Old 24th July 2019, 04:12   #1  |  Link
BassPig
BassPig's Avatar
Using Handbrake to Compress MKV - No Progress
I extracted the contents of a Blu-ray disc successfully with Make MKV.
The file is huge, so I read that Handbrake can compress it to a manageable size.
So I install Handbrake and try one of their presets, but the progress indicator never moves and the frame rate reads 0.00.
As far as I can tell, there's no published reason why it can't read MKV files, but maybe that doesn't mean it can.
What am I doing wrong? Is Handbrake incompatible with MKV source files?
Take care,
Mark & Mary Ann Weiss
www.mwhdvideo.com The Best in Video & Sound
www.ampexperts.com
www.basspig.com The Bass Pig's Lair - 20,000 Watts of Driving Stereo!
BassPig is offline   Reply With Quote
Old 24th July 2019, 07:29   #2  |  Link
sneaker_ger
HandBrake is compatible with most MKV files (it's based on ffmpeg so it can read a lot of different formats).
How long did you wait? It can take some time for the progress indicator to start. Also try a HandBrake nightly version. If it still doesn't work I would cut a short sample from the beginning using mkvtoolnix and if that doesn't process either send it to the developers (maybe test against ffmpeg).
Old 24th July 2019, 14:40   #3  |  Link
BassPig
BassPig's Avatar
The file I was testing was a short, 6 minute trailer off the BD. What happens is after pressing the start button, one of my 8 CPU cores shows considerable activity, but the GPUs both are idle, even if I use the Intel or the NVENC encoding options. The status at the bottom of the screen shows 0.00 FPS encoding speed and there is no visual indication that the program is doing any work. I waited about 15 minutes. This, on a i9-9700K, which is not the slowest CPU on the planet. I did note that after that 15 minutes, I had about a 6MB file in the output folder, so I tried to play it in VLC. It was only audio though, no video.
I can reasonably expect maybe a minute or so before visual indicators come to life, but 15 minutes of doing nothing? Seems like something went wrong.
Take care,
www.ampexperts.com
Old 24th July 2019, 20:31   #4  |  Link
BassPig
BassPig's Avatar
I tried a fresh session and used one of the presets and opened my MKV file, started the encode and left the room. Came back an hour later and it had apparently finished, but the file size was only 6.4MB and in VLC has no video track, only audio.
I don't see any errors in the log:
HandBrake 1.2.2 (2019022300)
OS: Microsoft Windows NT 10.0.17763.0
CPU: Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz
Ram: 32612 MB,
GPU Information:
