Old 1st December 2011, 08:21   #1  |  Link
Starbuck2010
DVDx 4 Author
Starbuck2010's Avatar
DVDx 4.0.1.0 is out!
Version 4.0.1.0: Merge and split movie files
New smart feature:
- add movie merge (merge several movie files into one file)
New feature (all editions, input files must not have multi-audio or multi-subtitle tracks):
- add movie split to volumes (split one file into fixed-size volumes)
- add movie split into equal parts (divide one file into several ones)
Smart Edition:
- increase maximum video bitrate for H.264 HDTV and DivX Plus HD codecs from 4000Kbps to 20000Kbps
- set default video bitrate at 6000Kbps for H.264 HDTV and DivX Plus HD codecs
- no longer ask for activiation at every start
All:
- change H.264 HDTV and DivX Plus HD bitrates for medium and high profiles
- limit job manager window width (too large with too long fine names)
Windows:
- updated FFmpeg engines to 32-bit N-34031-ge403a97 and 64-bit
- updated MediaInfo to 0.7.51
- upgrade to Qt 4.7.4 libraries
Mac OS X:
- fix job title display in job manager window (first job title vertical display was shrinked)
Linux (Ubuntu):
- back to Qt 4.7.2 libraries for compile platform (Ubuntu 11.10 libmenu issue with Qt 4.7.4)
- Ubuntu Unity notes:
a) to remove Global Menu: sudo apt-get remove appmenu-gtk3 appmenu-gtk appmenu-qt
which is revertible: sudo apt-get install appmenu-gtk3 appmenu-gtk appmenu-qt
b) to run an DVDx 4 with the menu inside the application window and not on the Uniy panel
(which is not a regular Gnome Panel!): UBUNTU_MENUPROXY=0 dvdx4
c) to run an DVDx 4 with the menu in both the Unity panel and the application window,
like so: APPMENU_DISPLAY_BOTH=1 dvdx4
Developpers (Open Edition):
- introducing new encoder and media analyzer interfaces (much faster and easier to manage)
DVDx 4.0 home page:
http://www.labdv.com/dvdx/
Starbuck
DVDx 4 Author
Starbuck2010 is offline   Reply With Quote
Old 2nd December 2011, 09:33   #2  |  Link
Przemek_Sperling
When the main windows of the program is maximized the system tray of my Win 7 Home Ed. x32 PL obscures the bottom option section, so I cannot set any. In fact I cannot even press "start encoding".
Przemek_Sperling is offline   Reply With Quote
Old 2nd December 2011, 13:30   #3  |  Link
Starbuck2010
DVDx 4 Author
I can't reproduce that behavior. When I maximize DVDx 4.0 it goes at top-left but doesn't change window size (no video loaded).
This is normal behavior because DVDx 4.0 keep it's size to fit loaded video.
Maybe you have low screen rezolution or very large video rezolution.
Anyway, they're 2 solutions:
A) Player menu, Display zoom submenu, choose 1:4
B) If you've closed DVDx with a too large window, you have to reset settings: Options menu, Clear all settings menu.
I guess you gona solve this, please keep me posted.
And btw, next version we're working on will have a more powerful player with better resizing behavior.
Starbuck
DVDx 4 Author
Old 2nd December 2011, 14:40   #4  |  Link
Przemek_Sperling
Thanks for the hint. The #1 option works! Actually I see that o9nly "auto settings" work wrong. All other work with flying colors.
I use a Sapphire ATI Radeon 5770 video card with latest (11.11) Catalyst drivers. The resolution of my screen is 1680*1050 pixels.
Old 5th December 2011, 13:39   #5  |  Link
sl1pkn07
Pajas Mentales...
one question....
dvdx-4.0.1.0-win32.exe
dvdx-4.0.1.0-macosx_x86_64.dmg
dvdx-4.0.1-0_i386.deb
why?
[AUR] Vapoursynth Stuff
[AUR] Avisynth Stuff
sl1pkn07 is offline   Reply With Quote
Old 5th December 2011, 15:11   #6  |  Link
Starbuck2010
DVDx 4 Author
For Windows: dvdx-4.0.1.0-win32.exe
For Mac OS X (intel): dvdx-4.0.1.0-macosx_x86_64.dmg
For Linux (intel): dvdx-4.0.1-0_i386.deb
Starbuck
DVDx 4 Author
Old 5th December 2011, 19:18   #7  |  Link
sl1pkn07
Pajas Mentales...
sourcecode (open edition) compile* in my 64bits linux machine
why only distribute 32bits binary?
