25th January 2007, 17:03 | #81 | Link | |
Pig on the wing
What I mean is that people are encouraged to do quite the incorrect things with the functions. I know Didée doesn't like that much, and considering the fact that he's done a lot for the Avisynth community, I'd really listen to his advice EDIT: I hope that "casting pearls before the swine" isn't directed at me
25th January 2007, 21:48 | #82 | Link |
Didée Fan
Merlin7777,
No, I googled it and found it myself. foxyshadis, The version you made is nice. HeadBangeR77, You must understand. Didée, and Foxyshadis, might want to see what people have done with their work. I know what it's like to see a new post in my thread, so I like to add nice stuff, what I think is nice, to other peoples threads. I'm sorry I'm aggravating you. Here's what I've done with Seesaw, LSF, and Soothe. I made one with Soothe and LSF, just so you know in case you wanted to see that. Just download the folder, look at the FFDshow configurations and compare the pictures; Pictures showing the Detail quality of the different configurations. Updated January 25, 2007 The rules say there is no best, Boulder. What you linked to in no way makes my work with Didée's stuff ant less important than the fine stuff anybody else has done with it. Because there is no best according to the rules. Didée is happy that I'm happy with the results. That's all that's important. In case your wondering why I keep deleting my posts. I'm scared I'm going to get the lash if I have more than one post in this thread. |
26th January 2007, 01:32 | #83 | Link | |
Could someone soothe () this thread, so it does make sense again?
"Only two things are infinite: the universe and human stupidity, and I'm not sure about the former."
26th January 2007, 17:49 | #84 | Link |
Angel of Night
No, mods don't sweep up threads, except to clean up flamewars or occasionally to update a badly out-of-date first post. The best route is to create an entirely new thread with as much pertinant information in the post as possible. I'm beginning to warm to the idea of a FAQs forum, at least as long as the wiki is down/readonly. (Although the soothe entry is live.)
27th January 2007, 14:54 | #85 | Link | |
Although I must admit that using Soothe(s,d,100) isn't the same as not using Soothe at all (yes, I've made some samples), one thing here troubles my mind: Since "keep" is an integer, range 0 - 100, that tells how much percent of the original sharpening will be kept at least, then orig.avi < soothe(-100) < soothe(100) < sharp.avi is correct. Soothe always soothes, even if we tell her to stop. On the other hand, even with negative values, the function will never fully undo the sharpening effect. Why then soothe(15) > soothe(100) ??? This is too much for my exhauste humanistic brain.
29th January 2007, 13:13 | #86 | Link |
Oh, oh-oh ... that's because I used the Soothe function of SeeSaw, which has the parameters inversed (in SeeSaw the meaning is not "keep", but rather "strength") ... Standalone Soothe doesn't even use "negative" values.
In this respect, it's all a big mess with Soothe. Agreed. Worse is, that I shouted at Jeremy without a reason: When using the Standalone function of Soothe, then Soothe(100) in fact IS THE SAME as not using Soothe ... Jeremy was right, and I stumbled in my own trap.
29th January 2007, 14:32 | #87 | Link |
Thanks for clearing, now I get it. A true genious is always a bit absent-minded, isn't he?
OT: Is Soothe (function) he/ she/ or it in english? The problem with this simplified-long-forgotten-anglo-saxon-bad-pronounced-latin-distorted-french-language is, that almost noone teaches grammatical genders, so I don't have the flexibility I've got in german or in polish.
