13th March 2011, 11:59 | #5961 | Link | |
13th March 2011, 12:04 | #5962 | Link | |
13th March 2011, 12:04 | #5963 | Link | |
Fwiw, i do not see any difference between video player controlled, or setting PC/Video there
13th March 2011, 12:23 | #5965 | Link |
For my GT240 all the suggested changes you suggest do not change the way you test program reports, I still get 0-255.
This is 2nd gpu outputting to a secondary display. Like I said however I have to make the gt240 the primary display and gtx295 secondary to get the program to report details for it. I have tried all the suggested settings you suggest and it just won't go from 0-255 to 16-235. |
13th March 2011, 14:41 | #5967 | Link |
If I create my own test custom resolution it works but If I use the nvidia preset custom resolutions it does not.. Here lies the problem, I cannot create the custom resolutions I need because it messes up all the other standard resolutions in such a way that I have to clean reinstall the driver. This is an issue I think with trying to create custom resolutions on secondary displays in the nvidia control panel, it sucks. This bug has been there for ages and nvidia have not fixed it even though they are aware of it.
13th March 2011, 14:54 | #5968 | Link |
I know. Did you try to create the custom resolutions on the secondary display by activating it and disabling the primary display, so it can be the only active? Whenever I do this I can create my custom resolutions on both displays without any problem. The secret is creating the custom resolutions only with one of the displays active, the one which you want to create the resolutions to.
13th March 2011, 15:16 | #5969 | Link | |
Tried, as soon as I enter the first resolution all other resolutions are limited to 16bit. Last edited by Razoola; 13th March 2011 at 16:09. |
13th March 2011, 16:24 | #5970 | Link |
For those of you that didn't know, for whoever has a HDTV connected with nvidia drivers, and the entire desktop is being output in 16-235 instead of full range, the best workaround is to add this to the nv_disp.inf before installing the drivers. Makes the drivers assume your using a fullrange TV instead of limited range. I need to use this each time I do a clean install of nvidias drivers.
Add HKR,,SetDefaultFullRGBRangeOnHDMI,%REG_DWORD%,1 to each section of your inf that begins with [nv_miscBase_addreg_ eg [nv_miscBase_addreg__01] HKR,,SetDefaultFullRGBRangeOnHDMI,%REG_DWORD%,1 ====================== madshi, a general question. You might remember I recently reported about having less frame drops in some particular files, when using high performance mode of my nvidia card, rather than adaptive performance. Well it turns out I'm having issues with many of these files in another way which I havn't been able to figure out, with getting much more frame drops than others even when not using any avisynth scripts, with cpu usage less than 15%. The evr-cp renderer in mpc actually showed me with its graph, that the presentation of video isn't smooth with these files compared to blu-rays / other files on my machine. See below the green line isn't straight when playing these files. I still havn't figure it out but am wondering does madVR do any type of timestamp smoothing or is it something you think might be useful. So far all I can think of that causing this effect with these files is something to do with timestamps. Some are mkv, some are mp4 and I havn't tried too many more files to see how many it effects. (PS: The evr-cp graphs / or the unsmooth presentation would have come in handy in madVR in this case ). Even when there are 0 frame drops its easy to see from the graph something isn't right.. Last edited by mark0077; 13th March 2011 at 16:27. |
13th March 2011, 16:30 | #5971 | Link |
This should be useful for me since I've been using VGA because of that issue.
Would you happen to know how I might be able to enable a 24Hz (or multiple of 24Hz) mode on my TV? At the moment, I've only got bloody 25Hz and 60Hz. |
13th March 2011, 16:45 | #5972 | Link | |
The workaround I gave doesn't have any negative effects... pity there isn't a gui based option... |
13th March 2011, 16:51 | #5973 | Link |
There are 2 settings that show if your outputting via HDMI, you can choose either RGB or YCbCr444 for digital color format. Also you can choose either auto select, desktop programs or full screen video for content type reported to the display. When ever I update the driver I have to do these settings again to get full range back. |
13th March 2011, 16:52 | #5974 | Link | ||
13th March 2011, 17:03 | #5975 | Link | |
For now I have given up trying to get correct setting with the secondary GT240 as I cannot set up the custom resolutions I need on it using the nvidia control panel. |
13th March 2011, 17:54 | #5976 | Link |
Hi madshi, I suppose what I'm asking is
1) Does madVR do any sort of checking for uneven timestamps, and is it able to smooth them out? 2) If not, do you think its something the renderer should / or could do in future? 3) I'm going to go through alot of my content over the next few days to see which are effected, and will use evr-cp to check this, unless madVR has a way of indicating the issue I see using evr-cp's graphs, with some of its CTRL-J stats? Not a big issue I can use evr-cp if madVR hasn't a way of showing such problems up. Here is one clip which I downloaded recently, its Lada Gaga's new music video, 1080p. I won't post a direct link but the filename is "Lady Gaga - Born This Way(1080p_H.264-AAC) VEVO.mp4" - 171 MB (179,834,004 bytes) I don't know the source but if you wanted you could try it and see the evr-cp graphs, and see the framedrops with madVR and other renderers of course. I can only assume thousands of people will have similar files, and I would love a way to workaround the problems I'm having with them without having to remux them all Let me know if you have any thoughts. If madVR could workaround such problems, it would be another step ahead of evr-cp but I'm unsure if its appropriate for the renderer to do such a thing. In the meantime I'll try remuxing one of the mkv's I have the problem with, with eac3to to see if it helps. |
13th March 2011, 18:25 | #5977 | Link | |
2) Maybe. 3) I don't know what the issue is so I don't know if madVR shows it. |
13th March 2011, 21:49 | #5978 | Link |
What is madVR doing that makes pagefile writes take off? Just got and SSD and was wondering if I'm making enough writes to the pagefile to make it worth moving it off the SSD. So I fired up Process Monitor, and made a long capture.
During normal desktop usage the pagefile writes were areound 5MB/h, but when watching something with MPC-HC and madVR the pagefile writes increase to over 3GB/h. This does not happen with EVR. 3GB per hour is quite a lot of writes. What is madVR doing? |
13th March 2011, 22:52 | #5979 | Link |
The pagefile is managed by the OS. If madVR increases pagefile usage then probably your PC doesn't have enough RAM in it. madVR keeps 8 decoded frames in system RAM. I don't think EVR does that. Sorry, nothing I can do about it. The max I could do is to offer an option to decrease the queue size. I have that planned for a future build, but it may take some time until I get there.
14th March 2011, 01:51 | #5980 | Link | |
Razoola. That nvidia cp option never has any effect on my pc. I'm not sure what it does but for me I need that registry tweak to get full range with samsung series 9 - gtx295 - win 7 64 bit |
