14th September 2007, 02:45 | #701 | Link | |
16th September 2007, 13:24 | #703 | Link | |
I have released version 0.6 of WAV to AC3 Encoder. You can download it from here or use direct download links placed below.
Download Binary Package: Win32 Unicode | Win32 Ansi | Win64 Unicode | Win64 Ansi Installer Package: Win32 Unicode | Win32 Ansi | Win64 Unicode | Win64 Ansi Source Package: Visual C++ 2005 SP1 Changelog Quote:
Thanks, wisodev |
16th September 2007, 19:24 | #706 | Link | |
Thanks, wisodev |
25th September 2007, 23:21 | #708 | Link | |
I have released version 0.7 of WAV to AC3 Encoder. You can download it from here or use direct download links placed below.
wisodev |
29th September 2007, 17:36 | #710 | Link |
wisodev,
first thank you for new version. i have a problem: loading 5.1wave from audition in EncWAVtoAC3-0.7-Win32A-bin or in EncWAVtoAC3-0.7-Win32U-bin(default adjusts) i got a message.."this program is closed by windows..." etc. loading the same 5.1 in EncWAVtoAC3 0.4 everything runs fine and i got the perfect result. help please with the new version and thanks again! |
29th September 2007, 17:48 | #711 | Link | |
PS. Similar problems are with kurtnoise13 libaften.dll build. |
29th September 2007, 17:58 | #712 | Link | |
now a request for next version if you don't mind: with 0.7 version i have to change to 1024x768 pixels. is possible "back" to 800x600 pixels? thanks sooo much. |
5th October 2007, 14:00 | #716 | Link |
FAVC Man
AAC Channel Order via DirectShowSource
My app, FAVC, feeds Aften through wavi (i.e. an avisynth script).
I've had some reports from users that using DirectShowSource on mkv files with 6 channel AAC audio leads to an Aften encoding that has the wrong channel order. It was my understanding that using DirectShowSource for audio would always give the correct order for Aften. Is this not the case? Is it more likely that the original AAC file has the wrong channel mapping? Or, in general should I be reordering channels from AAC audio in Directshowsource to feed to Aften?
5th October 2007, 16:35 | #717 | Link | |||
7th October 2007, 12:21 | #718 | Link |
I'm on MacOsx and trying to compile aften 0.08. I use the cmake .., which runs succesfully. However, the make step ends in error during the link fase. Code:
Linking C executable aften /usr/bin/ld: Undefined symbols: _expstr_set_bits _a52_window collect2: ld returned 1 exit status make[2]: *** [aften] Error 1 make[1]: *** [CMakeFiles/aften_exe.dir/all] Error 2 make: *** [all] Error 2 I've searched the web but the only thing relevant (I think) was this post. As mentioned, I'm not a programmer so I don't know what to change. Anyone can help me with this? |
11th October 2007, 04:47 | #719 | Link |
HeadAC3he coder
@surfer63
Could you run a "make clean" and then a "make VERBOSE=1" and then mail me the complete output? @raquete What kind of CPU do you have? Does using aften commandline work for you, even if you don't disable simd support? |
11th October 2007, 19:14 | #720 | Link | |
I have fixed the crush problem when using my builds (actually there is one problem with libaften.dll build by Kurtnoise13 when used on system without SSE3 but Kurtnoise13 aften.exe build works perfectly) and released updated binaries! My aften.exe and libaften.dll builds are now working without any problems. I made mistake by enabling SSE3 support for SSE version so when running on system with no SSE3 support there where crushes. Sorry for the trouble. wisodev |
