7th January 2016, 23:52 | #35041 | Link | |
Deinterlacing in video mode, wrong auto-detected, right? As in "PAL 4" case?
I tried YADIF deinterlacing in ffdshow - madVR recognizes double frame rate. So the problem is perhaps in LAV. Also, the picture I got with it for PAL is the same I got with LAV (worse than I got with madVR's film mode deinterlacing). Does it mean that YADIF deinterlacing algorythm is objectively worse in this case and the bug report will be senseless?
Windows 8.1 x64 Magically yours Raistlin Last edited by GCRaistlin; 7th January 2016 at 23:55. |
8th January 2016, 00:03 | #35042 | Link | |||
i don't think so anymore it should be a problem with lavfilter. it is working with ffdshow so it is very unlikely a problem in madVR and the automatic detection should have anything to do with it. madVR gets an progressive stream from lav when yadif is used so this detection shouldn't be used what so ever. Quote:
8th January 2016, 00:04 | #35043 | Link |
madshi, 2 feature requests:
Windows 8.1 x64 Magically yours Raistlin |
8th January 2016, 00:28 | #35044 | Link | ||
PAL from http://forum.doom9.org/showthread.ph...69#post1752069 Quote:
YADIF is very important, yes, but, as I said above, sometimes it gives worse results than madVR's film mode: http://i66.tinypic.com/15yk9c.jpg (compare it to madVR's deinterlacing screenshots here). Is it the issue it is worth to report of?
8th January 2016, 00:40 | #35045 | Link |
madVR film mode can (nativ progressive content) restore the original frames. Result is perfect.
Don't know which mode LAV uses for yadif, but I dont think there is an auto film/video detection and so it is in "video mode"? "Video Deinterlacer" do not give you always a perfect results for film content. Imho this works as it should. |
8th January 2016, 01:25 | #35046 | Link |
Regarding Dolby Vision, here is a very good info:
http://hdguru.com/dolby-vision-tries...t-bar-for-hdr/ http://www.dolby.com/us/en/technolog...hite-paper.pdf Will it be technically possible to achieve accurate playback of the UHD BD mastered in Dolby Vision using MPC-HC/LAVfilters/madvr?
__________________ System: Intel Core i5-6500, 16GB RAM, GTX1060, 75" Sony ZD9, Focal speakers, OS Win10 Pro, Playback: madvr/JRiver |
8th January 2016, 04:14 | #35047 | Link |
so if I understand correctly if I have philips 7007 which doesn't support full . should I select limited in the nvcp and madvr full ? what about setting in potplayer or mpdn. ? I get crushed black when I use that . black is too black
8th January 2016, 05:21 | #35048 | Link | |
8th January 2016, 05:45 | #35050 | Link |
If I use Full-Range I get crushed black, everything just become like what's called black crush, shadows just doesn't shown as shadows anymore. Another question about Exclusive mode : When entering and exiting FSE , frame dropped suppose to happen and shown in madvr OSD Statistics ? Because when entering and exiting FSE those frame dropped becomes and issue when the video try to reset itself and play the video like it is lagging behind and I have repeating frames over and over again while the render queue is dropping. even the Madvr OSD is repeating itself with the numbers you can see the numbers before in an instant while everything is stuttering. it happens as long as D3D11 FSE is enabled no matter if it's 8 bit or 10 bit. The only thing that fix it is using "Delay playback start until render queue is full" and "delay playback start after seeking too" which shows that the issue is with the render queue like I said before. but what is causing this issue only in windows 10 with D3D11 FSE ? can someone please help with this, I've been trying older madvr version , but nothing changed. Even with Delay both selected I still have dropped frames while entering FSE and exiting. I'm using CPU queue size : 16 and GPU queue size : 12 , would other numbers fix the issue ? or what could the render queue settings should I focused on. I tried to play with the prerender but 3 suppose to be the best. pretty please someone , it was working great before , I didn't need to enable delay playback and delay after seek . I don't know what changed. I even tried older nvidia driver which didn't fix the issue. MPDN D3D11 FSE have no issues at all going and exiting. In the end it could be an bug in potplayer, but why would same version works fine in windows 8.1 and not windows 10 ? someone else had the same issue : https://www.doom9.org/showthread.php...72#post1730672 as a check to the post withe the Cpu and Gpu queue https://www.doom9.org/showthread.php...58#post1730558 http://forum.doom9.org/showthread.ph...42#post1752242 http://forum.doom9.org/showthread.ph...57#post1752157 Last edited by x7007; 8th January 2016 at 05:58. |
8th January 2016, 08:23 | #35051 | Link | |
AV heretic
In sum, for RGB 0-255 you need PC mode for HDMI input and High black level in color. |
8th January 2016, 11:02 | #35053 | Link | |
and yeah there are issues with contrast/ brightness which can clip a lot of black levels. |
8th January 2016, 11:31 | #35054 | Link |
I have Game mode and Computer mode, but game mode is like 0-255 you use Limited . and Computer mode is like it turned the brightness up and using Full range makes it look like Game mode. but if you go 3D mode then it revert back to Game mode automatically and you are left with crushed black again.
9th January 2016, 23:31 | #35059 | Link | |
GTX-960 upscale to 2160 sure ain't a blu-Ray experience for me. |
10th January 2016, 01:05 | #35060 | Link | |
The dilemma madVR has created for this user is that I enjoy Kodi as a media frontend but only the defunct DSPlayer is compatible with madVR. In a year or less, I will be forced to choose between madVR and Kodi. It's madVR, of course.