NVIDIA GeForce GTX 1060 6GB - 25.21.14.1735
Intel(R) UHD Graphics 630 - 25.20.100.6471
Screen: 2560x1600
Temp Dir: C:\Users\Mark Weiss\AppData\Local\Temp\
Install Dir: C:\Program Files\HandBrake
Data Dir: C:\Users\Mark Weiss\AppData\Roaming\HandBrake
# Starting Encode ...
[14:36:16] hb_init: starting libhb thread
[14:36:16] 1 job(s) to process
[14:36:16] json job:
"Audio": {
"AudioList": [
"Bitrate": 160,
"DRC": 0.0,
"Encoder": "av_aac",
"Gain": 0.0,
"Mixdown": 4,
"NormalizeMixLevel": false,
"Samplerate": 0,
"Track": 0,
"DitherMethod": 0
"CopyMask": [
"copy:aac",
"copy:ac3",
"copy:dtshd",
"copy:dts",
"copy:eac3",
"copy:flac",
"copy:mp3",
"copy:truehd"
"FallbackEncoder": "ac3"
"Destination": {
"ChapterList": [
"Name": "Chapter 1"
"Name": "Chapter 2"
"Name": "Chapter 3"
"Name": "Chapter 4"
"Name": "Chapter 5"
"Name": "Chapter 6"
"ChapterMarkers": true,
"AlignAVStart": true,
"File": "F:\\Downloads\\Videos\\A Silent Voice- The Movie T01-1.m4v",
"Mp4Options": {
"IpodAtom": false,
"Mp4Optimize": false
"Mux": "mp4"
"Filters": {
"FilterList": [
"ID": 4,
"Settings": {
"mode": "7"
"ID": 3,
"Settings": {
"block-height": "16",
"block-thresh": "40",
"block-width": "16",
"filter-mode": "2",
"mode": "3",
"motion-thresh": "1",
"spatial-metric": "2",
"spatial-thresh": "1"
"ID": 11,
"Settings": {
"crop-bottom": "22",
"crop-left": "0",
"crop-right": "0",
"crop-top": "22",
"height": "1036",
"width": "1920"
"ID": 6,
"Settings": {
"mode": "2",
"rate": "27000000/900000"
"PAR": {
"Num": 1,
"Den": 1
"Metadata": {},
"SequenceID": 0,
"Source": {
"Angle": 1,
"Range": {
"Type": "chapter",
"Start": 1,
"End": 6
"Title": 1,
"Path": "H:\\MakeMKV FIles\\A Silent Voice\\A Silent Voice- The Movie_t01.mkv"
"Subtitle": {
"Search": {
"Burn": true,
"Default": false,
"Enable": true,
"Forced": true
"SubtitleList": []
"Video": {
"Encoder": "x264",
"Level": "4.0",
"TwoPass": false,
"Turbo": false,
"ColorMatrixCode": 0,
"Options": "",
"Preset": "fast",
"Profile": "main",
"Quality": 22.0,
"QSV": {
"Decode": true,
"AsyncDepth": 0
[14:36:16] CPU: Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz
[14:36:16] - Intel microarchitecture Kaby Lake
[14:36:16] - logical processor count: 8
[14:36:16] Intel Quick Sync Video support: yes
[14:36:16] - Intel Media SDK hardware: API 1.27 (minimum: 1.3)
[14:36:16] - H.264 encoder: yes
[14:36:16] - preferred implementation: hardware (any) via D3D11
[14:36:16] - capabilities (hardware): breftype icq+la+i+downs vsinfo opt1 opt2+mbbrc+extbrc+trellis+ib_adapt+nmpslice
[14:36:16] - H.265 encoder: yes (8bit: yes, 10bit: yes)
[14:36:16] - capabilities (hardware): bpyramid icq vsinfo opt1
[14:36:16] hb_scan: path=H:\MakeMKV FIles\A Silent Voice\A Silent Voice- The Movie_t01.mkv, title_index=1
udfread ERROR: ECMA 167 Volume Recognition failed
src/libbluray/disc/disc.c:323: failed opening UDF image H:\MakeMKV FIles\A Silent Voice\A Silent Voice- The Movie_t01.mkv
src/libbluray/disc/disc.c:424: error opening file BDMV\index.bdmv
src/libbluray/disc/disc.c:424: error opening file BDMV\BACKUP\index.bdmv
[14:36:16] bd: not a bd - trying as a stream/file instead
libdvdnav: Using dvdnav version 6.0.0
libdvdreadVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.IFO failed
libdvdreadVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.BUP failed
libdvdread: Can't open file VIDEO_TS.IFO.
