10th December 2011, 15:36 | #7641 | Link | |
anyway, they are stored in the registry. goto "HKEY_CURRENT_USER\Software\DScaler5\MpegVideo Filter" in regedit and edit what you want. or you could paste the following into a .reg file (edit if you want before hand) then merge to the registry by double clicking. Code:
Windows Registry Editor Version 5.00 [HKEY_CURRENT_USER\Software\DScaler5\MpegVideo Filter] "Display Forced Subtitles"=dword:00000001 "3:2 playback smoothing"=dword:00000000 "Inverse Telecine"=dword:00000001 "Change FPS"=dword:00000000 "Deinterlace Mode"=dword:00000000 "Video Delay"=dword:00000000 "Use accurate aspect ratios"=dword:00000000 "DVB Aspect Preferences"=dword:00000000 "Hardcode for PAL with ffdshow"=dword:00000000 "IDCT to Use"=dword:00000002 "Colour space to output"=dword:00000000 "Do Analog Blanking"=dword:00000001 "Force Field 1 first Flag"=dword:00000000 |
10th December 2011, 16:03 | #7642 | Link |
Thank you very much, dear nevcairiel for a change, I'm sorry that bother you, just found the problem and decided to report it, but please do not forget to adjust the settings window LAV Audio Decoder opening in Windows XP, go to Start \ All Programs \ LAV Filters.
10th December 2011, 18:48 | #7643 | Link |
So, now that madvr has dxva deinterlacing, would it be possible to implement hardware acceleration using openvideodecode?
or is the api too hard to work with? also, is this amd specific, or would it work with ivy bridge in the future? Last edited by mindbomb; 10th December 2011 at 18:59. |
10th December 2011, 19:09 | #7644 | Link | |
Its an API invented by AMD, what makes you think Intel would support it any time?
10th December 2011, 19:17 | #7645 | Link |
i was thinking because intel is adding support for opencl, so it may work, but it looks like openvideodecode is specifically for uvd, right?
is it like really hard to work with, since i think the coreavc attempted to add it in their decoder, but they ended up just using dxva instead. Last edited by mindbomb; 10th December 2011 at 19:47. |
10th December 2011, 21:08 | #7646 | Link |
OpenVideoDecode is stupid. It's not any easier than DXVA, it requires the use of OpenCL, for which AMD offers no Direct3D9 interop at the moment, it doesn't support deinterlacing and it's strictly AMD, only. NVidia's CUDA Decoding solution is much better, it's much easier to use than DXVA, it offers CUDA access with Direct3D9 interop and it does support deinterlacing. Furthermore, NVidia is very fast at GPU -> System RAM copy, while AMD is very slow with that. NVidia's solution: All good. AMD's solution: All bad. Sorry, but that's the honest truth.
10th December 2011, 21:25 | #7648 | Link |
Here's your new browser homepage:
http://code.google.com/p/lavfilters/issues/detail?id=47 |
11th December 2011, 01:29 | #7650 | Link |
And that's pretty much a safe bet until he comes out and says "it's done". You'll not miss it being announced when he's finished it, I'm quite sure. Either it'll be in a special build to try it out, or, it'll be in the release notes for a future version.
11th December 2011, 18:03 | #7652 | Link | |
AMD was really to late to this Open ecosystem idea with exclusive NDA stuff and resheduling realeases over and over (to be exact 2 years to late) also this gave Intel time to catch up which also buildup a big High Quality ecosystem like Nvidia did early on Though ATI/AMD where always straight on implementing stuff directly from their Labs into their Drivers like the Realtime Deshaking,adaptive sharpening and so on
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 11th December 2011 at 18:24. |
11th December 2011, 19:13 | #7653 | Link | |
I don't use mpc-hc. To be honest I didn't even know there was a problem's using other players. Sagetv player does exactly what graphstudio does.. except it inserts EVR as video tenderer. What is DEP by the way?
PS: As an additional performance enhancement, I changed default colorspace to yv12 instead of yuy2. Im still trying to make my mind up yo use ivtc=when flag detected or ALWAYS. "Always" has better results for ivtc but seems to adversely affect true Video based material. Quote:
11th December 2011, 19:31 | #7654 | Link |
could you please try if this VC-1 video plays? doesnt for me (was only a first try though). its from the latest BBC blu-ray: http://www.mediafire.com/?vhxgz1qwxmc2u6b
edit: nvm it does, its ffdshow raw video which creates trouble.
Laptop Lenovo Legion 5 17IMH05: i5-10300H, 16 GB Ram, NVIDIA GTX 1650 Ti (+ Intel UHD 630), Windows 10 x64, madVR (x64), MPC-HC (x64), LAV Filter (x64), XySubfilter (x64) (K-lite codec pack) Last edited by Thunderbolt8; 11th December 2011 at 19:37. |
12th December 2011, 01:03 | #7655 | Link |
what's the difference or affect of choosing mpeg-2 under lav video "codecs for hardware decoding" versus under the formats tab? I only ask cause I finally got dscaler5 to more or less work with mpc-hc for 24fps on soft telecined dvds, and figured I probably want to disable one or both of these?
12th December 2011, 01:13 | #7656 | Link |
If you don't select mpeg-2 under the formats tab, LAV Video will never accept mpeg-2, neither for software nor hardware decoding. If you turn off mpeg-2 in "codecs for hardware decoding" LAV Video will decode mpeg-2 in software mode.
12th December 2011, 01:36 | #7657 | Link |
thx. on further inspection, it doesn't seem to matter - mpc uses the dscaler decoder, probably because the merit is higher.
funny thing is, dscaler seems to have been around for years. Wonder why its ivtc capabilities never made it into ffmpeg? |
12th December 2011, 02:35 | #7658 | Link | |
It's a Windows security thing ; most modern processors also have it on HW level. See http://windows.microsoft.com/en-US/w...ked-questions# I still can't use the Dscaler decoder IVTC because of this... Some players don't require DEP, for example with Zoomplayer I can access the Dsaler dec properties, but they don't retain on my system. Even not after changing the Dscaler setting directly in the registry. I'm out of ideas how to use it in MPC-HC. Unless a MPC-HC version with DEP requirements disabled comes along, I'm pretty sure it's plain *impossible* to use the Dscaler decoder. |
12th December 2011, 02:40 | #7659 | Link | |
have you tried disabling DEP in your system BIOS? (that is, if your system has the option...) |
12th December 2011, 02:46 | #7660 | Link | |
I mean the decoder loads in the graph and can decode MPEG-2, but the IVTC is not enabled. I can't enable it because accessing the properties always crashes MPC. What OS are you running ? I've W7 Professional x64 SP1. |
