1st November 2010, 00:51 | #5841 | Link |
Can work also.
But the problem with ffaudiosource (also with ffmpeg) is the output decoder precission: 16 bits int Code:
---[NoImage] input format: Microsoft WAVE Signed 16-bit little-endian 48000 Hz 5.1-channel Code:
---[NoImage] input format: Microsoft WAVE Floating-point 32-bit little-endian 48000 Hz 5.1-channel
1st November 2010, 05:23 | #5842 | Link |
Mr. Sandman
32bit float has more or less the same "quality" as 24 bit int. if 32bit INT is going to be implemented in ffmpeg/libavcodec i'd prefer 32bit INT over 32bit float.
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 1st November 2010 at 15:26. |
1st November 2010, 12:28 | #5843 | Link |
Of course.
But the 32 bit float is the internal format of the decoders and you can't improve the quality with a conversion to 32 bit int. Also many AviSynth functions can only operate with 16 bit int or 32 bit float but not with 32 bit int. I think the best option is preserve the same sample format througth the whole process. BTW, you can implement ffaudiosource in MeGUI for AAC (and other formats not covered by NicAudio), is always better than DirectShowSource and you don't need more AviSynth plugins (BassAudio.dll, Bass.dll, Bass_aac.dll). If a user want use BassAudio always can use the .avs method.
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 1st November 2010 at 12:53. |
1st November 2010, 13:06 | #5844 | Link |
One of the main advantages of float as internal sample format would also be that you don't need to be afraid of overflows until you finally render the sample down to integer. Having a 24 bit mantissa, it won't lose much precision even for quiet scenes or calculation results (the mantissa is independent of the exponent). And some audio functions are easier to implement if they are based on normalized float values (-1.0 .. +1.0), applying them on integers might require forth-and-back conversion to float.
I speak from my experience of e.g. the "Booster" dynamic compressor in BeSweet, implemented as simple functions on normalized float samples. Last edited by LigH; 1st November 2010 at 13:08. |
1st November 2010, 15:30 | #5845 | Link |
Mr. Sandman
thanks for the explanation. i think we will go for the ffaudiosource way for coherency since we already have ffms and mencoder/ffmpeg for other tasks.
let's hope developers will increase the resolution in future updates.
2nd November 2010, 10:35 | #5846 | Link |
Hooray -- x264 is now also available with integrated audio encoders!
Sh** -- MeGUI doesn't know that, and encodes my manually created custom AviSynth scripts with audio output without adding "--acodec none", so the "qtaac encoder" gets active, but is unstable, and my AVC encode crashes. And furthermore, I would have preferred NeroAacEnc anyway. |
2nd November 2010, 11:47 | #5848 | Link |
MeGUI 0.3.5.24 -- x264 1745-1 (Jeeb)
x264.exe --fullhelp Code:
x264 core:107 r1745+311 2317302 Syntax: x264 [options] -o outfile infile Infile can be raw (in which case resolution is required), or YUV4MPEG (*.y4m), or Avisynth if compiled with support (yes). or libav* formats if compiled with lavf support (yes) or ffms support (yes). Outfile type is selected by filename: .264 -> Raw bytestream .mkv -> Matroska .flv -> Flash Video .mp4 -> MP4 .3gp -> MP4 (branded '3gp6') .3g2 -> MP4 (branded '3gp6' and '3g2a') ... Audio: Audio options may be used if audio support is compiled in. Audio is automatically opened from the input file if supported by the demuxer. --audiofile <filename> Uses audio from the specified file --ademuxer <string> Demux audio by the specified demuxer [auto] Supported and compiled in demuxers: - auto, lavf, avs, lsmash --atrack <integer> Audio track number [auto] --acodec <string> Audio codec [auto] Available settings: - auto (select muxer default codec and its default encoder) - copy (copy source audio without transcoding) - none (disable audio) Set audio format only and automatically choose encoder - raw, mp3, aac, ac3, alac, mp2, vorbis, amrnb Force to use specified audio encoder 'ff' prefix indicate they are supported via libavcodec - raw, lame, qtaac, (ff)aac, (ff)ac3, (ff)alac, (ff)mp2, (ff)vorbis, (ff)libopencore_amrnb --abitrate <float> Enables bitrate mode and set bitrate (kbits/s) --aquality <float> Quality-based VBR [codec-dependent default] --asamplerate <integer> Audio samplerate (Hz) [keep source samplerate] --acodec-quality <float> Codec's internal compression quality [codec specific] --aextraopt <string> Pass extra option to codec [codec specific] Should be comma separated "name=value" style Encoder specific helps: * raw encoder help Directly pass the decoded PCM samples (in native endian) to muxer. All audio options except for --acodec and --audiofile are ignored. * lame encoder help --aquality VBR quality [6] 9 (lowest) to 0 (highest) --abitrate Enables CBR mode. Bitrate should be one of the values below - for 32000Hz or 44100Hz or 48000Hz 32, 40, 48, 56, 64, 80, 96, 112, 128, 160, 192, 224, 256, 320 - for 16000Hz or 22050Hz or 24000Hz 8, 16, 24, 32, 40, 48, 56, 64, 80, 96, 112, 128, 144, 160 - for 8000Hz or 11025Hz or 12000Hz 8, 16, 24, 32, 40, 48, 56, 64 --asamplerate Output samplerate. Should be one of the values below 8000, 11025, 12000, 16000, 22050, 24000, 32000, 44100, 48000 --acodec-quality Internal algorithmic complexity [0] 9 (poor quality) to 0 (best quality) * qtaac encoder help --aquality VBR quality [63] Cannot be used for HE-AAC and possible values are: 0, 9 ,18 ,27 ,36 ,45 ,54 ,63 ,73, 82, 91, 100, 109, 118, 127 0 is lowest and 127 is highest. --abitrate Enables bitrate mode Bitrate should be one of the discrete preset values depending on profile, channels count, and samplerate. Examples for typical configurations - for 44100Hz or 48000Hz with 1ch LC: 32, 40, 48, 56, 64, 72, 80, 96, 112, 128, 144, 160, 192, 224, 256 HE: 16, 24, 32, 40 - for 44100Hz or 48000Hz with 2ch LC: 64, 72, 80, 96, 112, 128, 144, 160, 192, 224, 256, 288, 320 HE: 32, 40, 48, 56, 64, 80 - for 44100Hz or 48000Hz with 5.1ch LC: 160, 192, 224, 256, 288, 320, 384, 448, 512, 576, 640, 768 HE: 80, 96, 112, 128, 160, 192 The lower samplerate, the lower min/max values are applied --asamplerate Output samplerate LC: 8000, 11025, 12000, 16000, 22050, 24000, 32000, 44100, 48000 HE: 32000, 44100, 48000 Samplerate greater than input is not supported --acodec-quality Encoder's internal complexity [0] 0 (medium), 1 (high), 2 (highest) --aextraopt Profile and bitrate mode sbr : enable HE-AAC encoding [0] mode : bitrate control mode [abr] "abr", "cbr", "cvbr" --aquality/--abitrate setting may be changed inside codec due to its limitations and extreme resampling settings (e.g. 48000->8000) may not work. If something goes wrong, it will result in a failure of codec initialization. * (ff)libopencore_amrnb encoder help Accepts only mono (1ch), 8000Hz audio and not capable of quality based VBR --abitrate Only one of the values below can be acceptable 4.75, 5.15, 5.9, 6.7, 7.4, 7.95, 10.2, 12.2 ... |
2nd November 2010, 15:33 | #5850 | Link |
Mr. Sandman
add --acodec none in the custom commandline options of the x264 preset config.