libdvdnav: vm: failed to read VIDEO_TS.IFO
[14:36:16] dvd: not a dvd - trying as a stream/file instead
Input #0, matroska,webm, from 'H:\MakeMKV FIles\A Silent Voice\A Silent Voice- The Movie_t01.mkv':
Metadata:
title : A Silent Voice: The Movie
encoder : libmakemkv v1.14.4 (1.3.5/1.4.7) win(x64-release)
creation_time : 2019-07-24T01:16:42.000000Z
Duration: 00:05:58.94, start: 0.000000, bitrate: 23128 kb/s
Chapter #0:0: start 0.000000, end 32.949583
Metadata:
title : Chapter 01
Chapter #0:1: start 32.949583, end 52.802750
Metadata:
title : Chapter 02
Chapter #0:2: start 52.802750, end 86.669917
Metadata:
title : Chapter 03
Chapter #0:3: start 86.669917, end 106.981875
Metadata:
title : Chapter 04
Chapter #0:4: start 106.981875, end 261.886625
Metadata:
title : Chapter 05
Chapter #0:5: start 261.886625, end 358.941917
Metadata:
title : Chapter 06
Stream #0:0(eng): Video: h264 (High), yuv420p(tv, bt709, progressive), 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
Metadata:
BPS-eng : 22934006
DURATION-eng : 00:05:58.941916666
NUMBER_OF_FRAMES-eng: 8606
NUMBER_OF_BYTES-eng: 1028994410
SOURCE_ID-eng : 001011
_STATISTICS_WRITING_APP-eng: MakeMKV v1.14.4 win(x64-release)
_STATISTICS_WRITING_DATE_UTC-eng: 2019-07-24 01:16:42
_STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID
Stream #0:1(eng): Audio: ac3, 48000 Hz, stereo, fltp, 192 kb/s (default)
Metadata:
title : Stereo
BPS-eng : 191953
DURATION-eng : 00:05:58.902000000
NUMBER_OF_FRAMES-eng: 11213
NUMBER_OF_BYTES-eng: 8611584
SOURCE_ID-eng : 001100
[14:36:16] scan: decoding previews for title 1
[14:36:16] scan: audio 0x1: ac3, rate=48000Hz, bitrate=192000 English (AC3) (2.0 ch)
[14:36:16] scan: 10 previews, 1920x1080, 23.976 fps, autocrop = 22/22/0/0, aspect 16:9, PAR 1:1
[14:36:16] scan: supported video decoders: avcodec qsv
[14:36:16] libhb: scan thread found 1 valid title(s)
[14:36:16] Skipping subtitle scan. No suitable subtitle tracks.
[14:36:16] starting job
[14:36:16] decomb filter thread started for segment 0
[14:36:16] decomb filter thread started for segment 7
[14:36:16] decomb check thread started for segment 1
[14:36:16] decomb check thread started for segment 6
[14:36:16] decomb check thread started for segment 7
[14:36:16] mask filter thread started for segment 1
[14:36:16] decomb filter thread started for segment 5
[14:36:16] mask filter thread started for segment 7
[14:36:16] mask erode thread started for segment 2
[14:36:16] mask erode thread started for segment 4
[14:36:16] decomb filter thread started for segment 1
[14:36:16] mask dilate thread started for segment 4
[14:36:16] decomb check thread started for segment 2
[14:36:16] yadif thread started for segment 1
[14:36:16] yadif thread started for segment 5
[14:36:16] yadif thread started for segment 6
[14:36:16] job configuration:
[14:36:16] * source
[14:36:16] + H:\MakeMKV FIles\A Silent Voice\A Silent Voice- The Movie_t01.mkv
[14:36:16] + title 1, chapter(s) 1 to 6
[14:36:16] + container: matroska,webm
[14:36:16] + data rate: 23128 kbps
[14:36:16] * destination
[14:36:16] + F:\Downloads\Videos\A Silent Voice- The Movie T01-1.m4v
[14:36:16] + container: MPEG-4 (libavformat)
[14:36:16] + align initial A/V stream timestamps
[14:36:16] + chapter markers
[14:36:16] * video track
[14:36:16] decomb filter thread started for segment 6
[14:36:16] + decoder: h264_qsv
[14:36:16] + filters
[14:36:16] + Comb Detect (mode=3:spatial-metric=2:motion-thresh=1:spatial-thresh=1:filter-mode=2:block-thresh=40:block-width=16:block-height=16)
[14:36:16] + Decomb (mode=39)
[14:36:16] + Framerate Shaper (mode=2:rate=27000000/900000)
[14:36:16] + frame rate: 23.976 fps -> peak rate limited to 30.000 fps
[14:36:16] + Crop and Scale (width=1920:height=1036:crop-top=22:crop-bottom=22:crop-left=0:crop-right=0)
[14:36:16] + source: 1920 * 1080, crop (22/22/0/0): 1920 * 1036, scale: 1920 * 1036
[14:36:16] + Output geometry
[14:36:16] + storage dimensions: 1920 x 1036
