Old 4th September 2012, 18:36   #1  |  Link
Th3KiNG
DVD2DVD-R Pro vs DVD Rebuilder Pro
Which one do you recommend and why?
Th3KiNG is offline   Reply With Quote
Old 5th September 2012, 00:06   #2  |  Link
writersblock29
DVD Rebuilder Pro wins in my book because of the amount of choices it offers. Full disk, movie-only, alternate output... and it can use the free HC encoder (which many argue is on par with CCE). What's not to like?
Isn't it a bit unnerving that doctors call what they do "practice?"
--George Carlin
writersblock29 is offline   Reply With Quote
Old 5th September 2012, 03:14   #3  |  Link
manolito
manolito's Avatar
I agree with writersblock29. Even the free version of DVD-RB is way more versatile than DVD2DVD-R Pro.
I assume that you are referring to DVD2DVD-R Pro Version 2.52. I installed and tested it with 2 DVD sources. It does not offer too many options, but this makes it very easy to use.
One thing though is totally unacceptable:
It installs an older version of AviSynth without asking for permission and without even telling the user. Which of course breaks any newer software which needs a current AviSynth version (e.g. AVStoDVD).
So I definitely do not recommend DVD2DVD-R Pro...
Cheers
manolito
[IMG] code is Off