*build-release-linux.sh: line 2: ../../tools/linux/buildnumber: No such file or directory
don't exist "/tools/buildnumber" in sourcecode 7z
fail build
Old 6th December 2011, 09:48   #8  |  Link
Starbuck2010
DVDx 4 Author
I guess 64-bit build won't add any performance value while it requires one more compiler platform to manage. But I have it in my list anyway (much to do with features before).
For compilation, see the Developers-Compiling page:
http://www.labdv.com/dvdx/dev-compiling.php
The tools.7z is there.
Starbuck
DVDx 4 Author
Old 6th December 2011, 17:31   #9  |  Link
sl1pkn07
Pajas Mentales...
ok thanks
i have problem with detect mplayer
InterfaceMplayer::cliCmdGetStatus() returns command: "/usr/bin/mplayer" with options ("-noconfig", "all", "-noquiet", "-nocache", "-nofs", "-nomouseinput", "-vo", "help", "-ao", "help")
Player: start process "/usr/bin/mplayer" ("-noconfig", "all", "-noquiet", "-nocache", "-nofs", "-nomouseinput", "-vo", "help", "-ao", "help")
Player: process started.
Player: process finished.
InterfaceMplayer::parseStatus() starts parsing status raw data
InterfaceMplayer::parseStatus() - Failed to parse MPlayer log (signature)
but mplayer is intalled (i change the paths on main/paths.h. from the /opt/dvdx4-open-edition/bin to /usr/bin)
sl1pkn07@sL1pKn07 aplicaciones $ mplayer "-noconfig" "all" "-noquiet" "-nocache" "-nofs" "-nomouseinput" "-vo" "help" "-ao" "help"
MPlayer2 421c840 (C) 2000-2011 MPlayer Team
Controladores de salida de video disponibles:
        vdpau   VDPAU with X11
        xv      X11/Xv
        gl_nosw OpenGL no software rendering
        x11     X11 ( XImage/Shm )
        xover   General X11 driver for overlay capable video output drivers
        sdl     SDL YUV/RGB/BGR renderer (SDL v1.1.7+ only!)
        gl      OpenGL
        gl_sdl  OpenGL with SDL
        dga     DGA ( Direct Graphic Access V2.0 )
        fbdev   Framebuffer Device
        fbdev2  Framebuffer Device
        aa      AAlib
        caca    libcaca
        v4l2    V4L2 MPEG Video Decoder Output
        dfbmga  DirectFB / Matrox G200/G400/G450/G550
        null    Null video output
        directfb        Direct Framebuffer Device
        mpegpes MPEG-PES to DVB card
        yuv4mpeg        yuv4mpeg output for mjpegtools
        png     PNG file
        jpeg    JPEG file
        gif89a  animated GIF output
        tga     Targa output
        pnm     PPM/PGM/PGMYUV file
        md5sum  md5sum of each frame
Controladores de salida de audio disponibles:
        oss     OSS/ioctl audio output
        alsa    ALSA-0.9.x-1.x audio output
        pulse   PulseAudio audio output
        jack    JACK audio output
        sdl     SDLlib audio output
        mpegpes DVB audio output
        v4l2    V4L2 MPEG Audio Decoder output
        null    Null audio output
        pcm     RAW PCM/WAVE file writer audio output
        rsound  RSound output driver
162 codecs de audio & 361 codecs de video
greetings
Old 6th December 2011, 18:02   #10  |  Link
Starbuck2010
DVDx 4 Author
change in interfacemplayer.cpp
#define RX_CATCH_MPLAYER_OUTPUT_STATUS "(mplayer\\s+[^\\s]+.*MPlayer Team)"
#define RX_PARSE_MPLAYER_SIGNATURE "(mplayer)\\s+([^\\s]+).*(MPlayer Team)"
to
#define RX_CATCH_MPLAYER_OUTPUT_STATUS "(mplayer\\d*\\s+[^\\s]+.*MPlayer Team)"
#define RX_PARSE_MPLAYER_SIGNATURE "(mplayer\\d*)\\s+([^\\s]+).*(MPlayer Team)"
Because mplayer signature is MPlayer2.
I've change for further versions (so thanks by the way)
Starbuck
DVDx 4 Author
Old 6th December 2011, 18:58   #11  |  Link
sl1pkn07
Pajas Mentales...
thanks!
Upload PKGBUILD for Archlinux https://aur.archlinux.org/packages.php?ID=54642
greetings
Old 7th December 2011, 08:01   #12  |  Link
Starbuck2010
DVDx 4 Author
Thanks for sharing,
I've linkedd from DVDx 4.0 download page:
http://www.labdv.com/dvdx/download.php#archlinux
Starbuck
DVDx 4 Author
[IMG] code is Off
