Old 21st July 2007, 20:06   #61  |  Link
MysticE
Originally Posted by MrC View Post
You're right! NTSC requires 480 pixel vertical resolution.
@MysticE
Forget my suggestion... I really need a holiday...
Bye
Don't get me wrong, I love your program. The whole pulldown thing just confuses me. I'm using your app (with HCenc) to convert PAL (25fps) sources (music vids), AVI, MPG, and VOBs to 16:9 NTSC. The ability to tweak the script, set my bitrates, and trim vertically is great. Easy and quick, the results are wonderful.
Don't mean to be a pest, thanks again.
MysticE is offline   Reply With Quote
Old 22nd July 2007, 15:57   #62  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Too many compliments! I'm becoming red...
Remember: any suggestions how to improve AVStoDVD are welcome
Bye
________
volcano vaporizer
MrC is offline   Reply With Quote
Old 29th July 2007, 13:07   #63  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
AVStoDVD release 1.0.1 is available.
Change log:
  • Some bugs fixed
  • MediaInfo updated to 0.7.5.0
  • Improved Help Content
  • Revised max bitrate automatic calculation
  • Added 2CoreEnc for Dual Core CPU systems (QuEnc only supported to be configured manually)
  • Added "convertfps=true" for video DirectShowSource to support VFR video streams (WMV, ASF, MKV)
DGPulldown option and subtitles support are coming with release 1.1.0. Stay tuned!
Bye
________
DR750SE
Old 29th July 2007, 19:07   #64  |  Link
MysticE
Cool, looking forward to trying it.
Grazie
Old 1st August 2007, 19:48   #65  |  Link
gus8511q
Change log:
  • Some bugs fixed
Bye
thnks man, you are the best
im looking forward to release srt support
thnks again
gus8511q is offline   Reply With Quote
Old 2nd August 2007, 11:29   #66  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@MysticE and everyone interested in
DGPulldown support enabled in release 1.1.0 beta.
Could you please try it and give me your opinion. DGPulldown can be selected in Settings/Encoding/FPS Upsize.
Bye
________
buy silver surfer
Old 2nd August 2007, 15:51   #67  |  Link
bionic
And you added a gops option too..excellent
Testing as i post.
Edit:
so far so good, no problems noticed here
bionic is offline   Reply With Quote
Old 5th August 2007, 14:20   #68  |  Link
gus8511q
Testing as i post.
Edit:
one problem with your programm is that i cant use 2 avi files for input to make 1 dvd...
Old 5th August 2007, 14:55   #69  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Yes you are right, it is not AVStoDVD's purpose (for now...). It would require some menu handling, and I want to upgrade a little bit AVStoDVD's capabilities in MPEG2 encoding before entering that world
Bye
________
launch box vaporizer
Old 8th August 2007, 02:28   #70  |  Link
boywondr16
Error in HCenc
**banging head against monitor**
I've run into a complete block--every time I try to us AVStoDVD with HCenc as the encoder, I'm met with "ERROR: can't open log file".
I've tried multiple different movies...I've tried CCE instead, and got a garbled mess...I even tried rolling back to no codecs and reinstalling.
I'm getting nowhere fast with this. Any ideas? Please?
**abject begging**
boywondr16 is offline   Reply With Quote
Old 8th August 2007, 08:17   #71  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
**abject begging**
No panic please! Let's try to understand what's the problem.
1. Which AVStoDVD release are you using? I hope 1.0.1.
2. Which HCenc release are you using? You should use at least 0.17.
3. When do the message "ERROR: can't open log file" come out?
4. What do you mean got a garbled mess when using CCE SP?
5. Have you tried using QuEnc If yes, any problem?
6. Can you copy&paste the AVStoDVD log file?
7. Have you installed every codec needed to play the clip you want to convert?
________
mexico city hotel
Old 8th August 2007, 21:19   #72  |  Link
boywondr16
Nah. No panic. Just frustration. Forgive my post being less than informational, but it was the last thing I did before crashing for the night...
Correct
0.21
It appears shortly after HCenc appears. In other words, HCenc pops up ready to encode, sorts out the file info, and then gives the error message.
Using one of the same files, I attempted using CCE and the resulting video looked like a scrambled cable TV channel. That was before I unregistered all codecs and reinstalled.
