9th July 2011, 09:09 | #942 | Link |
few bugs in v0.9:
- render madvr, haali splitter, MPCHC or Potplayer. When unpause movie image back to a few frames. This bug does not occur on EVRCP. - any render, haali splitter, MPCHC or Potplayer. When change audio stream picture stops for a few seconds and then catches up with the current frame. This bug does not occur with Your splitter. My pc: CPu: Intel i5. GPU: Nvidia GeForce GT 320M 275.33 drivers, Win7 x64 SP1 Last edited by Volfield; 9th July 2011 at 14:07. |
14th July 2011, 08:39 | #948 | Link |
The decoder has nothing to do with the menu navigation. TBH, i have no idea how menus are rendered in DirectShow, but i do know that it has nothing to do with the decoder.
Anyhow, LAV CUVID is not compatible with the MS DVD Navigator at this time. It might be added later.
14th July 2011, 08:43 | #950 | Link |
Yeah, the DVD Navigator sends the streams encrypted, and the decryption is just not integrated in LAV CUVID. I do have it in LAV Audio, so it would just be a matter of moving it over, but meh. I r teh busy.
14th July 2011, 09:20 | #952 | Link |
Not sure, probably not.
But it always sends the data in a special packed format, namely as MEDIATYPE_DVD_ENCRYPTED_PACK, which is a special packing form for single PES units, either encrypted or not. I borrowed the code to handle this from MPC-HC, after understanding it in theory and testing some discs, i just called it a day and didn't investigate to deeply how it really behaves.
14th July 2011, 11:20 | #954 | Link |
The Macrovision error is just a simple renderer check afaik. Use a guid from one of the MS renderers and a custom renderer wil work.
I wonder if it would be possible to create some kind of wrapper for the MS DVD navigation filter. Then the data/info it gets could be modified to fool it.
MPC-HC 2.1.7.2 |
14th July 2011, 11:41 | #955 | Link | |
That would be quite cool, of course. |
14th July 2011, 11:46 | #956 | Link |
Replacing one of the MS decoders might not be safe though and could result in funky problems. Some other filters also check which renderer is used to adjust their behavior. For example ffdshow.
MPC-HC 2.1.7.2 |
16th July 2011, 20:34 | #958 | Link | |
As attachement there is a MediaPortal's directshow graph with MS DVD Navigator. - tourettes |
21st July 2011, 06:53 | #960 | Link |
ZZZzzzz...
I am having trouble playing this file with LAV CUVID Decoder 0.9.
http://www.mediafire.com/?yv750rqhfot2htq This is a clip I made from my encode of Star Trek (2009). Here is the MediaInfo data is available here. This clip plays fine with DiAVC and ffdshow, but not with LAV CUVID Decoder. I'm not sure if it is a problem with my file or with Nvidia's drivers (I use version 275.50). Last edited by lych_necross; 21st July 2011 at 06:58. |
