Old 10th February 2021, 09:19   #641  |  Link
ChaosKing
Ah yes, I can see it in DebugView++ now. Could be some of the used filters in QTGMC. I think I saw once Myrsloik posting an image of the generated filter graph by a VS script. I can't find it right now, but could be handy to quickly check which plugins are beiing used...
edit
Avisynth has DumpFilterGraph(), does VS has something similar build in?
ChaosKing is offline
Old 10th February 2021, 10:19   #642  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
edit
Only in the API R4 test builds.
Myrsloik is offline
Old 10th February 2021, 16:02   #643  |  Link
HolyWu
Originally Posted by lansing View Post
When running QTGMC, I'm getting a log "AvstpWrapper: cannot find avstp.dll.Usage restricted to single threading" in the console
https://github.com/EleonoreMizo/fmtc...apper.cpp#L160
HolyWu is offline
Old 11th February 2021, 05:15   #644  |  Link
lansing
Originally Posted by HolyWu View Post
So does that mean I'm running something single thread?
lansing is offline
Old 16th February 2021, 13:33   #645  |  Link
Julek
Julek's Avatar
Since you have ported TDeint, is there any chance that you also port MTCombMask?
https://github.com/Asd-g/MTCombMask
In some cases it does better than the current CombMask, capturing some areas that CombMask ignores.
Julek is offline
Old 30th September 2021, 03:33   #646  |  Link
lansing
QTGMC() needs update as of R56 since filters under core.misc namespace has been changed.
lansing is offline
Old 30th September 2021, 07:22   #647  |  Link
ChaosKing
Namespace has been changed? misc is an external plugin now. So "vsrepo install misc" and everything is back to where it was.
Old 30th September 2021, 12:35   #648  |  Link
lansing
Thanks it works.
lansing is offline
Old 4th October 2021, 20:51   #649  |  Link
cogman
The Crazy Idahoan
Any path forward for us linux folk? How hard is it to build the v3 libs and use them with v4?
cogman is offline
Old 4th October 2021, 21:09   #650  |  Link
Myrsloik
Myrsloik's Avatar
Same as windows. Very easy. Almost all API3 stuff still works.
All split out plugins can be found here. Build system included with most.
https://github.com/vapoursynth
Myrsloik is offline
