21st November 2015, 21:45 | #13701 | Link | |
Encode/Decoder Nero7 NeroDec Faad Qaac ffmpeg --------------- ------ ------- ---- ---- ------ 2.0-nero.m4a - Ok +33 Ok Ok 5.1-nero.m4a - Ok +33 Ok Ok 2.0-qaac.aac +22 - +22 +44 +44 2.0-qaac.m4a - Ok +22 Ok Ok 5.1-qaac.aac broken - +22 +44 +44 5.1-qaac.m4a - Ok +22 Ok Ok 2.0-qaac-ND.aac -21 - -21 Ok Ok 2.0-qaac-ND.m4a - 0 -21 Ok Ok 5.1-qaac-ND.aac broken - -21 Ok Ok 5.1-qaac-ND.m4a - 0 -21 Ok Ok ND = qaac --no-delay parameter -21 = first frame cutted +x = ms of silence delay added 0 = first frame silenced - = Not supported
21st November 2015, 22:33 | #13702 | Link | ||
tests are for 2.0 Code:
process-decoder\coder nero qaac default qaac --no-delay samples ms samples ms samples ms m4a-faad 1600 33,33 1088 22,67 -1024 -21,33 m4a-ffmpeg 0 0 0 0 0 0 aac-eac3to&faad 1600 33,33 1088 22,67 -1024 -21,33 aac-ffmpeg 2624 54,67 2112 44 0 0 aac-mp4-faad 1600 33,33 1088 22,67 -1024 -21,33 aac-mp4-ffmpeg 2624 54,67 2112 44 0 0 aac-mkv-eac3to 1600 33,33 1088 22,67 -1024 -21,33 aac-mkv-ffmpeg 2624 54,67 2112 44 0 0 mkv w delay-eac3to -1040 -21,67 -1024 -21,33 mkv w delay-ffmpeg -448 -9,333 -960 -20 mkv-eac3to -1472 -30,67 -1984 -41,33 -1024 -21,33 mkv-ffmpeg -448 -9,333 -960 -20 0 0 ts-eac3to 1600 33,33 1088 22,67 -1024 -21,33 ts-ffmpeg 2624 54,67 2112 44 0 0 m4a - initial encode aac - demux from m4a with mp4muxer aac-mp4 - remuxed back with mp4muxer, initial headers got stripped aac-mkv - mkvtoolnix 8.5.2 was used mkv w delay - m4a to mkv with additional track - container delays, 20ms for default qaac, 9ms for nero ts - muxed from m4a with tsmuxer 1.10.6 versions: eac3to 3.30, nerodec 1.5.1.0, neroenc 1.5.4.0, qaac 2.55-7.10.5.0, ffmpeg N-76417-gee20354, faad 373248B conclusions: encoders: nero - 2624 samples initial delay, qaac - 2112 by default faad don't give a damn about m4a header faad & eac3to both kill first frame (1024samples) nero & ffmpeg (and foobar) -ok in m4a mkv muxing from m4a tries to compensate coder delays by killing a few frames. and then adding a delay. or not adding when it's a single track which leads to -960 samples with qaac when properly decoded or almost 2k with nero7 frame drop foobar is using ffmpeg engine so results are identical ffmpeg (with foobar) don't count mkv delays neroaacdec & ffmpeg results are identical too Last edited by kukushka; 21st November 2015 at 23:41. |
22nd November 2015, 03:42 | #13703 | Link |
@kukushka
Maybe we can open a new thread to speak about AAC and muxer/demuxer's (Mp4Muxer/Mp4Box/MkvToolnix/tsMuxeR), but the relevant questions for this thread are clear: - The directshow Nero 7 decoder, used by eac3to to decode .aac, cut the first 1024 samples (21,333 ms in 48 KHz) in 2.0 and is broken for 5.1. Take in mind the problem. EDIT: after more test the cuts are unpredictables (from 0 to 54 ms) - The encoder NeroAacEnc.exe, user by eac3to to encode .m4a, put the correct delay to compensate and can be decoded without problems with NeroAacDec, Qaac or ffmpeg. No problem with it. - eac3to works fine extracting AAC from MKV/TS/M2TS containers, I obtain the same aac than I muxed previously. Then, to avoid problems, you can use eac3to to extract and Qaac or ffmpeg to decode (or LWLibavAudioSource inside AviSynth).