No. Personal preference. So, that's one thought...
I will include in next post...
Yeah, even going as far as unregistering all and installing the K-Lite Codec Pack.
Old 8th August 2007, 21:37   #73  |  Link
boywondr16
Here's the log, but I've still not figured out anything from it/them...
<8/8/2007 2:35:04 PM>
JOB START
<8/8/2007 2:35:05 PM>
JOB SETTINGS
Source Video file: D:\My Videos\Documentaries\CNN Presents - In the Footsteps of bin Laden (2006.TVRip.SoS)\CNN Presents - In the Footsteps of bin Laden (2006.TVRip.SoS).avi
Source Audio file: D:\My Videos\Documentaries\CNN Presents - In the Footsteps of bin Laden (2006.TVRip.SoS)\CNN Presents - In the Footsteps of bin Laden (2006.TVRip.SoS).avi
MPEG2 Encoding Options: Very High Quality (Low Speed)
MPEG2 Encoder: HCenc
DVD Video Format: NTSC
DVD Video Aspect Ratio: 4:3
DVD Video BitRate: 6159 (8000) kbps
DVD Audio Format: AC3
DVD Audio BitRate: 192 kbps
DVD Audio Language: EN - English
DVD Chapters Interval: 5 min
Delete temp process files: Yes
Save Log file: Yes
Shutdown system when process complete: No
Output Folder: M:
DVD Output Setup: DVD Folder
SOURCE FILES
Video: D:\My Videos\Documentaries\CNN Presents - In the Footsteps of bin Laden (2006.TVRip.SoS)\CNN Presents - In the Footsteps of bin Laden (2006.TVRip.SoS).avi
Info: AVI (XviD) - 906 kbps - 640x480 - 4:3 - 29.979 fps - 1:35:24 hours - 171560 frames
Audio: D:\My Videos\Documentaries\CNN Presents - In the Footsteps of bin Laden (2006.TVRip.SoS)\CNN Presents - In the Footsteps of bin Laden (2006.TVRip.SoS).avi
Info: AVI (MPEG-1 Audio layer 3) - 95 kbps - VBR - 44100Hz - 2ch - 1:35:24 hours
AVISYNTH SCRIPT
Video = DirectShowSource("D:\My Videos\Documentaries\CNN Presents - In the Footsteps of bin Laden (2006.TVRip.SoS)\CNN Presents - In the Footsteps of bin Laden (2006.TVRip.SoS).avi", convertfps=true)
Audio = DirectShowSource("D:\My Videos\Documentaries\CNN Presents - In the Footsteps of bin Laden (2006.TVRip.SoS)\CNN Presents - In the Footsteps of bin Laden (2006.TVRip.SoS).avi")
AudioDub(Video, Audio)
ConvertToYV12
ChangeFPS(29.97)
LanczosResize(720,480,0,0.5)
SSRC(48000)
EnsureVBRMP3Sync()
<8/8/2007 2:35:30 PM>
JOB COMPLETED.
Attempting QuEnc, currently...
Old 9th August 2007, 08:25   #74  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@boywondr16
Yes, you are right, no clues from the log file. It seems a "very standard" job, xvid+mp3 to DVD.
Let me know if QuEnc works.
Another try could be removing the codec pack (I really do not like that mess) and install ONLY the codecs you need (i.e. XviD and MP3) or the all-in-one ffdshow.
IMO ffdshow is the best choice: you get rid of all single codecs and have very good encoding/decoding quality.
Bye
________
Zodia
Old 9th August 2007, 09:31   #75  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Originally Posted by landseer945 View Post
Why not other good converter software.
Like this Daniusoft Video Converter?
Just one BIG reason: it is not free...
And you are OT
Bye
________
VTX1300R
Old 9th August 2007, 23:42   #76  |  Link
boywondr16
QuEnc worked, which makes the whole thing even more odd...
Oh, well...adjustment and on I go. I will try again with ffshow later, and remove the KLCP.
Old 10th August 2007, 07:27   #77  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Another try: select HCenc as default encoder, save settings and the copy&paste the txt content of AVStoDVD.ini file you find in AVStoDVD installation folder.
However, when encoding @ 6157 kbps, the encoder really do not make any difference.... so you can go with QuEnc.
