19th November 2007, 10:15 | #584 | Link |
Angel of Night
http://sourceforge.net/project/showf...roup_id=173941 is where the actual builds are published, in case you want to test them for compatibility.
19th November 2007, 15:47 | #585 | Link |
I have a VFR MP4. I try to extract the raw AVC stream with Yamb and then use DGAVCindex to play with it, but what I get is a 29.97 fps video. In the bottom I see that the fps has a value of 60000 / 2002 (=29.97fps), but the video originally is 23.976fps except for a part that is 60fps. Am I doing something wrong? Or maybe there is some kind of evil problem with DGAVCindex handling VFR AVC streams?
19th November 2007, 16:01 | #586 | Link | |
Comes from a SONY AVCHD camera. May contain some PAFF (DGAVCIndex 1.00a6 complained it). I indexed and converted a longer video (~ 20 min, with interlaced/progressive changes due to changing lightness) without problems, too. VirtualDub crashed (simply disappeared) when dragging the position slider around on a loaded AviSynth script. But this is not really the recommended treatment anyway. Last edited by LigH; 19th November 2007 at 16:03. |
19th November 2007, 17:01 | #587 | Link | |
Probably it has 23.976 parts pulled-down to 29.97 mixed with 29.97 parts. To handle that, DGAVCDec could honor the pulldown flags and then you can decide in your Avisynth script how to deal with that (just as for DGMPGDec), or DGMPGDec could apply Force Film. But I haven't yet implemented the Honor Pulldown Flags or Force Film functionality, so you'll have to be patient. It's not so easy, because when decoding, libavcodec.dll is doing the work and it doesn't honor pulldown either, so I have to do it after decoding the frame. But I don't have access to the picture timing SEI, because libavcodec.dll decoded the frame and all I get back is the decoded frame data. So I either have to make a special build of libavcodec.dll that passes back data I need (which I prefer not to do so that users can switch out different libavcodec.dll versions as they come along), or I have to parse the NALUs as they flow by on the way into libavcodec.dll. I can do the latter but some redesign will be needed. I'm working on it. Last edited by Guest; 19th November 2007 at 17:07. |
19th November 2007, 17:12 | #588 | Link |
Thanks for your quick answer neuron2. The stream is some 800mb so I don't know how I can give it to you.
But according to the timecodes I get if I mux into mkv, there are 60fps parts and 23.976 parts. It's an anime episode and the part in 60fps is the ED. P.S. What I noticed some minutes ago, is that i get some 886 frames less than I should have got. I don't know if this is related with your explanation though... |
19th November 2007, 20:50 | #590 | Link |
Life's clearer in 4K UHD
Given .MKV appears to be the container of choice for pirated high-def downloads, I reckon we're going to get a lot more questions from people wanting to know how to gain access to the elementary streams. Not to mention re-muxing the elementary streams to other containers!
19th November 2007, 21:36 | #591 | Link |
Are there any ... well, kind of statistics, which kind of generator / encoder / producer prefers which kind of "interlaced vs. progressive" encoding? I have a suspicion that e.g. hardware encoders (like in AVCHD cameras) may prefer the more generic and faster solutions (e.g. switch to low-res progressive on low brightness), and that different HDTV broadcasters may use different encoders and settings.
Furthermore, I wonder why PAFF was harder to implement than MBAFF, although to me it sounds like PAFF defines the "interlaced" behaviour of all macroblocks in the whole frame, in contrast to MBAFF which defines it per macroblock -- or did I misunderstand them? Last edited by Guest; 22nd November 2007 at 04:32. Reason: removed off-topic material |
19th November 2007, 23:06 | #593 | Link |
What? Can you point to any article which reports this? From what I know encoding any source to any other format is just as illegal anywhere in Europe. Why should anime be different from any other source? I'm glad I don't live a bit further north then.
Or have I just been trolled?
x264 log explained || x264 deblocking how-to preset -> tune -> user set options -> fast first pass -> profile -> level Doom10 - Of course it's better, it's one more. |
19th November 2007, 23:52 | #594 | Link |
Possible hang with Alpha 8
I installed 1.0.0 Alpha 8 and tried to index a file. The stream came from DishNetwork and contains PAFF. I know it's not supported, but decided to try it just for the heck of it.
