23rd September 2019, 07:48 | #3542 | Link | |
Another link to be updated: https://github.com/woshin/hnwvsfunc Last edited by LigH; 23rd September 2019 at 07:51. |
23rd September 2019, 08:39 | #3543 | Link | |
28th September 2019, 15:13 | #3544 | Link |
Hello.
I'm trying to compile vapoursynth in ubuntu 18.04. First I installed development packages for libav*, iconv, pango, freetype, fonconfig, tesseract and another libraries. I downloaded, compiled and installed zimg v2.9 branch and ImageMagick 7. Then when compiling vapoursynth I get this error: Code:
CXXLD libvapoursynth.la /usr/bin/ld: ./.libs/libexprfilter.a(libexprfilter_la-exprfilter.o): relocation R_X86_64_PC32 against undefined symbol `_ZN12_GLOBAL__N_115ExprCompiler1289constDataE' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: final link failed: Bad value collect2: error: ld returned 1 exit status Makefile:1166: recipe for target 'libvapoursynth.la' failed make: *** [libvapoursynth.la] Error 1 Thank you. I've tried passing --enable-shared --disable-static --with-pic to configure without success. The configure output is: Code:
checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for a thread-safe mkdir -p... /bin/mkdir -p checking for gawk... gawk checking whether make sets $(MAKE)... yes checking whether make supports nested variables... yes checking whether make supports nested variables... (cached) yes checking build system type... x86_64-pc-linux-gnu checking host system type... x86_64-pc-linux-gnu checking how to print strings... printf checking for style of include used by make... GNU checking for gcc... gcc checking whether the C compiler works... yes checking for C compiler default output file name... a.out checking for suffix of executables... checking whether we are cross compiling... no checking for suffix of object files... o checking whether we are using the GNU C compiler... yes checking whether gcc accepts -g... yes checking for gcc option to accept ISO C89... none needed checking whether gcc understands -c and -o together... yes checking dependency style of gcc... gcc3 checking for a sed that does not truncate output... /bin/sed checking for grep that handles long lines and -e... /bin/grep checking for egrep... /bin/grep -E checking for fgrep... /bin/grep -F checking for ld used by gcc... /usr/bin/ld checking if the linker (/usr/bin/ld) is GNU ld... yes checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B checking the name lister (/usr/bin/nm -B) interface... BSD nm checking whether ln -s works... yes checking the maximum length of command line arguments... 1572864 checking how to convert x86_64-pc-linux-gnu file names to x86_64-pc-linux-gnu format... func_convert_file_noop checking how to convert x86_64-pc-linux-gnu file names to toolchain format... func_convert_file_noop checking for /usr/bin/ld option to reload object files... -r checking for objdump... objdump checking how to recognize dependent libraries... pass_all checking for dlltool... no checking how to associate runtime and link libraries... printf %s\n checking for ar... ar checking for archiver @FILE support... @ checking for strip... strip checking for ranlib... ranlib checking command to parse /usr/bin/nm -B output from gcc object... ok checking for sysroot... no checking for a working dd... /bin/dd checking how to truncate binary pipes... /bin/dd bs=4096 count=1 checking for mt... mt checking if mt is a manifest tool... no checking how to run the C preprocessor... gcc -E checking for ANSI C header files... yes checking for sys/types.h... yes checking for sys/stat.h... yes checking for stdlib.h... yes checking for string.h... yes checking for memory.h... yes checking for strings.h... yes checking for inttypes.h... yes checking for stdint.h... yes checking for unistd.h... yes checking for dlfcn.h... yes checking for objdir... .libs checking if gcc supports -fno-rtti -fno-exceptions... no checking for gcc option to produce PIC... -fPIC -DPIC checking if gcc PIC flag -fPIC -DPIC works... yes checking if gcc static flag -static works... yes checking if gcc supports -c -o file.o... yes checking if gcc supports -c -o file.o... (cached) yes checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes checking whether -lc should be explicitly linked in... no checking dynamic linker characteristics... GNU/Linux ld.so checking how to hardcode library paths into programs... immediate checking whether stripping libraries is possible... yes checking if libtool supports shared libraries... yes checking whether to build shared libraries... yes checking whether to build static libraries... yes checking for gcc... (cached) gcc checking whether we are using the GNU C compiler... (cached) yes checking whether gcc accepts -g... (cached) yes checking for gcc option to accept ISO C89... (cached) none