17th December 2017, 18:45 | #4982 | Link |
MKVToolNix author
Due to my experience with players and font Mime types in the past, the new types are not the default and purely optional.
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. |
19th December 2017, 22:09 | #4984 | Link | |
19th December 2017, 22:23 | #4985 | Link |
MKVToolNix author
Not giving you something you very vociferously demand isn't harassment. What you're doing, on the other hand, is pretty much trolling. Please stop it.
20th December 2017, 12:20 | #4986 | Link |
There's a tiny bug i noticed a while ago. Well maybe it's not a bug, probably "unexpected behavior" would be better.
If you set a track name with spaces in it (edit: or you have files with spaces in them) and you then select Multiplexer > Show command line, the default escaped output (Windows cmd.exe is selected by default) is correct. But if I go in the drop down menu and select Don't escape, then the cmd escaping AND the " " for the text are removed. For example, let's say I use "English 5.1" as track name, the default is shown like this: Code:
mkvmerge.exe --ui-language en --output ^"D:\temp\output.mkv^" --language 0:und --language 1:und ^"^(^" ^"D:\temp\video.m2ts^" ^"^)^" --language 0:eng --track-name ^"0:English 5.1^" ^"^(^" ^"D:\temp\sound.opus^" ^"^)^" --track-order 0:0,0:1,1:0 After selecting don't escape, it's converted to this: Code:
mkvmerge.exe --ui-language en --output D:\temp\output.mkv --language 0:und --language 1:und ( D:\temp\video.m2ts ) --language 0:eng --track-name 0:English 5.1 ( D:\temp\sound.opus ) --track-order 0:0,0:1,1:0 Code:
mkvmerge v19.0.0 ('Brave Captain') 64-bit Error: The file '5.1' could not be opened for reading: open file error. IMHO, the "don't escape" should not remove " characters which are required for values of parameters to function, for the command to actually work. I just want the ^ and cmd.exe escaping to go away. In my particular case, I'm just trying from time to time to get the command and then replace filenames with %1, %2 etc and create a batch merge with a PHP script. |
20th December 2017, 12:37 | #4987 | Link |
MKVToolNix author
Uhm, no. Either you escape, or you don't. There is no middle ground, just "wrong/incomplete escaping that'll do the wrong thing in situations you don't expect".
20th December 2017, 14:50 | #4988 | Link |
I sort of see what you're saying but at the same time by your logic, since you're escaping the parenthesis in the first example, shouldn't those be missing in the 2nd form as well?
What's the difference between the ( ) characters and the " characters that the () get special treatment while " are silently removed? Your special way of parsing the parameters/arguments in command line seems to make using ( ) characters a requirement so to me it would seem your program should either add some intelligence during parsing to guess where file names end (and what's normally in text fields) , or you should treat " characters like those ( ) characters, as required to read arguments properly. I think it's not a Windows thing to require " characters, you'd need them in Linux and other operating systems as well, or am I wrong... |
20th December 2017, 14:54 | #4989 | Link |
MKVToolNix author
Parenthesis have nothing to do with escaping or the shell or cmd.exe. They're a function of mkvmerge and important to mkvmerge regarding appending files.
20th December 2017, 16:33 | #4990 | Link |
WHATTTTT? NO SUPPORT FOR WINDOWS 95? I am totally going to complain about this on my myspace page that has 3 visitors a year.
PS. You can send me your hearts and prays through AOL Instant Messenger, my email is backstreet_boys_superfan_*85*_<333@aol.com Last edited by Gser; 20th December 2017 at 16:38. |
23rd December 2017, 02:46 | #4991 | Link | |
I've only just switched to MKVToolNix 19, but so far version 10 of mkvtoolnix-gui.exe is playing nice with version 19 of mkvmerge.exe, so you can use that. manolito's utility for automatically dismissing the warning could previously be found via this post but the link seems to be dead so here's a new one if you want it. (I've removed the link as I only had the exe's without instructions, plus it turns out I uploaded the first version and the SendTo method of opening files doesn't work. I didn't realise I'd kept it. See the next post for a new link from manolito). PS. Thanks for the update Mosu. Last edited by hello_hello; 23rd December 2017 at 15:21. |
23rd December 2017, 03:23 | #4992 | Link |
Thanks hello_hello for uploading my little hack to VideoHelp...
ZippyShare deletes uploads after noone has downloaded them for more than 4 weeks, and this is very much OK with me. I just reuploded the complete hack (which contains instructions and the sources for the executable) here: https://files.videohelp.com/u/172211/ToolNix_XP.zip I do check new releases of MKVToolNix to make sure my workaround still works, so far I found no issues... Cheers manolito Last edited by manolito; 31st December 2017 at 02:31. Reason: Moved the archive from ZippyShare to VideoHelp |
27th December 2017, 23:50 | #4993 | Link |
Any more thoughts on Dolby Vision? UHD ripping has really taken off since it was first mentioned in October, and things are starting to get software updates to support Dolby Vision (I just got my AppleTV 4k -> Pioneer VSX-1131 -> LG OLED65C7P chain working today thanks to a Pioneer software update). I know it's a chicken-and-the-egg problem (why add DV to MKV if all current devices will choke on it), but until it's at least added to the spec, no device will ever be able to support it. Infuse on Apple TV 4k seems like a great first player for DV-in-MKV content.
27th December 2017, 23:54 | #4994 | Link |
MKVToolNix author
I currently have no plans for spending time on it. Busy with other things.
1st January 2018, 15:43 | #4996 | Link |
Matroska find' ich toll
Hi Mosu,
I have started in the german forum a topic about the Block structure. Code:
Block Structure Size = 1 + (1-8) + 4 + (4 + (4)) octets. So from 6 to 21 octets. |
1st January 2018, 16:42 | #4997 | Link |
The first 1 is for the 0xA1 denoting a block; 1-8 is not a substraction, but means that the size of the data to follow is coded with a variable length EBML integer. The next four bytes seem to be for the TrackID, the relative timestamp/timecode (soon to be depreceated verbiage) and the byte with the flags. I don't know what the last (4+(4)) means: You can possibly have lacing data next (depending on the flags), but even in this case (4+(4)) doesn't make any sense. Furthermore, the interpretation of the first four depends on the TrackID coded in 1 octet (Matroska allows up to 2^56-1 tracks at the moment and they are coded in EBML integer form like EBML sizes (but with the difference that there is no reserved value (EBML sizes have a reserved value denoting an unknown size; TrackID has not)).
So currently I'd say that this is a bug in the specs. If mose agrees, you should file a bug report on github. |
1st January 2018, 16:52 | #4998 | Link |
MKVToolNix author
I'm pretty sure those numbers are completely wrong, both for the Block and the SimpleBlock elements. You've wondered that yourself in that German thread already, and it looks right to me.
For the Block structure, better numbers would be:
Edit: added missing "number of laced frames".
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. Last edited by Mosu; 1st January 2018 at 17:05. |
1st January 2018, 17:00 | #4999 | Link | |||
MKVToolNix author
"TrackID" (or rather: "track ID") is a concept used by mkvmerge & mkvextract, but there's no corresponding Matroska element. Yeah, it's confusing, I get that Quote:
1st January 2018, 19:30 | #5000 | Link | |||
Would you do this? I think your English is better. |
