8th July 2009, 17:17 | #23 | Link |
AviSynth plugger
SEt,
The question from plugins writer: is plugins compiled with your new modified 2.5.8MT header avisynth.h 100% compatible with older versions of Avisynth (2.5.6-2.5.7), including non-MT ? (my previous versions of MVTools and other plugins used old avisynth.h from Avisynth v2.5.5 for wide compatibility)
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. Last edited by Fizick; 8th July 2009 at 17:22. |
8th July 2009, 19:28 | #24 | Link |
It's as compatible as the header from official Avisynth 2.5.8.
The only additional problem you can get with my header is with compiling InterlockedIncrement -> _InterlockedIncrement mapping (depending on included headers and their order this can be redefinition). This is pure minor performance optimization for VS and that #if section can be safely removed without affecting the correctness. If you want to use older header - just apply the difference of my header with official 2.5.8 without the end of IScriptEnvironment and "friend class CacheMT;" as these are MT-specific additions (won't harm even if present in header as long as you don't call them). Last edited by SEt; 8th July 2009 at 19:34. |
9th July 2009, 18:34 | #25 | Link | |
AviSynth plugger
OK. Thanks. I will do it in next release
void Release() { VideoFrameBuffer* vfb_local = vfb; if (!InterlockedDecrement(&refcount)) InterlockedDecrement(&vfb_local->refcount); } For example, is IsWritable and GetWritePtr code thread-safe?
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. |
9th July 2009, 23:47 | #26 | Link | |
void Release() { VideoFrameBuffer* vfb_local = vfb; if (!InterlockedDecrement(&refcount)) InterlockedDecrement(&vfb_local->refcount); } Code:
void Release() { if (!InterlockedDecrement(&refcount)) InterlockedDecrement(&vfb->refcount); } Quote:
In general i don't like at all how this Read-Write state of frames work in current Avisynth - such things should be completely inside Avisynth itself, not in every plugin. Only than you would be able to say that they are thread-safe. I have several suggestions for radical changes in Avisynth plugin API and now is good time for them - i think version 2.6 can drop backward compatibility for easier to use, safer for threading and internally flexible (like caching implementation) without every plugin recompilation API. |
10th July 2009, 17:45 | #27 | Link |
AviSynth plugger
1. In my personal opinion (from user and plugin developer's point of view), we may broke plugins 2.5 compatibility in nearest Avisynth version only as a follows:
by providing new command LoadNewPlugin for new API plugins, and preserve LoadPlugin for old 2.5 API plugins. (So, do not break nothing, but do not provide much support of new features to old API) 2. probably we can return to discussion about roadmap of Avisynth, while IanB live in real life (may be hunting for crocodiles in Australian rivers If you have not only suggestions, but also some time to implement your suggestions (with some discussion), you are welcome to contribute to some new version branch, for example 2.7. (Ask Wilbert for sourceforge access as a team member.) 3. May be I am complitely wrong both in 1 and in 2 points above (it was hot day).
11th July 2009, 06:49 | #28 | Link |
AviSynth plugger
SEt, in meantime, can you provide (for me) some scenarios, showing thread-safety-notsafety of code fragments above?
11th July 2009, 13:45 | #29 | Link |
void Release() { if (refcount==1) InterlockedDecrement(&vfb->refcount); InterlockedDecrement((long *)&refcount); } Two threads are holding this object so refcount=2. They at the same time call Release(). Condition (refcount==1) is false for both, after that both decrement refcount and it becomes 0, but no one decrements vfb->refcount. Code:
void Release() { if (!InterlockedDecrement(&refcount)) InterlockedDecrement(&vfb->refcount); } Code:
void Release() { VideoFrameBuffer* vfb_local = vfb; if (!InterlockedDecrement(&refcount)) InterlockedDecrement(&vfb_local->refcount); } |
11th July 2009, 21:12 | #31 | Link |
AviSynth plugger
SEt, thanks.
Next question. One user reported a problem with your build of Avisynth2.5.8MT with the crazy script, including AnimeIVTC: http://forum.ixbt.com/topic.cgi?id=29:9331-153#4577 Version 2.5.7MT and official 2.5.8 works without this problem.
11th July 2009, 22:33 | #32 | Link |
AnimeIVTC is so monstrous that it's unusable i'd say. There are also several problems.
