Old 27th December 2008, 01:56   #41  |  Link
mikeytown2
Resize Abuser
mikeytown2's Avatar
Try it after installing this
Microsoft Visual C++ 2005 Redistributable Package
http://www.microsoft.com/downloads/d...displaylang=en
mikeytown2 is offline   Reply With Quote
Old 27th December 2008, 14:49   #42  |  Link
zee944
This solved it. Thanks.
zee944 is offline   Reply With Quote
Old 17th April 2012, 19:34   #43  |  Link
lansing
can anyone reupload the colorbalance dll somewhere? The original download link was dead
Old 17th April 2012, 19:59   #44  |  Link
Gavino
Avisynth language lover
This is the penultimate version (v0.25).
I believe the only difference in v0.26 was to change/correct the default value of the clone_gimp parameter (see post #38).
Old 18th April 2012, 06:27   #45  |  Link
lansing
12 hours since attachment posted and still no approval?
Old 18th April 2012, 07:39   #46  |  Link
cretindesalpes
cretindesalpes's Avatar
You forgot the magic formula. "I downloaded this MKV from the internets", and the moderators come instantly.
dither 1.28.1 for AviSynth | avstp 1.0.4 for AviSynth development | fmtconv r30 for Vapoursynth & Avs+ | trimx264opt segmented encoding
cretindesalpes is offline   Reply With Quote
Old 19th April 2012, 00:34   #47  |  Link
Mounir
i don't understand the syntax, how do you use this filter??
edit: nevermind
Mounir is offline   Reply With Quote
Old 1st July 2013, 06:59   #48  |  Link
real.finder
I found the v0.26 here
Old 16th November 2013, 21:30   #49  |  Link
BiOSsCZ
Hello,
Please, how to use this interesting plugin?
Can anyone help me?
BiOSsCZ is offline   Reply With Quote
Old 31st May 2015, 15:21   #50  |  Link
Bernardd
Hello,
I search a coloryuv autogain function alternative. I have tried to write a script to get automatic white balance with StainlessS RGBAdapt plugin.
Some results were nice, but it is a problem of luma compressed range, that i do not know resolve now. I am now out my knowledge boundary. Thus
i have tried to get automatic white balance with ColorBalance plugin. With my RGBAdapt experiment, i can say now, which is efficiently.
This function need to load ColorBalance.dll, GRunt.dll and MaskTools2.dll. The function has two original ColorBalance args (keep_luma and clone_gimp)
If the output is not nice, the function has two special args. one to tune the the reference middle value. one to increase or decrease the range of midtones.
There are three technical args, one for color space conversion matrix choice, one to display calculated corrections and one to display tones masks.
Note : i do not know Cine paint vs Gimp theorical difference
function ColorBalance_auto(clip, bool "keep_luma", bool "clone_gimp", string "matrix", int "midtones_value", \
string "midtones_size", bool "show_info", bool "show_masks")
#----------------------------------------------based on ColorBalance plugin -------------------------------------------------------------------#
# script authors : Gavino, Mikeytown2 http://forum.doom9.org/showpost.php?...1&postcount=44 #
#---------------------------------------------- need GRunT plugin ----------------------------------------------------------------------------#
# script author : Gavino http://forum.doom9.org/showthread.ph...83#post1157083 #
#---------------------------------------------- need masktools v2 plugin ----------------------------------------------------------------------------#
# script authors : Kurosu, Manao, mg262 http://forum.doom9.org/showthread.ph...83#post1157083 #
# fork http://avisynth.nl/index.php/MaskTools2 #
keep_luma = default(keep_luma, true) # (original plugin arg) Keep_luma corresponds to Gimp's 'Preserve Luminosity'.
# This option ensures that the brightness is maintained. The value of the brightest pixels are not changed.
clone_gimp = default(clone_gimp, true) # (original plugin arg) If set to false, ColorBalance will behave like CinePaint.