2nd November 2010, 22:55 | #5852 | Link |
It's been a month or so since I encoded something. I used to get around 33fps encoding with x264 to mp4 on both film and interlaced sources. All of a sudden I'm getting less than 10fps with film sources, but my interlaced stuff still encodes at 33fps. Has something changed recently in the way megui handles film sources? Here's one of my scripts that encodes really slowly
LoadPlugin("C:\Program Files\megui\tools\dgindex\DGDecode.dll") DGDecode_mpeg2source("E:\800FL\800FL.d2v", info=3) LoadPlugin("C:\Program Files\megui\tools\avisynth_plugin\ColorMatrix.dll") ColorMatrix(hints=true, interlaced=true, threads=0) fft3dfilter(interlaced=true) LoadPlugin("C:\Program Files\megui\tools\avisynth_plugin\TIVTC.dll") tfm(order=1).tdecimate() crop( 4, 6, -8, -2) LanczosResize(576,432) # Lanczos (Sharp) #denoise Could it be a cpu utilization problem? I have an i5 quad core and I let x264 automatically set the number of threads. It looks like film encodes are not using a very high percentage of cpu power when compared to an interlaced encode. Here's a typical script for one of my interlaced encodes. LoadPlugin("C:\Program Files\megui\tools\dgindex\DGDecode.dll") DGDecode_mpeg2source("E:\PR23\PR23.d2v", info=3) LoadPlugin("C:\Program Files\megui\tools\avisynth_plugin\ColorMatrix.dll") ColorMatrix(hints=true, interlaced=true, threads=0) fft3dfilter(interlaced=true) Load_Stdcall_Plugin("C:\Program Files\megui\tools\yadif\yadif.dll") Yadif(order=1) crop( 12, 6, -12, -6) LanczosResize(576,432) # Lanczos (Sharp) #denoise |
3rd November 2010, 11:28 | #5853 | Link |
Hi to everyone and sorry if my english won't be well but I'm italian
Is possible to add cleanup job manually? I meant without one-click feature. That's my procedure, I: 1) Open File indexer to make the d2v file 2) Open it with AVS creator and save the AVS script 3) Select the profile in the video encoder settings 4) Set the right bitrate with bitrate calculator and insert it in the profile 5) Click Auto-encode to generate all the jobs automatically. 6) At the end of the job I have to clean up by myself. These passes works good but I'd prefer cleaning up to start through jobs Thanks in advance |
3rd November 2010, 14:50 | #5854 | Link |
Mr. Sandman
@luke83: 4 is useless. Auto-Encode window will ask you for a target bitrate OR filesize too.
also, it's not clear to me what you mean with "i have to clean up". clean up what? @ZZZERO: ensure you're using the same encoding preset as before.
3rd November 2010, 16:17 | #5855 | Link | |
When I use the "One-Click" encoding, one more job appears at the end named:"Clean up". This job deletes all the file in the working directory. When I don't use "One-click", Megui doesn't add that final job. In this case the last job is "Muxing". I want to know the way to add "clean job" manually. So I haven't to open working folders and delete all the files by myself |
3rd November 2010, 18:08 | #5856 | Link |
I'm using the same preset as before. In fact, I'm using the same preset for film encoding and for interlaced material. The only difference between the encodes are these script lines:
Film script: LoadPlugin("C:\Program Files\megui\tools\avisynth_plugin\TIVTC.dll") tfm(order=1).tdecimate() Interlaced script: Load_Stdcall_Plugin("C:\Program Files\megui\tools\yadif\yadif.dll") Yadif(order=1) Both are generated from the MEGUI analyze function. The film script results in 10fps, the interlaced script gives me 33fps. I don't have an old film script so I don't know if MEGUI has changed some parameter in the scripts it creates, but I do know that I used to get at least 33fps when encoding film sources in the past. Now I'm getting a quarter of that speed and I don't know why. |
4th November 2010, 05:05 | #5857 | Link |
Mr. Sandman
@ZZZERO: inverse telecine is a more complex process than just deinterlacing. it's pretty normal.
@luke83: the clean up job cant be added outside one-click encoder.
4th November 2010, 09:35 | #5858 | Link |
When looking at a CSI disc in DGIndex and DGIndexNV both say that the disc is interlaced, yet when i go to make the avs file in MeGui it says that the stream is progressive, so which is right? Which is it? should i trust MeGui and let it make a .avs for progressive?
The Internet: where men are men, women are men, and children are FBI Agents |
4th November 2010, 09:44 | #5859 | Link | |
From the DGIndex manual:
4th November 2010, 09:47 | #5860 | Link |
Thanks Nurbs, helps me to understand a bit more. Yes RTFM is a good thing, maybe i should do that after coffee :-)
megui |