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 9th January 2016 at 13:09. |
22nd November 2015, 12:38 | #13704 | Link |
Anime addict
Hi, folks. I purchase bluray and get this errors with eac3to:
M2TS, 1 video track, 5 audio tracks, 6 subtitle tracks, 1:49:25, 28.878p 1: Chapters, 12 chapters 2: h264/AVC, 1080p24 /1.001 (16:9) 3: DTS Master Audio, Spanish, 5.1 channels, 16 bits, 48kHz (core: DTS, 5.1 channels, 768kbps, 48kHz) 4: DTS Master Audio, Spanish, 5.1 channels, 16 bits, 48kHz (core: DTS, 5.1 channels, 768kbps, 48kHz) 5: DTS Master Audio, Spanish, 5.1 channels, 16 bits, 48kHz (core: DTS, 5.1 channels, 768kbps, 48kHz) 6: DTS Master Audio, Spanish, 5.1 channels, 16 bits, 48kHz (core: DTS, 5.1 channels, 768kbps, 48kHz) 7: DTS Master Audio, Spanish, 5.1 channels, 16 bits, 48kHz (core: DTS, 5.1 channels, 768kbps, 48kHz) 8: Subtitle (PGS) 9: Subtitle (PGS) 10: Subtitle (PGS) 11: Subtitle (PGS) 12: Subtitle (PGS) 13: Subtitle (PGS) [a03] Extracting audio track number 3... [a03] Decoding with libDcaDec DTS Decoder... [a03] libDcaDec reported the warning "XLL output not lossless". <WARNING> [a03] Writing WAV... [a03] Creating file "E:\Bluray\DBZ BOG EXTENDED\_3spa.wav"... [a03] Skipping identical DTS frames (seamless branching)... [a03] libDcaDec output changed from 6 channels, 48kHz to 2 channels, 48kHz. <ERROR> Aborted at file position 21188608. <ERROR> Command line: "eac3to.exe" "E:\Bluray\DBZ BOG EXTENDED\" 1) 3: "E:\Bluray\DBZ BOG EXTENDED\_3spa.wav" -progressnumbers EDIT: If I use m2ts directly on eac3to, work fine. I think that is one problem of playlist. EDIT2: I ever get audio 2 channels with mt2s, but not 5.1.
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite Last edited by Overdrive80; 22nd November 2015 at 13:36. |
22nd November 2015, 13:57 | #13705 | Link |
did you check the playlist file of how many .m2ts files it consists (the file itself, not what eac3to displays)? perhaps the main .m2ts file is preceeded by some other small .m2ts file which has a 5.1 channel configuration.
22nd November 2015, 14:23 | #13706 | Link | |
Anime addict
I can extract audio track in dtshd (1,3 gb), but is impossible transcoding, ever get error.
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite Last edited by Overdrive80; 22nd November 2015 at 14:37. |
22nd November 2015, 15:13 | #13707 | Link |
then just skip that one and only work with the main movie file.
22nd November 2015, 15:29 | #13708 | Link | |
Anime addict
General Nombre completo : E:\Bluray\DBZ BOG EXTENDED\00000.mpls_3spa.dtshd Formato : DTS Formato/Info : Digital Theater Systems Formato del perfil : MA / Core Tamaño del archivo : 1,23GIB Modo de tasa de bits : Variable Audio Formato : DTS Formato/Info : Digital Theater Systems Formato del perfil : MA / Core Format_Settings_Mode : 16 Ajustes del formato, Endianness : Big Tipo de tasa de bits : Variable Tasa de bits : Desconocido / 768Kbps Canal(es) : 6canales Posiciones del canal : Front: L C R, Side: L R, LFE Velocidad de muestreo : 48,0KHz BitDepth/String : 16bits Compression_Mode/String : / Lossy Code:
General ID : 0 (0x0) Nombre completo : E:\Bluray\DBZ BOG EXTENDED\BDMV\STREAM\00000.m2ts Formato : BDAV Formato/Info : Blu-ray Video Tamaño del archivo : 21,8GIB Duración : 1h 49min. Modo de tasa de bits : Variable Tasa de bits total : 28,6Mbps Tasa de bits máxima : 48,0Mbps Video ID : 4113 (0x1011) ID Menú : 1 (0x1) Formato : AVC Formato/Info : Advanced Video Codec Formato del perfil : High@L4.1 Ajustes del formato, CABAC : Si Ajustes del formato, RefFrames : 4marcos ID Códec : 27 Duración : 1h 49min. Tipo de tasa de bits : Variable Tasa de bits máxima : 35,0Mbps Ancho : 1 920pixeles Alto : 1 080pixeles Relación de aspecto : 16:9 Velocidad de cuadro : 23,976fps Estándar : NTSC ColorSpace : YUV ChromaSubsampling : 4:2:0 BitDepth/String : 8bits Tipo de exploración : Progresivo colour_range : Limited colour_primaries : BT.709 transfer_characteristics : BT.709 matrix_coefficients : BT.709 Audio #1 ID : 4352 (0x1100) ID Menú : 1 (0x1) Formato : DTS Formato/Info : Digital Theater Systems Formato del perfil : MA / Core Format_Settings_Mode : 16 Ajustes del formato, Endianness : Big Modo Muxing : Stream extension ID Códec : 134 Duración : 1h 49min. Tipo de tasa de bits : Variable Tasa de bits : Desconocido / 1 509Kbps Canal(es) : 2canales Posiciones del canal : Front: L R Velocidad de muestreo : 48,0KHz BitDepth/String : 16bits Compression_Mode/String : / Lossy
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite |
22nd November 2015, 15:34 | #13709 | Link |
Life's clearer in 4K UHD
Over the last few months I've been backing-up all my multi-channel (DVD-A, Blu-Ray Audio and DTS-CD) albums to single multi-channel flac files complete with a cue file.
