29th March 2011, 07:46 | #101 | Link | |
I suppose i can try feeding it directly into the decoder and claiming its VC1, and see what happens..
29th March 2011, 09:23 | #102 | Link |
Nev might be interesting http://forum.doom9.org/showpost.php?...postcount=6181 especially the 12 second pattern before drops start (buffer difference ?) for some Decoder including yours
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 29th March 2011 at 09:34. |
29th March 2011, 18:34 | #103 | Link | |
http://www.megaupload.com/?d=F7S8JZO1 Thanks |
29th March 2011, 23:50 | #104 | Link |
For some reason, no matter what, this decoder will only work when I play H264 files. It doesn't work at all with any XVID files. I've disabled the MPC-HC decoder but it then just uses the Microsoft mpeg4 DMO.
EDIT: Whoops, my main card only supports featureset B. My mistake.
Running Win7 laptop with Nvidia GT120M card, 267.xx drivers. Last edited by neoufo51; 30th March 2011 at 00:57. |
30th March 2011, 00:44 | #106 | Link |
Nope, LAV CUVID decodes H264, VC-1, MPEG2 and MPEG4-ASP (DivX/Xvid) as long as you own a nVIDIA card that supports the VDPAU Feature Set C.
Cards supporting only Feature Set B or A can't decode MPEG4-ASP (DivX/Xvid) You may check http://en.wikipedia.org/wiki/Nvidia_..._.28HD.29_GPUs for a complete list of availability. Nuno
Win 11 x64, Geforce RTX 4060 Ti 16GB, TV Sony KD-55X8509C HDMI, Denon AVR-X2700H, Core i7-9700K, 32GB DDR4, Creative Labs Gigaworks S750 7.1 speakers MPC Home-Cinema madVR LAV Filters |
30th March 2011, 00:54 | #107 | Link | |
30th March 2011, 00:56 | #108 | Link | |
Running Win7 laptop with Nvidia GT120M card, 267.xx drivers. |
30th March 2011, 02:19 | #109 | Link |
Doesn't seem to be loading for me.
Using MPC and EVR-CP I blocked Microsoft DTV-DVD Decoder, made LAVCUDSFDFGFDS decoder preferred, DVD still loads with MPEG-2 Video Decoder (low merit) Last edited by JarrettH; 30th March 2011 at 02:23. |
30th March 2011, 03:06 | #110 | Link |
Yeah, it seems that using the 'Open DVD' function, and LAV CUVID isn't used (it uses the Cyberlink decoder in my case - and surprisingly, there are no Macrovision error with madVR). Only if I open the .vob file directly, LAV CUVID decoder will be used.
30th March 2011, 03:51 | #112 | Link |
@nevcairiel:
Since the time nvidia released driver newer than 258.96, DXVA and CUDA acceleration has been very choppy for me (home config), the worst is with 1080p video, with your decoder it plays like slideshow (1 frame per 4 or 5 seconds), with CoreAVC CUDA or MPC DXVA I still have it at certain positions in a video and after seek. It is really annoying that I'm thinking of changing hardware. So can you compile this decoder with an older version of CUDA SDK so I can use it with the older driver? It will be very appreciated. Also what is the current state of playback on your newer nvidia (GTS 450 I presume), is it butter smooth for any video resolution/bitrate? Thanks.
Home PC: Core i5-2400, 8GB RAM, nVidia GTX560Ti, Windows 7 64bit SP1. Work PC: Intel Xeon X3220 (Core 2 Q6600), 4GB RAM, Intel G45, Windows 7 64bit SP1. |
30th March 2011, 06:53 | #113 | Link |
Playback is perfect for me, on both my GTS 450 and my GTX 570, using either the 267.24 or 266.58 driver.
30th March 2011, 09:20 | #114 | Link | |
OpenDVD will produce MEDIATYPE_ENCRYPTEDPACK (not supported) Open VOB will produce MEDIATYPE_VIDEO
4gb DDR3/AMD Fx6300 Windows 8.1, GT750ti, Auzentech Meridian 7.1, LG 42LN5400 4:4:4 1080P LCD TV |
30th March 2011, 09:39 | #115 | Link |
@nevcairiel: Then I do hope I see you compile a version of your filter that support older graphic driver before I lost my patience and jump the gun . Don't really wanna change GFX card now as I'm going oversea sometime this year but this issue has been going for a while already and it seems to affect other with nvidia gtx 260/280 and older cards (saw a few on guru3d forum).
30th March 2011, 11:22 | #116 | Link | |
Low Power Profile High Power Profile Also what for a renderer are you using ? Also be carefull the DSP is only optimized upto H.264 1080p 60 fps if you try to playback something @ higher framerates you would need the VPx core that supports MVC
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 30th March 2011 at 11:43. |
30th March 2011, 11:33 | #117 | Link |
Thuan,
I'm using the 9800 GX2 with 267.60 driver (and previously 267.24), according to Wikipedia, should be exactly the same processing unit as the 9800 GT. No problems here... Code:
GeForce 9600 GSO, 9800 GT, 9800 GTX, 9800 GTX+, 9800 GX2 G92 VP2 A March 2008 -jj- |
30th March 2011, 11:42 | #118 | Link |
@jj666: Your OS is? I will search for and try 267.60
@CruNcher: Here's the screenshot in High Power mode My GPU is factory overclocked to 740MHz core and 1850 shader though. Driver is 266.58 ATM of testing. madVR or EVR-CP, same problem. And no, I was trying to play simple 1080p 24fps file.
Home PC: Core i5-2400, 8GB RAM, nVidia GTX560Ti, Windows 7 64bit SP1. Work PC: Intel Xeon X3220 (Core 2 Q6600), 4GB RAM, Intel G45, Windows 7 64bit SP1. Last edited by thuan; 30th March 2011 at 11:53. |
30th March 2011, 12:37 | #119 | Link |
Hmm quite low (what for System Memory you use ? Frequency,timings ?)
are these also result in playback issues (maybe even frame drops use the Youtube Info display, right click ) http://www.youtube.com/watch_popup?v...LXjA&vq=hd1080 http://www.youtube.com/watch_popup?v...Z73A&vq=hd1080 don't forget to turn hardware acceleration on
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 30th March 2011 at 12:44. |
30th March 2011, 12:40 | #120 | Link |
Note that LAV CUVID is only using pinned memory to transfer the image back from the GPU to the System RAM, as pageable memory is known to have performance problems.
