1st November 2011, 11:18 | #11382 | Link |
Your wav file have a wrong header:
File ........: D:\Internet\audio 32bit float.wav Size ........: 1152068 bytes ---------------------------------------------- Header Info ChunkID .....: RIFF RiffLength ..: 1152060 Container ...: WAVE SubchunkID ..: fmt (Length: 40) AudioFormat .: 65534 (WAVE_FORMAT_EXTENSIBLE) NumChannels .: 6 SampleRate ..: 48000 ByteRate ....: 1152000 BlockAlign ..: 24 BitsPerSample: 32 ValidBitsPS .: 0 MaskChannels : 63 (FL FR FC LF BL BR) SubType .....: 3 (Float) SubchunkID ..: data (Length: 1152000) Offset data .: 68 Duration ....: 1 sec., (0h. 0m. 1s.) ------------------------------------------------- End Info You can hexedit the wav file and put at offset 38 the correct value 32 (hex 20) or fix the file with WavFix: wavfix "audio 32bit float.wav" -m 0 Add the parameter -ignorelength if your wav file is greater than 4 GB. After that eac3to can read the file.
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 1st November 2011 at 11:29. |
1st November 2011, 12:43 | #11383 | Link |
What program did you use to see that information? I want to use it.
Also why the header is wrong? I used audition to get that. Also, if I output as 32bit float it doesn't work but if I output as 32bit integer, it works. (using adobe audition to output. Works means eac3to can read the file) |
1st November 2011, 14:03 | #11384 | Link |
Hi can someone please confirm for me what exactly the bug is with different versions of Arcsoft DTS Decoder, ?
Is it 1.1.0.5 or 1.1.0.0 for 6.1/6.0 audio and 1.1.0.8 for anything else ? Some people claim that 1.1.0.0 is the best for 6.1/6.0 but others claim 1.1.0.5 is best because 1.1.0.0 lacks many bug fixes ? I found the following pieces of information around doom9 forums but i'm still confused to which version to use to avoid any bug ? - 1.1.0.0 can decode DTS(-HD) 6.1/6.0 but can't decode non-standard 7.1 - All versions above v1.1.0.0 do not accurately decode 6.1 DTS tracks with eac3to. - 1.1.0.8 can't decode DTS(-HD) 6.1/6.0 but can decode non-standard 7.1 - Both decode DTS(-HD) 1.0 correctly, unlike 1.1.0.7. lossy DTS 1) 1.1.0.0 and 1.1.0.1 always decode lossy DTS as 24 bit, and their decoding results differ from each other. 2) 1.1.0.5 and up decode in proper bitdepth. 3) Versions 1.1.0.5 and up decode lossy DTS identically. 4) 1.1.0.1 and 1.1.0.5 decode 24 bit lossy DTS identically. 5) Decoding of 16 bit lossy DTS was changed from 1.1.0.0 to 1.1.0.1 and from 1.1.0.1 to 1.1.0.5. 6) 1.1.0.7 and 1.1.0.8 decode 6.0 without back center channel. The conclusion : for lossy DTS is 1.1.0.5. It decodes all configurations, in proper bitdepth, and decoding algorithm didn't change since this version (except 6.0 bug in .7 and .8). Last edited by dream88; 1st November 2011 at 14:16. |
1st November 2011, 20:58 | #11386 | Link | |
Banned
2nd November 2011, 00:02 | #11387 | Link | |
- lossy DTS don't have bitdepth, then you can't recover the original bitdepth source. The data in header only inform about the source bitdepth but this data is useless for 2 reasons: 1) Some encoders put always 24 bits in this field no mather the source was 16 or 24 bits. 2) The error recovering the lossy encode is greater than the precission difference betwen 16 and 24 bits, then it makes no sense decode to 16 or 24 bassed in source bitdeph, decode always to 24 bits and you obtain always the best approach.
