Old 18th February 2013, 20:49   #1  |  Link
senze
Subjective evaluation of perceived quality/distortion - Searching for participants
I'm trying to conduct a small study. Especially I'm comparing the performance of some codecs on small sized video files.
For that reason I created a small test package on basis of the "MSU Perceptual Video Quality tool" (http://www.compression.ru/video/qual...y_tool_en.html).
With this tool the participant (you) has to rate the perceived quality/distortion of five video files.
The package contains six videos. The first one is the reference file (high quality and uncompressed). The other video files are coded with different codecs and contain different degree of distortion. At the end of the rating process the program creates a csv file with your ratings. This file need to be sent here or on codecevaluation@googlemail.com
The package contains a detailed "readme.txt" and some other files for getting the program working.
If I find enough subjects and if wished, I can publish the results here.
The link to the package:
http://www.mediafire.com/?7cg2g3ggkv483ox
Best regards,
senze
senze is offline   Reply With Quote
Old 27th February 2013, 22:36   #2  |  Link
ChiDragon
ChiDragon's Avatar
No response? Well, sign me up. PM if necessary.
ChiDragon is offline   Reply With Quote
Old 6th March 2013, 18:59   #3  |  Link
senze
codec evaluation
do you want to participate in the study or are you interested in the results? Unfortunately it seems that there are not enough subjects for getting valuable results.
Old 7th March 2013, 06:49   #4  |  Link
ChiDragon
ChiDragon's Avatar
A participant, if you get enough.
codec comparison study
