11th September 2009, 17:00 | #561 | Link |
Programmer (or just 教务长)
I agree... and I agree more about PGSs were not supposed to be used for 'fancy' animations in the first place.
I wish one of you gifted guys had more time to take a closer look to IGS... (not that there is a free-tool to mux them into a menu m2ts file, but still). Dean |
11th September 2009, 17:39 | #562 | Link | ||
Author of BDSup2Sub
Well, the basic decoding/drawing stuff is very similar to PGS, but the interactivity makes everything much more complicated. Besides: IGS can't be simply converted to/from something else. So what would the input/output be? |
11th September 2009, 18:25 | #563 | Link |
Yes, you're one of the gifted guys for sure!
And about IGS... You have: input: * Image (active, inactive, action-state) * Coordiantes in selected plane (1920x1080) * Actions, associated with active/action states (ordinary navigational commands, used in movieobject.bdmv) output: Elementary stream, describing RLE encoded navigational graphics + palette with their attributes (x, y, actions) (max 15 per menu page, tho each page can have multiple 'sub-pages' of IG elements) Dean |
11th September 2009, 19:05 | #564 | Link |
Author of BDSup2Sub
I meant which input format for a command line tool to create an IGS stream or what output format to convert an IGS stream to. Creating a full featured IGS WYSIWYG editor is surely beyond the scope of any freeware tool.
11th September 2009, 19:13 | #565 | Link |
Okay, then a CLI can handle creation of IGS by accepting a bunch of PNGs/BMPs (like max 15 of them) as input files, reserving space for navigational commands and outputting the elementary stream.
Sure it seams simple, but there is no tool that can do it. Not to say that there is no muxer to mux the IGS (at least at the moment - but I'll think of something). Dean |
27th September 2009, 22:03 | #566 | Link |
Just a suggestion for the GUI and the drop-down with resolutions:
Since you know the bottom right x,y of each subpicture, would you add a semi-detection of the imported .sup so it won't always default to 720x576? (if y is the bottom right Y coordinate) Something simple as: default res=480 (checks performed in this exact order) y>480 - res=576 y>576 - res=720 y>720 - res=1080 It will be useless to use the width but it may help if bdsup2sub detects widths >720 or >1280 to refine the decisions after y coordinate is processed. |
27th September 2009, 23:01 | #567 | Link |
AVCHDCoder developer
Hello
After some time I decided to use your app in AVCHDCoder. But i am not been able to hook up BDSub2Sub to AVCHDCoder which is also written in java. I was unable to find the starting point when I add your jar as an external Library. I cannot figure out how to convert a pgs to pgs. (Downscaling) When I use the commandline version I get other problems. Because you wrapped it as a jar I get the following problems: Because your commandline gives no information on when it is ready I am unable to detect when the conversion is complete. (BDSub2Sub converts but no progress information) Techniques like looping and see if the filesize changes doesn't work. When I wrap you jar into an exe I am also unable to point the main class. The gui shows up with the exe but the commandline doesn't work ('"F:\NetBeansProjects\AVCHDCoder\Tools\BDSup2Sub\BDSup2Sub.exe"' is not recogniz ed as an internal or external command, operable program or batch file.) Maybe some problems are related to the fact that you placed some files in the default package instead of a package. (Always put java files in packages). As far as my knowledge goes I don't know a solution. Maybe you can help me? I do have an idea. You can pack your jar (because you have the source) into an exe file as Command Line application. (Launch4j) This way you can use System.out.println() to deliver progress information. Now you also don't have the java -jar problem on 64 bit Vista/7 (Know problem, you have to manually point to javaw in order to use the commandline) Thanx! |
27th September 2009, 23:51 | #568 | Link |
Author of BDSup2Sub
@Dean:
IMHO, there is no way to determinate the target resolution, as it's a user choice. How would I know from looking at the source (which has a known and fixed resolution) which target resolution the user wants to select??? I could maybe make the last choice persistent or add a command line option "/res:keep" (just like for fps), but that's about it. Or maybe I didn't really understand your request or maybe it's just too late right now. @twazerty: The best way to use BDSup2Sub from another Java app would be to use the whole JAR as a library. Then you can import functions from the BDSup2Sub classes like from any other library, e.g. Code:
import deadbeef.SupTools.Core; import deadbeef.SupTools.CoreException; import deadbeef.Tools.Props; import deadbeef.Tools.ToolBox; This approach is used by "ToNMT UI" AFAIK. If you need help, I could create an example, but probably not before Tuesday. Last edited by 0xdeadbeef; 28th September 2009 at 00:15. |
28th September 2009, 10:08 | #569 | Link | |
What I meant to say (and got confused) is to auto-select the source resolution in the drop-down list when loading a sup file and not always default to 720x576. It is not important at all anyway... I just started looking at .sup format yesterday with an idea for a small cli tool for resizing/repositioning... |
28th September 2009, 11:17 | #570 | Link |
Author of BDSup2Sub
Hm, for SUP/IFO, the resolution is read from the IFO as far as I remember - so it's not fixed to PAL, but maybe there's a bug. Also most probably it defaults to PAL if the info from the IFO is inconsistent or missing.
