Old 27th October 2013, 06:36   #41  |  Link
aegisofrime
Due to the changes in VS r21, Will it be a difficult process rewriting HAvsFunc to use the new native RemoveGrain plugin instead of the Avisynth one?
aegisofrime is offline
Old 27th October 2013, 06:50   #42  |  Link
HolyWu
Not that difficult. Already working on it. Maybe release today or tomorrow.
HolyWu is offline
Old 29th October 2013, 10:08   #43  |  Link
HolyWu
Updated r5.
  • Added the following functions: ediaa, daa, maa, SharpAAMCmod, Deblock_QED, Vinverse, LUTDeCrawl, LUTDeRainbow.
  • Added a simple wrapper Resize over fmtc.resample + fmtc.bitdepth, including a ringing-cancellation algorithm from Dither_resize16nr.
  • Added GammaToLinear and LinearToGamma function. The same as Dither_y_gamma_to_linear and Dither_y_linear_to_gamma, but some parameters name and default values are changed.
  • HQDering mod updated to v1.4. stack16 input/output is supported.
  • SMDegrain's Motion Vectors Globals Input/Output is supported.
  • LSFmod's Smode 1&2 are deleted. Smode 3~5 becomes 1~3 now.
  • Added 'noring' parameter to maa, SharpAAMCmod, Dehalo_alpha and LSFmod to indicate that a non-ringing algorithm must be used in case of supersampling.
  • Replaced RemoveGrain/Repair with the native plugin.
  • It's no need to pass in the core instance anymore.
  • Some bug fixes, optimizations and cosmetic changes.
EDIT: Fixed a very minor issue. Please redownload if you have downloaded hours ago.
HolyWu is offline
Old 30th October 2013, 13:36   #44  |  Link
HolyWu
Updated r6.
A quick bug fix release. I missed the 'planes' parameter in GammaToLinear/LinearToGamma and it mistakenly only processed the first(Y or R) plane. By the way I also add restriction on bitdepth to only allow 16-bit input clip in GammaToLinear/LinearToGamma.
HolyWu is offline
Old 17th February 2014, 17:08   #45  |  Link
Mystery Keeper
Beyond Kawaii
Mystery Keeper's Avatar
Couldn't get Deblock_QED to work. It uses mt_lutspa, but when I try to load mt_masktools-26.dll VS says it has no entry point.
...desu!
Mystery Keeper is offline
Old 17th February 2014, 17:12   #46  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Only 2.5 plugins supported for now. 2.6 won't happen until avisynth+ makes a sane 64bit api most likely.
Myrsloik is offline
Old 17th February 2014, 17:59   #47  |  Link
Mystery Keeper
Beyond Kawaii
Thank you. Figured it out, got it to work.
...desu!
Old 2nd July 2014, 20:55   #48  |  Link
Mystery Keeper
Beyond Kawaii
Using Deblock_QED crashes my script if I seek far forward. Crash happens in mt_masktools-25.dll. Can these functions be made to not rely on it?
...desu!
Old 3rd July 2014, 17:49   #49  |  Link
Reel.Deel
I don't think so, but it's been a while since I've used VS so if I remember correctly there is no native mt_lutspa equivalent.
Reel.Deel is offline
Old 3rd July 2014, 21:56   #50  |  Link
Mystery Keeper
Beyond Kawaii
mt_lutspa replacement from Myrsloik himself.
...desu!
Old 3rd July 2014, 22:54   #51  |  Link
Reel.Deel
Hmmm, I guess I must of missed that... I guess now the only Avisynth plugin required is DCTFilter?... Cool beans
Old 3rd July 2014, 23:50   #52  |  Link
Mystery Keeper
Beyond Kawaii
Also Deblock. But I tried to replace lutspa with those functions, and it spawns threads like crazy. Right now VirtualDub is running 1581 thread and hanging. My own WIP editor dies quickly after spawning ~700.
...desu!
Old 3rd July 2014, 23:54   #53  |  Link
Reel.Deel
Also Deblock.
Of course (how did I forget that?)
Old 4th July 2014, 05:01   #54  |  Link
HolyWu
Try havsfunc-r7.7z and see if it works for you. I didn't give it a heavy test though.
  • Added the following function: GrainStabilizeMC.
  • Changed the way to generate block clip instead of using mt_lutspa, which is used in Deblock_QED.
  • HQDering mod updated to v1.8.
  • Added sigmoid curves to GammaToLinear/LinearToGamma.
  • LSFmod's Smode 2 is deleted. Now Smode=1 is Range sharpening, Smode=2 is Nonlinear sharpening (corrected version).
  • Optimized the way to build LUT of Smode=2 in LSFmod. In previous version std.Expr is used for >8-bit clip and the speed is very slow. Now std.Lut is used for 8~16-bit clip.
  • Replaced MakeDiff/AddDiff with internal function std.MakeDiff/std.MergeDiff instead of using std.Expr.
HolyWu is offline
Old 4th July 2014, 10:02   #55  |  Link
Mystery Keeper
Beyond Kawaii
Works, but the same way as with mt_lutspa. If I seek all the way to the last frame - I crash. But now I did get an error. "Seek pattern broke d2vsource." -_-
But it does work, so thank you again.
...desu!
Old 16th August 2014, 15:21   #56  |  Link
HolyWu
Updated r8.
Changed Deblock_QED to use native plugins. That's it.
HolyWu is offline
Old 16th August 2014, 19:39   #57  |  Link
Mystery Keeper
Beyond Kawaii
Thank you!
...desu!
Old 24th August 2014, 12:29   #58  |  Link
YamashitaRen
Thank you!
As a linux user, I greatly appreciate these steps toward a fully native vapoursynth
YamashitaRen is offline
Old 26th August 2014, 14:27   #59  |  Link
HolyWu
Updated r9.
Added GrainFactory3 function. The default of g?str is adjusted to a saner value as the default in the original is way too overkill. Besides, g?tex parameter is removed.
HolyWu is offline
Old 23rd September 2014, 16:22   #60  |  Link
HolyWu
Updated r10.
Changed QTGMC and some other functions to use native filters of MVTools.
HolyWu is offline