One of them is Cdeblend - it doesn't (always) work in official 2.5.8 too. Here is the patch: Code:
--- Cdeblend_v1.1b.avsi 2007-05-18 16:40:16.000000000 +0400 +++ Cdeblend_v1.1b.avsi 2009-07-12 06:34:31.155704600 +0400 @@ -66,8 +66,6 @@ btemp = default(dclip,input) global blendclip= (fnr==false ? btemp : clense(btemp)).bilinearresize(int(width(btemp)*xr)*8,int(height(btemp)*yr)*8) -rate = framerate(input) - ###### masking ###### diff = mt_makediff(blendclip, blendclip.trim(1,0)) global mask = mt_lutxy(diff, diff.trim(1,0), yexpr="x 128 - abs y 128 - abs < x 128 - abs x y + 256 - abs < & x 128 - abs x 128 - abs 0.5 ^ - 2 ^ y 128 - abs x y + 256 - abs < y 128 - abs y 128 - abs 0.5 ^ - 2 ^ x y + 256 - abs x y + 256 - abs 0.5 ^ - 2 ^ ? ? x 128 - y 128 - * 0 > -1 1 ? * 128 +", uexpr="x", vexpr="x") @@ -129,6 +127,6 @@ mode > 1 ? scriptclip(output, "evaluate(LumaDifference(blendclip.trim(1,0),blendclip.trim(3,0)), AverageLuma(mask.trim(1,0)))") : \ scriptclip(output, "evaluate(LumaDifference(blendclip,blendclip.trim(2,0)), AverageLuma(mask))") -recl = last.changefps(rate*2).changefps(rate,linear=true) -return(recl.addborders(0,0,8,0).crop(0,0,-8,-0)) +recl = changefps(FrameRateNumerator(), FrameRateDenominator(), linear=true) +return recl } The other one i remember is EEDI2 distributed with it is built with very buggy OpenMP runtime. Just rebuilding solves the problem of random crashing. Last edited by SEt; 18th July 2009 at 16:16. |
12th July 2009, 01:14 | #33 | Link |
AviSynth plugger
here is the simplest broken script with 2.5.8MT:
blankclip return changefps(23.976)
12th July 2009, 05:04 | #34 | Link |
Problem fixed, see the first post for updated version.
Notes: lol, of course it will break if you change things like Code:
union { float f; unsigned i; } value; mantissa = (value.i & 0x7FFFFF) + 0x800000; // add implicit bit on the left Code:
union { double f; unsigned i; } value; mantissa = (value.i & 0x7FFFFF) + 0x800000; // add implicit bit on the left |
12th July 2009, 06:34 | #35 | Link |
AviSynth plugger
OK, thanks! It works now. But I do not see updated source code.
EDIT - now I see it (fps.cpp) (firstly i missed your point about rolling back, not modifying) (Oh, those warnings... )
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. Last edited by Fizick; 12th July 2009 at 06:45. |
12th July 2009, 09:53 | #36 | Link |
Didée Fan
Interesting thread. No real points to make but i would like to thank SEt for his fine efforts in this stuff.
I have done some tests with the tsp and set and my versions here: link. I just wanted you to see for something interesting to eyeball. I know I like to read such things. Anyway, keep up the interesting good work Mr. SEt.