All had been going very well up-until this morning, when I tried to back-up my 'Don Henley - End Of The Innocence' DTS-CD. After some investigation I've determined that the problem lies with the disc's very first track, which has been encoded using 6.1 DTS-ES audio, instead of regular 5.1 DTS audio. So far I've managed to back-up the first track to a (52.6MB) dts-es.wav file. And I've also managed to extract the elementary (46.0MB) dts-es.dts stream - but now I'm stumped Ideally what I'd like to do is create a 5.1 channel flac file from the 6.1 channel dts-es source but sadly neither LameXP or UsEac3to (with eac3to v3.31) are able to do this. Does anyone have any ideas? EDIT: Here's a link to a 5 second DTS-ES sample
22nd November 2015, 16:21 | #13710 | Link | |
22nd November 2015, 16:57 | #13711 | Link |
Anime addict
Yes, I used playlist and mt2s. From playlist can only extract dts files, with m2ts can extract and transcoding but I never get audio 5.1 only 2.0. Is posible that this company had hack playlist for showing false dts 5.1?
22nd November 2015, 17:23 | #13712 | Link |
Where is it showing false information?
The first m3ts contains 5.1 audio, the second 2.0. If you extract the playlist the header at the beginning will come from the first file and show as 5.1. If you only extract from the second m2ts it will always show as 2.0, because that is what is in the file. There is no 5.1 to decode, unless you like the intro in the first m2ts enough that you'd like to keep it. Your options are to ditch the intro, or downmix the sound from it to stereo and prepend it to the audio from the second m2ts file. |
22nd November 2015, 17:45 | #13713 | Link |
Anime addict
And can not it done intentionally?? Company sold product like DTS-MA 5.1: http://www.amazon.es/Dragon-Battle-E...VR19TT8QQ27FWS (Pre-sold that I got)
I am refering to false info to:
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite Last edited by Overdrive80; 22nd November 2015 at 17:48. |
22nd November 2015, 18:37 | #13714 | Link |
in that case you could try to contact the company and tell them about it & complain, get a refund etc.
22nd November 2015, 20:12 | #13715 | Link | ||||
%_.flac -down6 Quote:
22nd November 2015, 20:50 | #13716 | Link |
I actually tried these command line parameters with UsEac3To but I get this warning: -
eac3to v3.31 command line: "C:\UsEac3to118\eac3to.exe" "C:\Users\SeeMoreDigital\Desktop\The End of the Innocence.dts" "C:\Users\SeeMoreDigital\Desktop\The End of the Innocence.dts_.flac" -down6 -progressnumbers -log="C:\UsEac3to118\UsEac3To.log" ------------------------------------------------------------------------------ DTS-ES, 6.1 channels, 0:05:13, 1235kbps, 44.1kHz Decoding with libDcaDec DTS Decoder... Mixing surround channels... Encoding FLAC with libFlac... Creating file "C:\Users\SeeMoreDigital\Desktop\The End of the Innocence.dts_.flac"... libDcaDec reported the warning "Failed to parse core extension". <WARNING> libDcaDec output changed from 7 channels, 44kHz to 6 channels, 44kHz. <ERROR> Aborted at file position 1310720. <ERROR>
22nd November 2015, 22:57 | #13717 | Link | |
Then you need split your dts in 2 parts, only the first one need the -down6 eac3to 1.dts 1.wav -down6 eac3to 2.dts 2.wav After you can concatenate the 2 wav's: sox 1.wav 2.wav full.wav And encode to flac: eac3to full.wav full.flac The problem now is split the dts. Like "Aborted at file position 1310720", maybe you can upload me 2MB and I can say you how split the dts: eac3to full.dts begin.dts -2mb
22nd November 2015, 23:24 | #13718 | Link | |
Here's a link to a 10 second DTS-ES sample. And another to the full dts-es file. Cheers
23rd November 2015, 02:08 | #13719 | Link |
@SeeMoreDigital
Is not so easy, the dts is corrupt and there are 37 frames along the full dts (13460 frames) with the BC channel unrecoverable. eac3to crash decoding with dcadec and Arcsoft. With libav produce 346 WARNINGS and the decoded wav is useless. I have succes with BeHappy decoding the dts to wav 6.1 with: LWLibavAudioSource("D:\tmp\input.dts", stream_index=0,cache=false) than use dcadec also. Here I see the 37 broken frames decoded as silence. Using Foobar2000 I get a wav 5.1 with the BC channel already mixed in BL-BR. Sound fine for me: https://www.sendspace.com/file/lw3fl1
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 23rd November 2015 at 02:12. |
23rd November 2015, 10:32 | #13720 | Link | |
So the actual dts-es elementary stream is at fault. Do you think this could this have happened when it was extracted from the .wav container using DTSParser v2. Or somewhere else? Thanks again
eac3to |