matrix = default (matrix, "Rec601") # Color standart conversion matrix "Rec601" , "PC601" , "Rec709", "PC709"
midtones_value = default (midtones_value, 128) # Between 0 and 255, default 128
midtones_size = default(midtones_size, "64->192") # midtones range "96 - 160" or "64 - 192" or "32 - 224" or "0 - 255"
show_info = Default(show_info, false) # show info or not, default false
show_masks = Default(show_masks, false) # show masks or not, default false
ScriptClip(clip, """
clip = last
#----------- Luma tones evidence
(!isYV12(clip)) ? ConvertToYV12(clip, matrix=matrix) : clip
shadows_mask = (midtones_size == "96->160") ? MT_Lut(clip,"x 96 <= 255 0 ?", y=3,u=1, v=1):\
((midtones_size == "64->192") ? MT_Lut(clip,"x 64 <= 255 0 ?", y=3,u=1, v=1):\
((midtones_size == "32->224") ? MT_Lut(clip,"x 32 <= 255 0 ?", y=3,u=1, v=1):\
MT_Lut(clip,"x 0 <= 255 0 ?", y=3,u=1, v=1)))
midtones_mask = (midtones_size == "96->160") ? MT_Lut(clip,"x 160 <= x 96 > & 255 0 ?", y=3,u=1, v=1):\
((midtones_size == "64->192") ? MT_Lut(clip,"x 192 <= x 64 > & 255 0 ?", y=3,u=1, v=1):\
((midtones_size == "32->224") ? MT_Lut(clip,"x 224 <= x 32 > & 255 0 ?", y=3,u=1, v=1):\
MT_Lut(clip,"x 255 <= x 0 > & 255 0 ?", y=3,u=1, v=1)))
highlights_mask = (midtones_size == "96->160") ? MT_Lut(clip,"x 160 > 255 0 ?", y=3,u=1, v=1):\
((midtones_size == "64->192") ? MT_Lut(clip,"x 192 > 255 0 ?", y=3,u=1, v=1):\
((midtones_size == "32->224") ? MT_Lut(clip,"x 224 > 255 0 ?", y=3,u=1, v=1):\
MT_Lut(clip,"x 225 > 255 0 ?", y=3,u=1, v=1)))
black = BlankClip(clip, color=$000000)
shadows = Overlay(clip,black, mask=shadows_mask, opacity=1.0, mode="blend")
midtones = Overlay(clip,black, mask=midtones_mask, opacity=1.0, mode="blend")
highlights = Overlay(clip,black, mask=highlights_mask, opacity=1.0, mode="blend")
#------------ Color matrix input
Kr = (matrix == "Rec601") ? 0.299 : ((matrix == "PC601") ? 0.229 : 0.2126)
Kg = (matrix == "Rec601") ? 0.587 : ((matrix == "PC601") ? 0.587 : 0.7152)
Kb = (matrix == "Rec601") ? 0.114 : ((matrix == "PC601") ? 0.114 : 0.0722)
#------------ YUV values extraction
y_shadows = AverageLuma(shadows)
u_shadows = AverageChromaU(shadows)
v_shadows = AverageChromaV(shadows)
y_midtones = AverageLuma(midtones)
u_midtones = AverageChromaU(midtones)
v_midtones = AverageChromaV(midtones)
y_highlights = AverageLuma(highlights)
u_highlights = AverageChromaU(highlights)
v_highlights = AverageChromaV(highlights)
#------------ RGB values
r_shadows = y_shadows + 2*(v_shadows - midtones_value)*(1-Kr)
g_shadows = y_shadows - 2*(u_shadows - midtones_value)*(1-Kb)*Kb/Kg \
- 2*(v_shadows - midtones_value)*(1-Kr)*Kr/Kg
b_shadows = y_shadows + 2*(u_shadows - midtones_value)*(1-Kb)
r_midtones = y_midtones + 2*(v_midtones - midtones_value)*(1-Kr)
g_midtones = y_midtones - 2*(u_midtones - midtones_value)*(1-Kb)*Kb/Kg \
- 2*(v_midtones - midtones_value)*(1-Kr)*Kr/Kg
b_midtones = y_midtones + 2*(u_midtones - midtones_value)*(1-Kb)
r_highlights = y_highlights + 2*(v_highlights - midtones_value)*(1-Kr)
g_highlights = y_highlights - 2*(u_highlights - midtones_value)*(1-Kb)*Kb/Kg \
- 2*(v_highlights - midtones_value)*(1-Kr)*Kr/Kg
b_highlights = y_highlights + 2*(u_highlights - midtones_value)*(1-Kb)
#----------- RGB différence calcul
du_shadows = 128-u_shadows # in YUV range, correction is 128 subtract YUV channel value