27th March 2007, 01:53 | #88 | Link | |||
at first i have to thank you for your great filters Didée! I played with Soothe and asked myself how it would be possible to use use soothe in combination with the inbuild resizer of LSF. I after hours of thinking how it could work, i came up with this idea: Quote:
Regards McCauley EDIT:After some addititonal toying with it, i realized that i make sharpening a bit useless with the first one and found these settings satisfiing: Quote:
14th July 2007, 05:51 | #90 | Link | |
warpsharpened
function Soothe(clip sharp, clip orig, int "keep") { Assert(sharp.width == orig.width && sharp.height == orig.height, \ "Soothe: clip dimentions must match!") keep = default(keep, 24) keep = (keep>100) ? 100 : (keep<0) ? 0 : keep KP = string(keep) diff = mt_makediff(orig,sharp) diff2 = diff.temporalsoften(1,255,0,32,2) diff3 = mt_lutxy(diff,diff2, "x 128 - y 128 - * 0 < x 128 - 100 / " + KP \ + " * 128 + x 128 - abs y 128 - abs > x " + KP \ + " * y 100 " + KP + " - * + 100 / x ? ?") return( mt_makediff(orig,diff3,chroma="copy first") ) } Get mt_masktools v2 here. (latest one is this one.) Throw that in plugins folder too. Not sure if this one needs removegrain. (don't think so, anyone?) |
14th July 2007, 17:09 | #92 | Link | |
first of all thanks, can u tell what version? i need to download because there are so many v2 versions Thanks... Thanks to Boulder as well. |
23rd October 2007, 12:04 | #95 | Link |
Posts: n/a
Any help, how i have to use soothe and LSF with this script?
i'm using megui to make my script. @ should i call soothe avs or avsi in my plugin dir? DGDecode_mpeg2source("C:\Documents and Settings\Vesi\Desktop\HDDCS-Test\Test.d2v",info=3) ColorMatrix(hints=true,interlaced=true) #Not doing anything because the source is progressive crop( 2, 92, -2, -72) BicubicResize(640,272,0,0.5) # Bicubic (Neutral) Last edited by Vesi; 23rd October 2007 at 12:18. |
23rd October 2007, 14:50 | #96 | Link | |
Learning
Also check here whether you actually require colorcorrection or not (i doubt it is required) |
23rd October 2007, 22:28 | #97 | Link | |
Posts: n/a
Thanks alot salehin, i have few questions.
1.how do i know that my source is rec 709, and i don't need colorcorection? 2.o Resolution: Always use mod16 resolution for your output? please make it a bit clear, coz i'm new Quote:
23rd October 2007, 22:56 | #98 | Link |
Angel of Night
DGIndex and the d2v has that information. If it doesn't, colormatrix won't do anything with hints=true, don't worry. (Never use it if you're making a DVD from a DVD, though, unless you change the colormatrix in your encoder's advanced settings.) Mod16 isn't required, but it's preferred unless you have to really go out of your way to get it.
23rd October 2007, 23:56 | #99 | Link | |
Learning
Load the source file onto DGIndex (version 1.4.9+) and do a preview. You'll find the colorimetry info there. Always use AvsP for previews to be more certain (with and without CM). It gives a very good preview- impacts of using various filters. o Detailed reason behind mod16 (quoting check): Encoders work in blocks of 16x16. They can subdivide into smaller blocks below this (16x8, 8x8 and 4x4), but the encoder requires 16x16 blocks. If the size is not mod16, the encoder will simply duplicate the edge pixels, encode those instead and the decoder will not display them on playback. Instead of encoding non-mod16, resize to mod16 and set the correct AR in the matroska file. Then you have the correct AR and a more compressible movie o LSF and Soothe: I have updated the links (re: LSF and soothe eg) o Resize filter: May I also suggest you try Spline36neutral or Lanczos (Sharp). I tend to prefer spline36neutral as it gives as good results as lancsoz sharp, in some cases, slightly better than Lanczos (Sharp) Last edited by salehin; 24th October 2007 at 00:21. Reason: added info |
24th October 2007, 10:34 | #100 | Link |
Posts: n/a
foxyshadis and salehin thank you guys for the replays.
- I did open my source with DGIndex and found it BT.470-2 B,G, so in this case i don't need colorcorection, am i right? @ salehin please don't get angry on me , i releay don't get this mod16, should i change this in megui before i start my rip? please explain it in some simple words as i'm noob and bad english . is this the right way to make script soothe with LSF? dull = last sharp = dull.LimitedSharpenfaster( ss_x=1.25, ss_y=1.25,smode=4, strength=150, overshoot=1 ) Soothe( sharp, dull, 20 ) Tweak(sat=1.2,bright=-8,cont=1.3) Or any other ways too? Last edited by Vesi; 24th October 2007 at 11:01. |