When I opened the file, dgavcindex hung for about 10 minutes, then came back and gave me the paff warning. I cheerfully told it to go ahead and blow up in my face At this point, it's been unresponsive for about 2 hours. Interestingly enough, it has generated a 99k .dga file, so it definitely processed some of the stream. If anyone wants to test this, the first 15MB of the stream are at: http://mostlyharmless.dyndns.org/264/sample.264 The DGA file is at: http://mostlyharmless.dyndns.org/264/test.dga Terry |
20th November 2007, 08:07 | #595 | Link |
Version 1.0.0 alpha 9
This version adds the Info dialog functionality.
http://neuron2.net/dgavcdec/dgavcdec100a9.zip One tip: To see the frame types, set the playback speed to Single Step before starting your preview. Otherwise that field is just a blur. The changes were extensive as I had to implement the parallel parsing I described in my earlier post. So pound on it with relish. Last edited by Guest; 20th November 2007 at 08:43. |
20th November 2007, 09:26 | #598 | Link | |
Ron
HD MPEG-2 Test Patterns http://www.w6rz.net |
20th November 2007, 09:39 | #599 | Link |
Great, "Info dialog" was a missed little gem!
Due to the possible complexity of AVC, it may be useful to see a few more AVC specific details here, like the referencing amount. If you like... |
20th November 2007, 10:27 | #600 | Link | |
Anyway, here's what AVInaptic (18-11-2007) had to say about it: - Code:
[ About file ] Name: sample.264_pid17.mp4 Date: 20/11/2007 09:18:57 Size: 5,591,649 bytes (5.333 MB) [ Generic infos ] Play duration: 00:00:16 (15.76 s) Container type: MP4/MOV Major brand: ISO Base Media version 1 Compatible brands: JVT AVC Creation time: 19/11/2007 09:18:57 UTC Modification time: 19/11/2007 09:18:57 UTC Number of streams: 1 Type of stream nr. 1: video (avc1) {GPAC ISO Video Handler} Audio streams: 0 [ Relevant data ] Resolution: 1440 x 1080 Width: multiple of 32 Height: multiple of 8 [ Video track ] Codec: avc1 Resolution: 1440 x 1080 Frame aspect ratio: 4:3 = 1.333333 Pixel aspect ratio: 4:3 = 1.333333 Display aspect ratio: 16:9 = 1.777777 Framerate: 25 fps Number of frames: 394 Bitrate: 2834.996446 kbps [ About H.264 encoding ] SPS id: 0 Profile: Main@L4 Num ref frames: 4 Aspect ratio: Custom pixel shape (4:3 = 1.333333) Chroma format idc: YUV 4:0:0 PPS id: 0 (SPS: 0) Entropy coding type: CABAC Weighted prediction: No Weighted bipred idc: No 8x8dct: No PPS id: 4 (SPS: 0) Entropy coding type: CABAC Weighted prediction: P slices - explicit weighted prediction Weighted bipred idc: #undef# 8x8dct: Yes Custom inter4X4 chromau: 8 8 244 244 254 246 243 241 254 243 242 241 242 242 241 241 Custom inter4x4 chromav: 9 9 11 12 12 11 12 12 12 13 12 9 12 12 9 9 50 54 52 95 41 0 0 0 0 0 0 0 100 101 45 117 110 100 101 114 108 105 110 101 45 102 105 101 108 100 45 118 97 108 117 101 0 101 0 51 40 0 0 0 65 0 0 0 Custom intra8X8 luma: 9 9 6 6 15 15 14 13 12 6 13 16 16 14 22 16 19 10 16 16 15 22 16 16 10 11 17 15 22 16 13 15 10 16 15 12 16 13 14 15 16 16 15 20 13 13 95 84 16 15 17 13 13 95 84 84 18 17 14 14 98 84 84 84 Custom inter8X8 luma: 9 12 17 17 206 207 206 206 12 18 210 211 207 206 206 237 18 211 211 208 206 206 236 237 211 211 208 206 211 236 237 3 211 209 208 211 236 216 211 3 209 208 211 236 216 212 3 3 209 211 227 216 217 3 3 3 224 224 216 217 3 3 3 3 [ Profile compliancy ] Resolution: 1440 x 1080 > 720 x 576 Framerate: Ok Warning: If you need a more complete report, then click on "DRF analysis" This report was created by AVInaptic (18-11-2007) on 20 nov 2007, h 09:25:32