needed checking whether gcc understands -c and -o together... (cached) yes checking dependency style of gcc... (cached) gcc3 checking for g++... g++ checking whether we are using the GNU C++ compiler... yes checking whether g++ accepts -g... yes checking dependency style of g++... gcc3 checking how to run the C++ preprocessor... g++ -E checking for ld used by g++... /usr/bin/ld -m elf_x86_64 checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes checking for g++ option to produce PIC... -fPIC -DPIC checking if g++ PIC flag -fPIC -DPIC works... yes checking if g++ static flag -static works... yes checking if g++ supports -c -o file.o... yes checking if g++ supports -c -o file.o... (cached) yes checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes checking dynamic linker characteristics... (cached) GNU/Linux ld.so checking how to hardcode library paths into programs... immediate checking for special C compiler options needed for large files... no checking for _FILE_OFFSET_BITS value needed for large files... no checking for _LARGEFILE_SOURCE value needed for large files... no checking for pkg-config... /usr/bin/pkg-config checking pkg-config is at least version 0.9.0... yes checking for ZIMG... yes checking for library containing dlopen... -ldl checking for sched_getaffinity... yes checking for cpuset_getaffinity... no checking for a Python interpreter with version >= 3... python3 checking for python3... /usr/bin/python3 checking for python3 version... 3.6 checking for python3 platform... linux checking for python3 script directory... ${prefix}/lib/python3.6/site-packages checking for python3 extension module directory... ${exec_prefix}/lib/python3.6/site-packages checking for PYTHON3... yes checking for cython3... cython3 checking iconv.h usability... yes checking iconv.h presence... yes checking for iconv.h... yes checking for library containing libiconv_open... no checking for library containing iconv_open... none required checking for LIBASS... yes checking for FFMPEG... yes checking for IMAGEMAGICK... yes checking whether imagemagick is usable... yes checking for TESSERACT... yes checking that generated files are newer than configure... done configure: creating ./config.status config.status: creating pc/vapoursynth.pc config.status: creating pc/vapoursynth-script.pc config.status: creating Makefile config.status: executing depfiles commands config.status: executing libtool commands |
28th September 2019, 18:38 | #3545 | Link |
Autotools build system is broken in current master, use 47.2 release for now.
EDIT: Now that I remember, the you only need to pass -std=c++17 to your CXXFLAGS to make it compile. Last edited by Are_; 28th September 2019 at 19:02. |
29th September 2019, 10:02 | #3546 | Link | |
CYTHON src/cython/vapoursynth.c Error compiling Cython file: ------------------------------------------------------------ ... # If we are not using VSScript, do nothing. if self.single: return _environment_state.current = _env_current_stack().pop() def __eq__(self, other): ^ ------------------------------------------------------------ src/cython/vapoursynth.pyx:133:4: Special method __eq__ must be implemented via __richcmp__ Error compiling Cython file: ------------------------------------------------------------ ... core = kwargs.pop("core", None) or get_core() vals = self._as_dict() vals.update(**kwargs) return core.register_format(**vals) def __eq__(self, other): ^ ------------------------------------------------------------ src/cython/vapoursynth.pyx:710:4: Special method __eq__ must be implemented via __richcmp__ Makefile:2217: recipe for target 'src/cython/vapoursynth.c' failed make: *** [src/cython/vapoursynth.c] Error 1 Code:
def __eq__(self, other): {BODY} Code:
def __richcmp__(self, other, op): if op == 2: {BODY} else: err_msg = "op {0} isn't implemented yet".format(op) raise NotImplementedError(err_msg) Last edited by patxitron; 29th September 2019 at 10:21. |
29th September 2019, 17:55 | #3547 | Link | ||
http://vapoursynth.com/doc/installat...n-instructions:
2nd October 2019, 15:34 | #3548 | Link |
MaskedMerge bug in R47 ?
Overlay issue See post 486 and the replies. Works in R46 https://forum.doom9.org/showpost.php...&postcount=486 https://forum.doom9.org/showthread.php?p=1886366 |
2nd October 2019, 17:16 | #3549 | Link | |
Professional Code Monkey
3rd October 2019, 22:01 | #3551 | Link |
R48-test1 64bit
Changes: Code:
r48: it's now possible to select which optimized code path is used for internal filters (sekrit-twc) avx2 optimization in many filters, previously the internal ones were mostly sse2 (sekrit-twc) expr filter can now better optimize expressions (sekrit-twc) the portable version now includes all the plugins bundled with the normal installer again Btw, official audio support is probably coming soon as well.