Bye
________
box vaporizers
Old 10th August 2007, 19:35   #78  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
AVStoDVD release 1.1.0 is available.
Change log:
  • Moved Postprocessing Options to Settings Window
  • Moved MPEG2 Advanced Options to Main Window
  • Added "Close All GOPs" among MPEG2 Advanced Options
  • Added DGPulldown support (exe included in the installer)
  • Added text subtitles multiplexing
  • Added Spline16Resize and made Lanczos4Resize as default
  • Added consistency check on source files at job startup
  • Changed default DVD sizes from 4438/8876 to 4435/8870 for subtitles support
  • Revised resizing procedure in AVS Script
  • Improved log activity saving
There are many changes, so I'm expecting some bugs too...
As usual, comments and suggestions are welcome.
Bye
________
extreme q vaporizer
Old 11th August 2007, 00:16   #79  |  Link
boywondr16
OK...I've given up trying to reshape my codecs mess and did a clean install of Windows XP. Installed K-Lite Codec Pack clean.
In using QuEnc, I'm now getting errors related to the AudioDub commands.
Here's the latest log:
<8/10/2007 5:10:05 PM>
JOB START
JOB SETTINGS
Source Video file: D:\My Videos\PBS Frontline - News War - Complete 4 Part Series - 2007 [SoS]\PBS Frontline - News War, Part 1of4 - Secrets, Sources and Spin, Part I.m4v
Source Audio file: D:\My Videos\PBS Frontline - News War - Complete 4 Part Series - 2007 [SoS]\PBS Frontline - News War, Part 1of4 - Secrets, Sources and Spin, Part I.m4v
MPEG2 Encoder: QuEnc
MPEG2 Advanced Options: Progressive - Auto GOPs - No Matrix
DVD Video Aspect Ratio: 16:9
DVD Video BitRate: 9500 (9500) kbps
DVD Audio Format: MP2
Save Log file: Yes
Output Folder: C:\Documents and Settings\Troy\My Documents
DVD Output Setup: Muxed MPEG2
SOURCE FILES
Video: D:\My Videos\PBS Frontline - News War - Complete 4 Part Series - 2007 [SoS]\PBS Frontline - News War, Part 1of4 - Secrets, Sources and Spin, Part I.m4v
Info: isom (H.264) - 450 kbps - 512x288 - 16:9 - 29.97 fps - 54:35 minutes - 98161 frames
Audio: D:\My Videos\PBS Frontline - News War - Complete 4 Part Series - 2007 [SoS]\PBS Frontline - News War, Part 1of4 - Secrets, Sources and Spin, Part I.m4v
Info: isom (AAC) - 51 kbps - VBR - 24000Hz - 1ch - 54:35 minutes
Subs:
AVISYNTH SCRIPT
Video = DirectShowSource("D:\My Videos\PBS Frontline - News War - Complete 4 Part Series - 2007 [SoS]\PBS Frontline - News War, Part 1of4 - Secrets, Sources and Spin, Part I.m4v", convertfps=true)
Audio = DirectShowSource("D:\My Videos\PBS Frontline - News War - Complete 4 Part Series - 2007 [SoS]\PBS Frontline - News War, Part 1of4 - Secrets, Sources and Spin, Part I.m4v")
ConvertToYV12
#Using DGPulldown to upsize FPS
Lanczos4Resize(352,240)
SSRC(48000)
START VIDEO ENCODING OPERATIONS
QuEnc (Video) Parameters: -i "C:\DOCUME~1\Troy\LOCALS~1\Temp\PBS Frontline - News War, Part 1of4 - Secrets, Sources and Spin, Part I_AVStoDVD.avs" -o "C:\Documents and Settings\Troy\My Documents\PBS Frontline - News War, Part 1of4 - Secrets, Sources and Spin, Part I_AVStoDVD.m2v" -b 9500 -maxbitrate 9500 -2 -hq -vbr -aspectratio 16:9 -nointerlaced -mpeg2mux noaudio -dc 10 -priority 5 -auto -close
<8/10/2007 5:10:12 PM>
JOB COMPLETED.
Old 11th August 2007, 11:17   #80  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Good idea!
Which kind of errors? When you play your m4v file on WMP, do you get same message?
Bye
________
pot news
[IMG] code is Off