When I get tired during work with dvd stuff i think of River Tamm (Summer Glau's character). And the beauty that is Serenity. |
12th July 2009, 10:08 | #37 | Link | |
Avisynth language lover
On a different note (prompted by seeing the Cdeblend code above): do ScriptClip and friends work reliably under MT Avisynth? Can different threads interfere with each other when setting 'current_frame'? |
13th July 2009, 17:25 | #38 | Link | |
ffdshow/AviSynth wrangler
I do have 2 weeks of vacation come next week, so I'll be taking a look at it then. np: Tortoise - Charteroak Foundation (Beacons Of Ancestorship)
now playing: [artist] - [track] ([album]) |
16th July 2009, 21:04 | #39 | Link | |
Didée Fan
I found these files were not the same in the src. stdafx.h avisynth.cpp avisynth.h cache.cpp cachemt.cpp main.cpp mt.cpp mt.h softwire_helpers.cpp expression.cpp color.cpp convolution.cpp edit.cpp focus.cpp greyscale.cpp histogram.cpp layer.cpp layer.h levels.cpp merge.cpp planeswap.cpp resample.cpp resize.cpp transform.cpp source.cpp ____________ pfc folder string.cpp utf8.cpp Softwire folder assembler.cpp instructionset.cpp operand.cpp japan src SEt july 12 src ultraedit. sw I used to compare click the ultraedit link, go to product tour and highlight the "Save time by comparing your files to track editing changes. show/hide". IT will show you how to use the compare feature in this sw. You open two files, then click the blue "uc" globe icon. When the compare screen opens then you press the arrow icon to go where the different code is. I have to compare the distribute folder now and then go to my src and then the official 2.5.8 src so I will be updating this post later. I did not compare the directshowsource or tcpdeliver files as I did not build these so didn't fiddle with their files. Edit, I have now finished comparing the japan and SEt src and distrib folder and the changes are in the list above. These are the files with different code. ________________________________________________________________ Edit, I have redone the test with my src. My src is really SEt july 12 src but with a few files changed. Which files you ask? It's at the bottom of the edit below. I tried to use ultraedit to compare the official avisynth 2.5.8 to both the japan and SEt src and mine too but it was all garbage and I couldn't get it done. So I redid the work above but used my src instead of the one used before, cause I wanted too. You probably see more files in the list below. I was more careful this time cause I knew how to do it right after the first try in the list above. Anyway, below is the files changed in the SEt july 12 avisynth src from the original Japan avisynth mt src from way back when: Audio folder audio.cpp: lines 1400, 1450 avs-soundtouch.cpp: line 86 supereq.cpp: line 165 Convert folder core folder avisynth_c.cpp: lines 123 cache.cpp: lines 39, 514, 523, 533, 553, 824 cachemt.cpp: lines 295 main.cpp mt.cpp: lines 102, 200, 284 mt.h: line 82 softwire_helpers.cpp: line 68 core parser folder expression.cpp: lines 87, 93, 691 filters folder color.cpp: lines 129, 169, 176, 209 convolution.cpp: line 216 edit.cpp: lines 404, 474, 596, 859, 878, 887, 896, 905, 914, 923, 933, 946, 959 focus.cpp: lines 339, 481, 486, 725, 753, 1088, 1104, 1132, 1148 greyscale.cpp: line 95 histogram.cpp: lines 495, 507, 548, 582, 604, 667, 674, 694, 698, 709, 713, 775, 782, 792, 810, 818, 824, 829, 837, 843, 847, 864, 870, 876, 883, 890 layer.cpp: lines 514, 1005, 2300 layer.h: line 160 levels.cpp: lines 136, 143, 277, 299, 952, 1057 merge.cpp: lines 94 planeswap.cpp: line 348 resample.cpp: lines 331, 379, 410, 437, 470, 1705 resize.cpp: lines 260, 272 transform.cpp: lines 149, 159, 382, 385, 390, 395, 398, 403, 435, 441, 452, 456, 511 filters overlay, conditional folders sources folder source.cpp: lines 90, 96 sources, avi folder AVIReadHandler.cpp: line 1287 Note: Changes in the src tested from the SEt july 12 avisynth src. change 1.) The main src folder, not the src subfolders, is from my src. These are mainly settings for when I use visual studio to compile the dll, vcproj and other such files. Change 2.) I also put the avisynth.cpp and avisynth.h files from my src into the SEt july 12 src. Change 3.) Also I used the distrib, include: softwire, soundtouch, pfc files from my src. other than that, the rest of the files were from the SEt july 12 avisynth src. I'm sorry I changed so many files.
When I get tired during work with dvd stuff i think of River Tamm (Summer Glau's character). And the beauty that is Serenity. Last edited by Jeremy Duncan; 17th July 2009 at 13:27. |
18th July 2009, 16:45 | #40 | Link |
I've reviewed only changes between the version where this casting was added and previous one. Other files changes seems harmless.
The real problem is: why AVSValue stores floating point values as float, function named AsFloat, but returns double? I think it creates confusion for plugin writers too. Updated ffdshow patch - commented out identifying as cache because in current Avisynth cache and MT gates are inseparable and you'll probably want to change MTMode right after it. Updated Cdeblend patch: now it almost works with SetMTMode(5) - it can still process some first frames wrong due to inefficient caching after changefps(linear=true). The general problem there: script has to use global variables to store previous LumaDifference results what breaks in case of out of order frame access typical for multithreaded modes. Solution would be introducing something like cached "clip" with numbers. |