4th October 2019, 03:49 | #3554 | Link |
The cult of personality
I have this problem: https://imgur.com/a/76QEOYb
My system is windows 10 pro x64 with vapoursynth x64 the 47.2 version (latest from website). Seems like Tcanny and EEDI3 can't be loaded for some reason. |
4th October 2019, 11:11 | #3555 | Link |
Here is the log:
/!\ Only Plugins and no Scripts are tested /!\ VapourSynth Video Processing Library Copyright (c) 2012-2019 Fredrik Mellbin Core R47 API R3.6 Options: - OS: Microsoft Windows 10 Pro Is 64Bit OS?: True CPU: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz CPU Cores: 8 Python location: C:\python37\python.exe Loaded VapourSynth dll: C:\python37\lib\site-packages\vapoursynth.dll Found an installation in HKEY_LOCAL_MACHINE\SOFTWARE\VapourSynth - Path: C:\Program Files\VapourSynth - PythonPath: C:\python37\ - Version: R47.2 ============================================================ Checked Plugins: 54, Notices: 5, Errors: 2 Plugin Paths: • C:\Users\hossa\AppData\Roaming\VapourSynth\plugins64 • C:\Program Files\VapourSynth\plugins 🔥 Error unknown: ------------------------------------------------------------ C:\Users\hossa\AppData\Roaming\VapourSynth\plugins64\EEDI3m.dll C:\Users\hossa\AppData\Roaming\VapourSynth\plugins64\TCanny.dll 🤨 Unidentified DLLs (maybe also Plugin dependencies?): ------------------------------------------------------------ C:\Users\hossa\AppData\Roaming\VapourSynth\plugins64\cudart64_80.dll C:\Users\hossa\AppData\Roaming\VapourSynth\plugins64\libfftw3-3.dll C:\Users\hossa\AppData\Roaming\VapourSynth\plugins64\libfftw3f-3.dll C:\Users\hossa\AppData\Roaming\VapourSynth\plugins64\libmfxsw64.dll C:\Users\hossa\AppData\Roaming\VapourSynth\plugins64\w2xc.dll 👍 Successfully loaded Plugins: ------------------------------------------------------------ AddGrain.dll Bilateral.dll BM3D.dll CTMF.dll d2vsource.dll DCTFilter.dll Deblock.dll DFTTest.dll DGMVCSourceVS.dll EdgeFixer.dll EEDI2.dll ffms2.dll fft3dfilter.dll FFTSpectrum.dll flash3kyuu_deband.dll fmtconv.dll KNLMeansCL.dll libawarpsharp2.dll libbifrost.dll libdecross.dll libdescale.dll libfluxsmooth.dll libhqdn3d.dll libmedian.dll libmsmoosh.dll libmvtools.dll libmvtools_sf_em64t.dll libnnedi3.dll libsangnom.dll libtcomb.dll libtedgemask.dll LSMASHSource.dll NNEDI3CL.dll Retinex.dll RGSF_x64.dll TColorMask.dll TDeintMod.dll tonemap.dll TTempSmooth.dll vapoursynth-dpid.dll VSFilter.dll VSFilterMod.dll vslsmashsource.dll vsznedi3.dll Waifu2x-w2xc.dll xy-VSFilter.dll Yadifmod.dll |
4th October 2019, 11:33 | #3556 | Link | |
Are you using the integrated graphics card? you're probably missing the OpenCL dependency. https://software.intel.com/en-us/art...opencl-drivers
4th October 2019, 12:49 | #3557 | Link |
As for openCl, I installed the latest driver and still the same log file and errors appear.
Here is one of the messages: https://imgur.com/a/76QEOYb Problematic stuff is in Tcanny.dll and EEDI3m.dll Also, after updating the plugins and scripts... and using havfunc's aaf function, I get this: Code:
Failed to evaluate the script: Python exception: int() argument must be a string, a bytes-like object or a number, not 'list' Traceback (most recent call last): File "src\cython\vapoursynth.pyx", line 1946, in vapoursynth.vpy_evaluateScript File "src\cython\vapoursynth.pyx", line 1947, in vapoursynth.vpy_evaluateScript File ".....\ep02.vpy", line 21, in #aa = haf.aaf(grain) File ".....\Python\Python37\site-packages\havsfunc.py", line 5149, in aaf return core.rgvs.Repair(aa, inputClip, mode=[repMode]) File "src\cython\vapoursynth.pyx", line 1832, in vapoursynth.Function.__call__ File "src\cython\vapoursynth.pyx", line 648, in vapoursynth.typedDictToMap TypeError: int() argument must be a string, a bytes-like object or a number, not 'list' So I have these 2 problems. |
4th October 2019, 12:59 | #3558 | Link | |
checking for cython3... cython3 |
4th October 2019, 13:08 | #3559 | Link | |
python -c "import vapoursynth; c=vapoursynth.core; c.std.LoadPlugin(r'C:\Users\hossa\AppData\Roaming\VapourSynth\plugins64\EEDI3m.dll')" Code:
python -c "import vapoursynth; c=vapoursynth.core; c.std.LoadPlugin(r'C:\Users\hossa\AppData\Roaming\VapourSynth\plugins64\TCanny.dll')"
4th October 2019, 13:45 | #3560 | Link | |
Traceback (most recent call last): File "<string>", line 1, in <module> File "src\cython\vapoursynth.pyx", line 1852, in vapoursynth.Function.__call__ vapoursynth.Error: Failed to load C:\Users\hossa\AppData\Roaming\VapourSynth\plugins64\EEDI3m.dll. GetLastError() returned 127. |
speed, vaporware, vapoursynth |
