread when I put it online. Have phun. bis besser, T0B1A5
1st August 2007, 11:54 | #160 | Link |
I luv elder, but
708145, your tool is great. ver.5 worked for me for xivd 2 pass and x264 crf pass (no gui selectable 2pass). I couldn't get 6 to work at all via gui or cmd line. So i hacked ver 6's additional passes into 5 . I've only tested xvid2pass, x264crf & x264 2pass they all work well for me. Are you still active on development? How many cores can elder support before gains become irrelevant.
I not a coder so I don't understand why you changed the frame detection portion of you code if it already works... Thanks again for the great tool J |
