Old 24th January 2016, 14:11   #201  |  Link
speedyrazor
All good, thanks, working now.
Just checking, but using QTGMC, it is going to be staying in 10 bit?
speedyrazor is offline
Old 24th January 2016, 19:24   #202  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Yes, it should stay in 10bit. I would however recommend doing all processing in 16bit. You're wasting a lot of intermediate precision by not using it.
Myrsloik is offline
Old 24th January 2016, 20:49   #203  |  Link
speedyrazor
Hi Myrsloik, thanks for the suggestion, and sorry to ask, but using the below script as a 'typical' example, what commands would I need to add / change to process everything in 16 bit?
import vapoursynth as vs
core = vs.get_core()
ret = core.lsmas.LibavSMASHSource(source=r"F:/Interlaced_Test.mov")
ret = core.yadifmod.Yadifmod(ret, edeint=core.nnedi3.nnedi3(ret, field=1), order=1)
ret = core.fmtc.resample (clip=ret, w=720, h=576, css="444", kernel="spline36")
ret = core.fmtc.matrix (clip=ret, mats="709", matd="601")
ret = core.fmtc.resample (clip=ret, css="422")
ret = core.fmtc.bitdepth (clip=ret, bits=10)
ret.set_output()
Kind regards.
Old 25th January 2016, 03:11   #204  |  Link
HolyWu
Simply insert ret = core.fmtc.bitdepth(clip=ret, bits=16) below LibavSMASHSource.
HolyWu is offline
Old 25th January 2016, 07:26   #205  |  Link
speedyrazor
So it would look like this:
ret = core.fmtc.bitdepth (clip=ret, bits=16)
ret.set_output()
So convert to 16 bit, do the processing and force it back down to 10?
Does this have much processing / speed implications?
Kind regards.
Old 25th January 2016, 07:32   #206  |  Link
Boulder
Pig on the wing
Boulder's Avatar
No need to go back to 10 bits so you can remove the "ret = core.fmtc.bitdepth (clip=ret, bits=10)" line. Depending on the encoder you are using to produce the final result, you may need to tell it that you are inputting a 16-bit source.
Boulder is offline
Old 25th January 2016, 07:53   #207  |  Link
speedyrazor
I am piping into ffmpeg, is it better for ffmpeg to do the convert, or VapourSynth?
Old 25th January 2016, 19:21   #208  |  Link
Boulder
Pig on the wing
Boulder's Avatar
What codec do you use inside ffmpeg?
Boulder is offline
Old 25th January 2016, 21:22   #209  |  Link
speedyrazor
Mainly Prores HQ, but also H.264 and Mpeg2.
Old 25th January 2016, 21:43   #210  |  Link
Boulder
Pig on the wing
Boulder's Avatar
At least h.264 (x264) should have the input depth parameter, don't know about the others.
Boulder is offline
Old 25th January 2016, 21:48   #211  |  Link
sneaker_ger
x264cli has automatic dithering, that's different from the libx264 integration of ffmpeg. Either way, I don't see any reason to favor ffmpeg's/x264cli's dithering over the one of fmtconv.
sneaker_ger is offline
Old 25th January 2016, 22:50   #212  |  Link
speedyrazor
Thanks for the advice.
Old 5th February 2016, 16:31   #213  |  Link
sl1pkn07
Pajas Mentales...
only for history record, anyone have the r1, r2 and r3 zips/.py?
greetings
[AUR] Vapoursynth Stuff
[AUR] Avisynth Stuff
sl1pkn07 is offline
Old 5th February 2016, 19:29   #214  |  Link
Myrsloik
Myrsloik's Avatar
Speaking about history. Is there any chance I could convince you to use github for hosting and history too?
Myrsloik is offline
Old 5th February 2016, 20:13   #215  |  Link
sl1pkn07
Pajas Mentales...
the history is here https://www.nmm-hd.org/newbbs/viewtopic.php?f=23&t=941
sl1pkn07 is offline
Old 9th February 2016, 16:22   #216  |  Link
HolyWu
Done.
Could you consider porting SRestore to Vapoursynth? It's a monster of a function but quite slow in Avisynth as it doesn't like multithreading much.
Could you or anyone provide a small sample clip with blending problem? I need to do some experiments and make sure the result is correct.
HolyWu is offline
Old 9th February 2016, 16:26   #217  |  Link
sl1pkn07
Pajas Mentales...
i have zips since r4, if you want add in the history
http://sl1pkn07.wtf/havsfunc
sl1pkn07 is offline
Old 9th February 2016, 17:17   #218  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Sure, I'll try to find something for you off my HDDs. I have at least one concert video readily available but it's tricky to get a good scene for testing.
Boulder is offline
Old 9th February 2016, 17:59   #219  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Here you go: https://drive.google.com/file/d/0Bze...ew?usp=sharing
The original frame rate is 25 fps.
Boulder is offline
Old 17th February 2016, 19:11   #220  |  Link
BakaProxy
Do you actually intend on implementing the different prefilters from the avisynth version of smdegrain? prefilter 3 and 4 that is.
Thanks in advance.
BakaProxy is offline