Problem is that I only own PAL DVDs. I'll try to have a look at this with an NTSC sample later this week when I have time. Or are you suggesting to use the (DVD)-SUP format for higher resolutions? That is a little problematic as - in contrary to SUB/IDX - there is no way to define the resolution explicitly. The IFO only has predefined values for standard resolutions. |
28th September 2009, 11:42 | #571 | Link |
No, I was talking about BD SUP files...
I created a small .cmd file and associated .sup files with it so I can double click a bd sup file and open it in bdsup2sub: Code:
java -jar d:\multiavchd\tools\bdsup2sub.jar %1 :-) |
28th September 2009, 15:03 | #572 | Link | |
28th September 2009, 21:42 | #573 | Link | |
Author of BDSup2Sub
Hope this helps: http://www.sendspace.com/file/80y622 This is basically a version from BDSup2Sub which consists only of one base class which uses all the functionality from the JAR. This is the whole Eclipse project folder, but maybe you need to change the properties after moving it to another folder. Last edited by 0xdeadbeef; 28th September 2009 at 21:53. |
28th September 2009, 21:52 | #574 | Link |
I don't want to waste your time on the subject
What I was trying to say is that when I load a file in BDsup2sub and I'm presented with a window to chose resolution/framerate and other options, but the default (target) resolution is always 720x576. I was just asking if you can make it honor the input BD-SUP resolution (like you do with the framerate) and have it as default. |
28th September 2009, 22:16 | #577 | Link |
Author of BDSup2Sub
Honestly, the main reason for the PAL default is that I use BDSup2Sub only to convert BD SUPs to PAL SUB/IDX. So it's unlikely that I will simply default to the input resolution for the target.
Then again, there are probably more clever ways to handle this. I'll try to think of something when I have a little more time. Maybe next weekend or so. |
29th September 2009, 01:36 | #578 | Link |
too much lurking
I too agree that it would be nice to see BDSup2Sub remembering more of my previous selections upon restart: such as resolution and location of source files. I almost never use it for anything aside from converting BD Sup's to 720p sub/idx so it would be nice if the tool remembered that. After some certain point (I can't recall which version) BDSup2Sub defaults to (remembers?) the language I normally select, English, which has been much appreciated.
29th September 2009, 11:28 | #579 | Link | |
Author of BDSup2Sub
For the conversion options (like target resolution, target fps, scaleX/Y), I guess I will implement a "Use as default" and "Restore factory settings" button and additionally add the "/res:keep" command line option. This is probably a misconception. BDSup2Sub reads the language from the input stream (if this is possible) and uses it as default. If the stream doesn't contain any language information (e.g. BD-SUP), it tries to determine the language by looking at the name of the input stream. If it contains e.g. "English", it defaults to English. |
3rd October 2009, 10:21 | #580 | Link |
Hello there,
I discovered your awesome tool a few weeks ago. Thumbs up for your great work an level of support! I use it to move subtites into the 2.35 AR area since I use a scaler to view 2.35 movies to avoid black borders on top and bottom of my screen. Because it is painful to demux, move subs, remux etc, manually, I wanted to do some automation, the way Clown BD makes it (EAC3->BDSup2Sub->TsMuxeR), using CLI in a batch file. But (there is allways a but ) I noticed a strange behaviour: Here is an example with the "Largo Winch" French BR: 1. The GUI way: - the original sub ist hosted here: http://www.sendspace.com/file/2r8r1f - using the GUI it works flawlesly, with following parameters: - it ends up with a correctly processed file, sampled here: http://www.sendspace.com/file/nkgu7n The problem comes up when I want to use CLI-operation for doing the same task. 2. The CLI way: - I call BDSup2SUb using the following command-line: "C:\Program Files\Java\jre6\bin\java.exe" -Xmx256m -jar "D:\BDSup2Sub\BDSup2Sub.JAR" "'D:\HD-RIP\Largo Winch\*.sup' 'D:\HD-RIP\Largo Winch\*.sup' /res:1080 /movin:2.35,24 /verbatim+" >"D:\HD-RIP\Largo Winch\BDSup2SubLog.log" - and I end up with a corrupted file sampled here: http://www.sendspace.com/file/32zz0p where the bitmaps appear to have disapeared starting at sub nr 59. - I hosted the log file here: http://www.sendspace.com/file/tz0rlk Did I something wrong? Or is this an issue in BDSup2Sub CLI-support? Last edited by Kratus; 3rd October 2009 at 10:29. |
