Old 28th January 2009, 18:19   #21  |  Link
LaTo
LaTo INV.
LaTo's Avatar
PS: If you really want supersampling (I haven't seen any enhancement):
custom="spline36resize(resolution*2).addgrain(xx,0,0).spline36resize(resolution)"
LaTo is offline   Reply With Quote
Old 28th January 2009, 18:35   #22  |  Link
McCauley
Thanks for the custom clip!
Added to the wiki.
Regards
McCauley
McCauley is offline   Reply With Quote
Old 28th January 2009, 20:00   #23  |  Link
thetoof
Sleepy overworked fellow
Could you give the pros/cons of the different parameters in the guide... you only name them, which is not very useful for unexperienced users. (that aside, good job ^_^)
AnimeIVTC() - v2.00
-http://boinc.berkeley.edu/-
Let all geeks use their incredibly powerful comps for the greater good (no, no, it won't slow your filtering/encoding :p)
thetoof is offline   Reply With Quote
Old 3rd February 2009, 02:19   #24  |  Link
stpdrgstr
I've been testing this, and is quite good, the only parts of the image dithered are the ones that really need it.
Though, I don't really see any difference from temp=100 or using temp=50, the grain looks the same "jumpy" with any of these.
stpdrgstr is offline   Reply With Quote
Old 11th February 2009, 01:25   #25  |  Link
OrionZodiac
I didn't want to start a new thread, so i posted my ply for help here.
This is the first 10 seconds of freedom OVA ep#2. The source has virtually no grain, however the color gradient is HORRIBLE. I have been trying for days trying to get rid of the banding in some way or another, but the end-result does not look very good. Somebody please take a look at the purple area in the background and tell me if you have a good solution for the banding here.
http://www.megaupload.com/?d=GM7IZQR2
Thank you
OrionZodiac is offline   Reply With Quote
Old 11th February 2009, 16:30   #26  |  Link
LaTo
LaTo INV.
LaTo's Avatar
Update 2009/02/11 v1.3
v1.3:
replaced chroma parameter by thrC & strC
Old 11th February 2009, 16:38   #27  |  Link
LaTo
LaTo INV.
LaTo's Avatar
Thank you
GradFun2DBmod(thr=1.2,thrC=1.8,str=0.0,strC=0.0)
edit: If the effect disappear when encoding, you should increase str & strC until the dither remains.
Old 26th February 2009, 18:27   #28  |  Link
Video Dude
Senior Member
Can GradFun2DBmod be applied straight to interlace video?
Or should a SeparateFields or the Bob/filter/reinterlace method be used to apply GradFun2DBmod to interlaced video?
Video Dude is offline   Reply With Quote
Old 20th April 2009, 05:25   #29  |  Link
swaaye
Could someone please post AddGrainC 1.4 somewhere? The link from the avisynth plugin page to foxyshadis site is dead and I can't find the v1.4 plugin anywhere. Only managed to find 1.3....
swaaye is offline   Reply With Quote
Old 20th April 2009, 13:47   #30  |  Link
Socio
LaTo I have a side question; what app are you using in that side by side comparison in the OP?
Thanks
Socio is offline   Reply With Quote
Old 20th April 2009, 14:14   #31  |  Link
LaTo
LaTo INV.
LaTo's Avatar
Thanks
No app, just: GradFun2DBmod(show=true)
Old 20th April 2009, 15:22   #32  |  Link
Socio
Ok got it playing around with it now;
Old 21st April 2009, 02:59   #33  |  Link
hartford
hartford's Avatar
I've uploaded to the forum the 1.4 plugin:
http://forum.doom9.org/showthread.php?t=51320
It may take time before it is approved.
Hopefully, Warpenterprises will replace the old with the new.
Where did I get this? I don't recall.
hartford is offline   Reply With Quote
Old 23rd April 2009, 19:18   #34  |  Link
SPiKA
Thanks LaTo, this script is amazing!
SPiKA is offline   Reply With Quote
Old 3rd May 2009, 16:50   #35  |  Link
Nephilis
--preset WTF!
Where should i use GradFun2DBmod () (to avoid color blocking in dark areas in a frame) in the filterchain? At the last of script or somewhere else? Before or after sharpen, denoise ?
Thanx in advance..
Nephilis is offline   Reply With Quote
Old 3rd May 2009, 17:07   #36  |  Link
SPiKA
It's rather pointless to use it before denoising... xD
Old 3rd May 2009, 21:34   #37  |  Link
Sagekilla
x264aholic
Generally I would use debanding after denoising, but not before sharpening. If you do it before sharpening, the sharpener may accidentally sharpen your dither.
i.e:
Denoise()
Deband()
or
Denoise()
Sharpen()
Deband()
Sagekilla is offline   Reply With Quote
Old 4th May 2009, 12:41   #38  |  Link
Nephilis
--preset WTF!
I'll do it so
Denoise()
Sharpen()
Deband()
Thanx a lot Sagekilla..
Old 5th May 2009, 18:29   #39  |  Link
Zelos
it's me or it's horribly slow ?
Zelos is offline   Reply With Quote
Old 6th May 2009, 03:06   #40  |  Link
Sagekilla
x264aholic
Well yes, It's slower than your standard Gradfun2db, but that's because it has multiple masktools operations and some temporal soften + add grain sprinkled in. Temporal soften is fairly slow, and the mt_lut's don't help any either