2nd November 2011, 18:31 | #11388 | Link | ||
2nd November 2011, 19:13 | #11389 | Link |
tebasuna51, what you said is not correct.
I did another test. You said that it was because of wrong header. Well as I said, 32 float was not recognized and 32 integer was recognized by eac3to. So I passed a 32 integer to your tool LeeAudBi and the header is the same incorrect way as you say but it works. audio 32bit integer.wav ChunkID .....: RIFF RiffLength ..: 1152060 Container ...: WAVE SubchunkID ..: fmt (Length: 40) AudioFormat .: 65534 (WAVE_FORMAT_EXTENSIBLE) NumChannels .: 6 SampleRate ..: 48000 ByteRate ....: 1152000 BlockAlign ..: 24 BitsPerSample: 32 ValidBitsPS .: 0 MaskChannels : 63 (FL FR FC LF BL BR) SubType .....: 1 (Integer) SubchunkID ..: data (Length: 1152000) Offset data .: 68 Duration ....: 1 sec., (0h. 0m. 1s.) I attached the file here. Test it with eac3to and it is recognized so that header problem you mentioned is not the problem. There must be another problem within eac3to. |
3rd November 2011, 02:31 | #11390 | Link | |
Maybe eac3to don't check this field with int samples, because it make the test to know the real bitdepth of the source, with float sample must know the alignement.
But, how do you explain than changing only this field with a hexeditor the float file is read without problems? You can read about this field here: http://msdn.microsoft.com/en-us/wind...dware/gg463006 Quote:
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 4th November 2011 at 11:15. Reason: explain int/float check |
4th November 2011, 15:52 | #11391 | Link |
Source is 24bit TrueHD track, i want to convert it to 16bit flac or DTS but i'm getting this error
command line: eac3to.exe" "E:\THD.thd" "E:\flac16.flac -down16" ------------------------------------------------------------------------------ TrueHD, 5.1 channels, 48kHz This audio conversion is not supported. <ERROR> |
6th November 2011, 17:27 | #11394 | Link | |
Now I am using BeSplit to cut sections and eac3to to insert o delete (with delay) in the beginning. This works but BeSplit is not maintaned, and there are also some bugs. And i post, also, a feature request: Extract a ac3 segment to a new file. |
7th November 2011, 19:44 | #11395 | Link |
Pig on the wing
How does normalization work when doing a multichannel to multichannel transcode? Is it even useful to apply or will it only mess the balance between the channels?
8th November 2011, 19:19 | #11397 | Link |
AVCHDCoder developer
HDV 4 ch audio not detected (Mpeg 2 Layer 3)
In the professional world there is a problem regarding the HDV format with 4 audio channels. For example the Sony S270 which I have access to. This is a professional camera which is able to record a 4ch audio stream. When you want to import the footage of the camera to your computer you are unable to access the 4ch audio file inside the M2T file (MPEG-TS). And big names like Vegas, Avid, etc aren't able to see/extract the 4ch audio stream. Only the second stereo stream will be available. On the camera itself you are able to access all 4 audio channels. This is a problem that all camera's have that record in HDV with 4 channels and there isn't a solution from the manufactures. The only way is via SDI but it is very time consuming and HDD hungry (3GB/s).