[14:36:16] + pixel aspect ratio: 1 : 1
[14:36:16] + display dimensions: 1920 x 1036
[14:36:16] + encoder: H.264 (libx264)
[14:36:16] + preset: fast
[14:36:16] + profile: main
[14:36:16] + level: 4.0
[14:36:16] mask filter thread started for segment 3
[14:36:16] + quality: 22.00 (RF)
[14:36:16] + color profile: 1-1-1
[14:36:16] * audio track 1
[14:36:16] + decoder: English (AC3) (2.0 ch) (track 1, id 0x1)
[14:36:16] + bitrate: 192 kbps, samplerate: 48000 Hz
[14:36:16] + mixdown: Stereo
[14:36:16] + dither: none
[14:36:16] + encoder: AAC (libavcodec)
[14:36:16] + bitrate: 160 kbps, samplerate: 48000 Hz
[14:36:16] mask filter thread started for segment 2
[14:36:16] mask filter thread started for segment 4
[14:36:16] decomb filter thread started for segment 3
[14:36:16] mask filter thread started for segment 5
[14:36:16] mask filter thread started for segment 6
[14:36:16] mask erode thread started for segment 1
[14:36:16] mask erode thread started for segment 0
[14:36:16] mask erode thread started for segment 3
[14:36:16] decomb check thread started for segment 0
[14:36:16] mask erode thread started for segment 6
[14:36:16] mask erode thread started for segment 5
[14:36:16] decomb check thread started for segment 3
[14:36:16] mask dilate thread started for segment 1
[14:36:16] mask erode thread started for segment 7
[14:36:16] mask dilate thread started for segment 2
[14:36:16] decomb filter thread started for segment 2
[14:36:16] mask dilate thread started for segment 0
[14:36:16] mask dilate thread started for segment 3
[14:36:16] mask dilate thread started for segment 5
[14:36:16] yadif thread started for segment 0
[14:36:16] mask dilate thread started for segment 6
[14:36:16] decomb check thread started for segment 5
[14:36:16] mask dilate thread started for segment 7
[14:36:16] yadif thread started for segment 2
[14:36:16] decomb filter thread started for segment 4
[14:36:16] yadif thread started for segment 3
[14:36:16] yadif thread started for segment 4
[14:36:16] yadif thread started for segment 7
[14:36:16] decomb check thread started for segment 4
[14:36:16] mask filter thread started for segment 0
[14:36:16] sync: expecting 8605 video frames
[14:36:16] encx264: min-keyint: 24, keyint: 240
[14:36:16] encx264: encoding at constant RF 22.000000
[14:36:16] encx264: unparsed options: level=4.0:ref=2:8x8dct=0:weightp=1:subme=6:vbv-bufsize=25000:vbv-maxrate=20000:rc-lookahead=30
x264 [info]: using SAR=1/1
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
x264 [info]: profile Main, level 4.0, 4:2:0, 8-bit
[14:36:23] sync: first pts audio 0x1 is 0
[14:43:32] reader: done. 1 scr changes
[14:43:33] work: average encoding speed for job is 0.000000 fps
[14:43:33] comb detect: heavy 0 | light 0 | uncombed 0 | total 0
[14:43:33] decomb: deinterlaced 0 | blended 0 | unfiltered 0 | total 0
[14:43:33] vfr: 0 frames output, 0 dropped and 0 duped for CFR/PFR
[14:43:33] vfr: lost time: 0 (0 frames)
[14:43:33] vfr: gained time: 0 (0 frames) (0 not accounted for)
[14:43:33] ac3-decoder done: 11213 frames, 0 decoder errors
[14:43:33] h264_qsv-decoder done: 0 frames, 8607 decoder errors
[14:43:33] sync: got 0 frames, 8605 expected
[14:43:33] mux: track 0, 0 frames, 0 bytes, 0.00 kbps, fifo 8
[14:43:33] mux: track 1, 16824 frames, 6568052 bytes, 146.39 kbps, fifo 32768
[14:43:33] libhb: work result = 0
# Encode Completed ...
On second read, these two lines:
make me suspect that it could not find these files because the input file is an MKV.
Take care,
www.ampexperts.com
Old 24th July 2019, 20:38   #5  |  Link
sneaker_ger
Can you try with software decoding? (Preferences->Video-> un-tick "Enable QuickSync Decoding")
Old 28th July 2019, 04:29   #6  |  Link
BassPig
BassPig's Avatar
Yes, I've tried it all different ways. But it's the same result. I think it just doesn't know what to do with the MKV container.
Take care,
www.ampexperts.com
[IMG] code is Off