dv_shadows = 128-v_shadows
dr_shadows = 2*dv_shadows*(1-Kr)
db_shadows = 2*du_shadows*(1-Kb)
dg_shadows = - 2*du_shadows*(1-Kb)*Kb/Kg - 2*dv_shadows*(1-Kr)*Kr/Kg
du_midtones = 128-u_midtones
dv_midtones = 128-v_midtones
dr_midtones = 2*dv_midtones*(1-Kr)
db_midtones = 2*du_midtones*(1-Kb)
dg_midtones = - 2*du_midtones*(1-Kb)*Kb/Kg - 2*dv_midtones*(1-Kr)*Kr/Kg
du_highlights = 128-u_highlights
dv_highlights = 128-v_highlights
dr_highlights = 2*dv_highlights*(1-Kr)
db_highlights = 2*du_highlights*(1-Kb)
dg_highlights = - 2*du_highlights*(1-Kb)*Kb/Kg - 2*dv_highlights*(1-Kr)*Kr/Kg
#----------- RGB corrections calcul
red_shadows = 100*dr_shadows/r_shadows
green_shadows = 100*dg_shadows/r_shadows
blue_shadows = 100*db_shadows/r_shadows
red_midtones = 100*dr_midtones/r_midtones
green_midtones = 100*dg_midtones/r_midtones
blue_midtones = 100*db_midtones/r_midtones
red_highlights = 100*dr_highlights/r_highlights
green_highlights = 100*dg_highlights/r_highlights
blue_highlights = 100*db_highlights/r_highlights
#-------- ColorBalance use
(!isYV12(clip)) ? clip : ConvertToRGB(clip, matrix=matrix)
ColorBalance(last, red_shadows, green_shadows, blue_shadows, \
red_midtones, green_midtones, blue_midtones, \
red_highlights, green_highlights, blue_highlights,\
keep_luma, clone_gimp,false)
#-------- displayed info or no
(!show_info)? last : \
last.Subtitle("RED" + " Midtones range : " + string(midtones_size)+\
"\nShadows Values : "+String(r_shadows)+ " Midtones Values : "+String(r_midtones)+" Highlights Values: "+String(r_highlights)+\
"\nShadows Values Diff : "+String(dr_shadows)+ " Shadows ColorBalance Corr : "+String(red_shadows)+\
"\nMidtones Values Diff : "+String(dr_shadows)+ " Midtones ColorBalance Corr : "+String(red_midtones)+\
"\nHighlightss Values Diff : "+String(dr_shadows)+ " Highlights ColorBalance Corre : "+String(red_highlights),\
y=40,lsp=20)\
.Subtitle("GREEN" +\
"\nShadows Values : "+String(g_shadows)+ " Midtones Values : "+String(g_midtones)+" Highlights Values: "+String(g_highlights)+\
"\nShadows Values Diff : "+String(dg_shadows)+ " Shadows ColorBalance Corr : "+String(green_shadows)+\
"\nMidtones Values Diff : "+String(dg_midtones)+ " Midtones ColorBalance Corr : "+String(green_midtones)+\
"\nHighlightss Values Diff : "+String(dg_highlights)+ " Highlights ColorBalance Corr : "+String(green_highlights),\
y=160,lsp=20)\
.Subtitle("Blue" +\
"\nShadows Values : "+String(b_shadows)+ " Midtones Values : "+String(b_midtones)+" Highlights Blue Values: "+String(b_highlights)+\
"\nShadows Values Diff : "+String(db_shadows)+ " Shadows ColorBalance Corr : "+String(blue_shadows)+\
"\nMidtones Values Diff : "+String(db_midtones)+ " Midtones ColorBalance Corr : "+String(blue_midtones)+\
"\nHighlightss Values Diff : "+String(db_highlights)+ " Highlights ColorBalance Corr : "+String(blue_highlights),\
y=280,lsp=20)
(!isYV12(clip)) ? last : ConvertToYV12(last, matrix=matrix)
(!show_masks)? last : StackHorizontal(shadows.Subtitle("Shadows"), midtones.Subtitle("Midtones"), highlights.Subtitle("highlights"))\
.BilinearResize( width(clip), height(clip))
return last """, args = "keep_luma, clone_gimp, matrix, midtones_value, midtones_size, show_info, show_masks")
(!show_masks)? last : BilinearResize( 3*width(clip), height(clip))
Bernardd is offline   Reply With Quote