Applications like MediaInfo and all video players can only access the second audio stream (or a backwards compatible stream but I am not sure of this). This is the mediainfo log: Code:
General ID : FF Complete name : J:\HDVTest 4ch\00_0002_2010-11-07_214302.M2T Format : MPEG-TS File size : 138 MiB Duration : 44s 160ms Start time : UTC 2010-11-07 21:43:02 End time : UTC 2010-11-07 21:43:07 Overall bit rate : 26.2 Mbps Maximum Overall bit rate : 33.0 Mbps Encoded date : UTC 2010-11-07 21:43:02 Video ID : 2064 (0x810) Menu ID : 100 (0x64) Format : MPEG Video Format version : Version 2 Format profile : Main@High 1440 Format settings, BVOP : Yes Format settings, Matrix : Default Duration : 44s 320ms Bit rate mode : Constant Bit rate : 24.0 Mbps Nominal bit rate : 25.0 Mbps Width : 1 440 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 25.000 fps Standard : Component Resolution : 8 bits Colorimetry : 4:2:0 Scan type : Interlaced Scan order : Top Field First Bits/(Pixel*Frame) : 0.617 Stream size : 127 MiB (92%) Audio ID : 2068 (0x814) Menu ID : 100 (0x64) Format : MPEG Audio Format version : Version 1 Format profile : Layer 2 Duration : 44s 208ms Bit rate mode : Constant Bit rate : 384 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Video delay : -232ms Stream size : 2.02 MiB (1%) Code:
eac3to v3.24 command line: "c:\Program Files (x86)\AVCHDCoder\Tools\eac3to\eac3to.exe" "J:\HDVTest 4ch\00_0002_2010-11-07_214302.M2T" -demux ------------------------------------------------------------------------------ TS, 1 video track, 2 audio tracks, 0:00:44, 50i 1: MPEG2, 1440x1080 50i (16:9) 2: E-AC3, unknown parameters 3: MP2, 2.0 channels, 384kbps, 48kHz, -264ms Bitstream parsing for track 2 failed. <WARNING> Demuxing this track may still produce correct results - or not. <WARNING> [a02] Extracting audio track number 2... [v01] Extracting video track number 1... [a03] Extracting audio track number 3... [v01] Creating file "00_0002_2010-11-07_214302 - 1 - MPEG2, 1440x1080 50i.m2v"... [a03] Applying MPx delay... [a03] Creating file "00_0002_2010-11-07_214302 - 3 - MP2, 2.0 channels, 384kbps, 48kHz.mp2"... Video track 1 contains 1107 frames. eac3to processing took 1 second. Done. Code:
MPEG-1 Part 3 AL 2 Stereo (2-channel) at 384 kbit/s (192 kbit/s per channel); optional MPEG-2 Part 3 AL 2 4-channel at 96 kbit/s per channel. Currently eac3to extracts the m2v and 2ch audio stream fine. Only the 4 channel stream isn't detected nor extracted. I uploaded 2 sample to my server for analysis: http://tools.twanwintjes.nl/uploads/...-07_153401.M2T (49 seconds / 152MB) - Right Click --> Save As http://tools.twanwintjes.nl/uploads/...-07_214302.M2T (44 seconds / 137MB) - Right Click --> Save As In addition to the main problem the camera splits a recording into 4GB chunks. So sync issues are a problem according to the professionals. Note: I do not own this professional camera. I professional camera guy I know came to me with this problem and he owns a camera. If you are willing to support HDV and you need more material like other resolutions/framerates/interlaced/progressive with only 2ch or combined with a 4ch audio track. We can deliver test footage. We are sure many people are looking for a solution. Companies like Sony do not offer a software solution, also this problem is still available on new camera's. Additional info Last edited by twazerty; 13th November 2011 at 23:02. |
9th November 2011, 11:54 | #11398 | Link |
Why does eac3to and mkvextractgui2 output different file sizes?
h264 track demuxed from mkv: eac3to 18 341 959 089 mkvextractgui2 18 341 843 800
Windows 10 Pro 2004 with Media Center, 2 x DVB-C with cable cards MPC-HC (madVR, LAV Filters, XySubFilter) Sony Bravia 85X950H/85XH95 Yamaha RX-V685 Yamaha Piano Black NS-777/555/C444/YST-SW315 Last edited by Joniii; 9th November 2011 at 11:56. |
13th November 2011, 05:18 | #11399 | Link | ||
I'm trying to convert a Dolby TrueHD 1.0 track to FLAC, and I keep getting the following error.
ffmpeg -i japanese.thd -ac 1 -acodec pcm_s24le -f wav japanese.wav And got the following error: Quote:
eac3to |
