25th December 2016, 23:59 | #3041 | Link |
Selur,
The audio tab is missing "configuration save and apply" buttons
Asus ProArt Z790 - 13th Gen Intel i9 - RTX 3080 - DDR5 64GB Predator - LG OLED C9 - Yamaha A3030 - Windows 11 x64 - PotPlayerr - Lav - MadVR |
26th December 2016, 10:41 | #3044 | Link |
The "GeForce GTX 670MX" should still be detected as compatible card for nvenc, it that is not the case for you, what does the Hybrid log mention. My guess is for some reason the name inside the registry changed.
-> need details. |
26th December 2016, 12:06 | #3045 | Link | |
Well, it just only detects my Intel HD 4000 (Quick sync), it is not that version only, it has not detected since the last version, I use a Clevo P151 notebook, with Intel HD 4000 and Nvidia GTX 670MX. Older versions still work, much like StaxRip works, but the Hybrid does not, nor does it appear for selection.
26th December 2016, 12:12 | #3046 | Link |
Hybrid checks the registry 'Device Description' entries under "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Video" to find the video cards available.
My guess is that for some reason your NVIDIA card isn't listed there or it is, but under a name that Hybrid doesn't recognize. -> What entries are there on your system? |
26th December 2016, 12:18 | #3047 | Link |
It has 3 entries. All Intel HD 4000. Maybe reinstall nvidia driver help me.
Well, I removed all the intel and nvidia drivers I had installed and with the native Windows 10 drivers, the Nvenc option reappeared. Last edited by Havokdan; 26th December 2016 at 12:41. |
26th December 2016, 23:57 | #3049 | Link | |
fontSize=15 toolTipFontSize=15 However, I don't have this problem in previous version. Is there another way to enlarge the window of hybrid? I have 60" panel and the default window size is really small. It's really hard to see
28th December 2016, 07:35 | #3051 | Link |
Thanks that did it!
I was just wondering about the ff: 1. Why queuing entries are deleted when you restart hybrid? 2. Why can't the user change the settings / preset once the video has been moved job queue ? Is this a limitation of the software used or your mere preference? Thanks a lot to all your work!
28th December 2016, 10:27 | #3052 | Link |
Is it possible to include in the first tab, somewhere near the box in which we chose the input file, an option to choose the input method? Something like Avisynth and its various options (L-smash source, ffmpeg2source and others) As well as those who do not use avisynth.
28th December 2016, 17:24 | #3053 | Link | ||||
a. Hybrid selects the method to handle the input based on a best guess and restriction model, this will not change. Especially since I don't see any useful case for this. b. You want to select from mencoder, mplayer, ffmpeg, all avisynth source filters and all vapoursynth source filters and then complain if you selected a filter that isn't fit for your input? c. since avisynth and vapoursynth are optional adding them to the main tab would just bloat the size of the tab. Cu Selur |
28th December 2016, 18:43 | #3054 | Link | |
28th December 2016, 18:47 | #3055 | Link |
Then use StaxRip or if you have some criteria which allows to identify those sources that require a specific input method share that info and I can look into using that selection method in Hybrid.
Cu Selur |
28th December 2016, 21:00 | #3056 | Link | |
If the image did not appear, it was using the source filter to use such a LWLibAVVideoSource, either with avisynth+ or vapoursynth in StaxRip, at the time did not know where to make that change in the Hybrid. Last edited by Havokdan; 28th December 2016 at 21:04. |
28th December 2016, 21:41 | #3059 | Link |
you can simply ignore those errors, deleted two parameters that weren't used anymore.
(will probably release a new version on Saturday or Sunday, which will fix this and some other minor stuff, waiting for feedback from a few users regarding some bug fixes) Last edited by Selur; 28th December 2016 at 21:43. |
