16th May 2008, 14:39 | #1941 | Link | |
Open the "Output" settings tab of MPC HC and search for a checkbox called "Direct3D Fullscreen (remove tearing)". This is the single best feature of MPC HC for me... |
16th May 2008, 14:45 | #1942 | Link | |
ffdshow/AviSynth wrangler
np: Styrofoam - By Anybody Else I Mean You (A Short Album About Murder)
now playing: [artist] - [track] ([album]) |
16th May 2008, 16:43 | #1943 | Link |
Anyone else having problems with h.264 STREAM and the INTERNAL decoder? The image starts as if I was looking at a chewed VHS tape, then it pixelates and it looks like a Picasso painting. The same happens in both XP (VMR9 and EVR) and Vista (EVR).
NOTE THAT h.264 files play flawlessly from my HDD. It is the stream that's messed up. ALSO, if I use Cyberlink h.264 as external filter, the stream WORKS great (in both Vista and XP). So it is either a bug or some settings that have to be adjusted. Anyone? |
17th May 2008, 00:42 | #1944 | Link |
to Cassimir666 - h264 stream check for DXVA ...
to Casimir666 :
In FfmpegContext.c do checking on ref frames: ... if (cur_sps->ref_frame_count > (1024*MAXDPB/((nWidth/16)*(nHeight/16)*384))) ... But this is only for Level 4.1, I suggest to change on if ((cur_sps->level_idc == 41) && (cur_sps->ref_frame_count > (1024*MAXDPB/((nWidth/16)*(nHeight/16)*384)))) and add check for level_idc<=41, because many rip is Level 5.1 and DXVA not work, I Have about 10 rip, where Level 5.1 and whan play - black screen and not play with DXVA and other question: #define MAXDPB 12288 // value for level 4.1 How to get MAXDPB for Level 3.1 ??? |
17th May 2008, 01:42 | #1945 | Link | |
Can you upload a stream which is problematic ? it is define in the annex A of the h264 standard. it is 6750 for level 3.1 |
17th May 2008, 03:21 | #1946 | Link | |
And how may know wich h264 with 5.1 level fine with DXVA ??? what parameters ??? number_of_refs ??? |
17th May 2008, 08:58 | #1947 | Link | |
I have Tearing with all Renderes (more or less) ,all Decoders/Formats. But only with DVI Port1 on a Samsung TFT 16:10 ( not caused by the TFT itself) Via VGA / 2nd DVI Port = no Tearing |
17th May 2008, 09:09 | #1948 | Link | |
MPC-HC Project Manager
Basically level5.1 in the header means the video is using a resolution higher than fullhd That also means that all files out there with level 5.1 in the header are wrong according to the standard, i have never seen a real level 5.1 file in my life, but i know they exist in japan as they have next generation hdtv's |
17th May 2008, 11:33 | #1949 | Link | |
17th May 2008, 13:09 | #1950 | Link |
Can anyone please compile a standalone mpcvideodec.ax video decoder filter. All my mkv files with subtitles crash mpc-hc when trying DXVA, and I'd like to try it from grapedit without the subtitles connecting.
17th May 2008, 16:47 | #1952 | Link | |
Subtitles synchronisation lost with VMR9/EVR
17th May 2008, 18:52 | #1953 | Link |
Something completely different.... Is there a way to keep the pan&scan setting persistent? I would like to play all my videos stretched to 16:9 but have to set it with every video file over again. I'm using the player with media portal and setting the stretch mode every time doesn't quite work well..
17th May 2008, 19:36 | #1954 | Link |
too much lurking
Windows doesn't recognize MPC-HC full screen as full screen when paused, so when it's paused the power saving settings (if in pace) will still shut the monitor off or engage the screen saver. This doesn't happen with every other version of MPC I have used.
17th May 2008, 19:39 | #1955 | Link |
People are not fat enough as it is ??
s/w: Vista Home Basic 32bit (no Aero), MPC-HC, EVR Custom Presenter, CoreAVC Pro, ffdshow, SPDIFer h/w: Antec 2480 case, Gigabyte GA-MA69GM-S2H, 4200+, 2.5gb+512mb, ATI x1250 IGP, MS MCE remote |
17th May 2008, 20:14 | #1956 | Link | |
-Playback of DXVA video content (all codecs, all resolutions) will sometimes lock up, a frame will keep repeating over and over, then the video continues like nothing happened. -MPC-HC will randomly delete the external filter settings in the .ini file. This last one seems to be fixed i'm not 100% sure yet, random macroblocking on DXVA content |
17th May 2008, 21:30 | #1957 | Link |
newbie
first of all i want to thank the developers of MPC - HC for making such an amazing program
finally my dream of playing HD videos on my ancient computer became a reality ! http://forum.doom9.org/showthread.php?t=136864 i just have a few questions to ask with xp sp3, ati HD 2600XT and using VMR9 Renderless i am able to play HD h264 videos profile 4.1 and lower with dxva enabled without any problems but for profile 5.1, it seems that only 720p videos work dxva doesn't seem to work with 1080p videos (hardware acceleration doesn't work) is this normal ? doesn't dxva support profile 5.1 h264 1080p videos ? |
17th May 2008, 21:54 | #1960 | Link | |
You are probably running into other issues such as non-mod16 height and/or width or more likely to many ref frames. Maybe this should be added to the startpage.... |
