25th March 2009, 11:46 | #3021 | Link |
I have 1.2.9
history http://www.videohelp.com/tools/tsMuxeR/version-history I think I will test all Versions until I find the first not working version. Ich think tsmuxer sets a wrong flag while muxing, because PCH and Onkyo TX-SR805 show both that they want to stream/decode DTS-HD Master (in some versions even Dolby Digital...), not High Resolution
Popcorn Hour B-110 Onkyo TX-SR 805 |
25th March 2009, 11:47 | #3022 | Link |
@roman76r
I don't know if you noticed, or anyone else reported this: Code:
the ASPECT RATIO in the tsMuxeR (incl 1.8.35) is incorrectly set to 4:3 instead of 16:9 on SD video streams. |
25th March 2009, 18:07 | #3026 | Link | |
Now I continue to implement "restore cropped video". Most part of the code already written. So, total progress (include debuging) near 40-50%. |
25th March 2009, 20:18 | #3027 | Link |
Roman, I can't wait for the restore cropped video. That should be a real nice addition as many MVK's are cropped (why I do not know) just as why do they release them as MKV's instead of either m2ts or BD structure. All the PH and PS3 will play m2ts files and as more people are buying BD standalone players that is the future. Sure the MKV file size is smaller but for all the people who alrady have a BD player we have to reencode now to add back the cropped bars to make them BD compliant. Hopefully with your addition that will not be needed anymore
26th March 2009, 00:31 | #3031 | Link | |
26th March 2009, 00:59 | #3033 | Link | |
26th March 2009, 01:21 | #3034 | Link | ||
shon3i
But some frames will be with artifacts (where is large ref frames is used). |
26th March 2009, 08:17 | #3035 | Link |
Is anybody able to define exactly what is the difference between the two muxing options of "Blu-ray disk" and "AVCHD disk"?
I understand the differences on an elementary stream level but I would like to know what exactly is changed when muxing... ? |
26th March 2009, 08:21 | #3036 | Link |
@Roman76r. Are you able to resolve the interlaced HD VC-1 video stream issue ?
http://forum.doom9.org/showthread.ph...10#post1259310 All Versions Upto V1.8.22: Code:
"E:\TVIX\tsMuxeR\tsMuxeR_1.8.22(b)\tsMuxeR.exe" "S:\BDMV\STREAM \00000.m2ts" SmartLabs tsMuxeR. Version 1.8.35(b) http://www.smlabs.net Track ID: 4113 Can't detect stream type Track ID: 4352 Stream type: DTS-HD Stream ID: A_DTS Stream info: Bitrate: 1536Kbps DTS core + MLP data. Sample Rate: 48KHz Channel s: 6 Stream lang: deu Track ID: 4353 Stream type: DTS-HD Stream ID: A_DTS Stream info: Bitrate: 1536Kbps DTS core + MLP data. Sample Rate: 48KHz Channel s: 6 Stream lang: eng Track ID: 4608 Stream type: PGS Stream ID: S_HDMV/PGS Stream info: Presentation Graphic Stream #0 Stream lang: deu BDInfo & eac3to correctly identify this as a VC1 1080i/25 |
26th March 2009, 08:28 | #3037 | Link | |
I don't know, as I've not tried it. but this is what it should do: . the version number in the headers should be 1 for AVCHD (2 for blu-ray) eg HDMV0100 instead of HDMV0200 . the directory structure is slightly different . the files are limited to 4gb in size (FAT32) . the filenames are in 8.3 format (FAT32) you can see here http://forum.doom9.org/showthread.php?t=141361
Blu-Ray Movie Only Copies : Clown_BD Blu-Ray Movie Only DVD Conversion : Clown_BD Blu-Ray Copies With Menus : Clown_BD BD Copier Last edited by mrr19121970; 26th March 2009 at 08:30. |
26th March 2009, 10:14 | #3038 | Link | |
Life's clearer in 4K UHD
http://forum.doom9.org/showthread.ph...10#post1261710 Cheers
26th March 2009, 10:43 | #3039 | Link | |
mrr19121970
there is another important difference: AVCHD descriptor are stored in index.bdmv file. Without this descriptor PS3 does not recognize AVCHD disks. Quote:
tsmuxer |
