18th February 2013, 00:36 | #242 | Link |
Yes, only updated the version and settings are the same for encode (maximum possible). Program very well written and lightweight Comparable to other encoders that consume a lot of processing, ie they get to use 100% of the processors and almost gets to hang the machine. Getting between 64% to 81% is very good to use the machine to do other things. I do not know what you did, but it is very light to handle videos on Hi10p. Can I call this version of TX264-Lite ... HEHEHE. Thanks a lot.
18th February 2013, 19:37 | #244 | Link |
Life's clearer in 4K UHD
Out of interest...
Has there been any compatibility tests running TX264 with Windows 8 32-bit?
19th February 2013, 00:02 | #245 | Link |
@Ozok,
I don't know if it's a problem with TX264(0.9.4.3057), or with Wine and Ubuntu but I can't encode using 10bit, 8bit seems to work fine. Bug Report and Log below. Bug Report - http://www.mediafire.com/view/?ygs70w2nuzbs46n Tx264 Log - http://www.mediafire.com/view/?0xk5dsvca4zxeay Last edited by BK-201; 19th February 2013 at 13:10. |
19th February 2013, 00:34 | #246 | Link |
TEncoder, TX264, TAC
@SeeMoreDigital no I didn't try it with Windows 8. Any input on that is welcome.
@Barough my bad. I generally check all the tools included in the package before a release but this time I missed it. You can replace them manually, I did after your warning and they work without a problem. (mkvmerge and mkvextract in tools\mkv\ folder) @Marchand I don't have an explaination about this. |
26th February 2013, 01:54 | #248 | Link |
Getting a bit bored i decided to try out TX264. I like the clean and simple interface and the fact that it is not bloated by odd codec's etc :-) But i do have a question, which probabaly is stupid. Is TX264 supposed to work with vob files as input? I rip my dvd's to a single .vob file, but all encodes fail. As fair as i can tell something is wrong with the audio which can't be found:
Best regards Last edited by Guest; 26th February 2013 at 03:06. Reason: 5 |
26th February 2013, 11:21 | #249 | Link |
@BK-201 I don't understand why that happens.
@soehest, yes vob files should work. However, they sometimes have funny track ids for audio streams so TX264 has problem exracting them. I recently changed audio track id detecting method in TX264 and I seem to forget about the that issue about vob files. I'll return you when I find a solution. Edit: typo |
5th March 2013, 19:02 | #251 | Link |
I'm having problems with Win8 32-bit... For some reason when ever I try to close down TX264 I obtain an 'Error Window'.
Here the log:
7th March 2013, 00:45 | #252 | Link |
@SeeMoreDigital, TX264 is designed to work as a portable program, it keeps settings file in its folder. When you put it in ProgramFiles folder where programs are not allowed to write, it tries to write settings file to there and since it is not allowed, this causes an error. You can copy TX264 to an other location (like C:\tx264) where it can write to.
13th March 2013, 21:31 | #253 | Link |
Thanks ozok,
What a 'school-boy' error for me to make Now that I have TX264 running correctly I'm trying to create a 'Pre-defined' profile for TX264 which offers the same (or near enough) settings as my old AutoMKV 0.98 profile. However, I don't seem to be able to obtain the same looking output. My AutoMKV 0.98 profile looks like this: - Code:
<?xml version="1.0"?> <VideoProfile xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"> <Name>x264_QuickTime</Name> <EncodingMode>4</EncodingMode> <BitrateQuantizer>1000</BitrateQuantizer> <KeyframeInterval>250</KeyframeInterval> <NbBframes>3</NbBframes> <MinQuantizer>10</MinQuantizer> <MaxQuantizer>51</MaxQuantizer> <Turbo>false</Turbo> <MaxNumberOfPasses>3</MaxNumberOfPasses> <NoDCTDecimate>false</NoDCTDecimate> <PSNRCalculation>false</PSNRCalculation> <noFastPSkip>false</noFastPSkip> <NoiseReduction>0</NoiseReduction> <MixedRefs>false</MixedRefs> <X264Trellis>1</X264Trellis> <NbRefFrames>4</NbRefFrames> <AlphaDeblock>0</AlphaDeblock> <BetaDeblock>0</BetaDeblock> <SubPelRefinement>5</SubPelRefinement> <MaxQuantDelta>4</MaxQuantDelta> <TempQuantBlur>0</TempQuantBlur> <BframePredictionMode>3</BframePredictionMode> <VBVBufferSize>0</VBVBufferSize> <VBVMaxBitrate>25000</VBVMaxBitrate> <METype>umh</METype> <MERange>16</MERange> <MinGOPSize>25</MinGOPSize> <Profile>1</Profile> <Level>4.0</Level> <IPFactor>1.4</IPFactor> <PBFactor>1.3</PBFactor> <ChromaQPOffset>0</ChromaQPOffset> <VBVInitialBuffer>0.9</VBVInitialBuffer> <BitrateVariance>1.0</BitrateVariance> <QuantCompression>0.6</QuantCompression> <TempComplexityBlur>20</TempComplexityBlur> <TempQuanBlurCC>0.5</TempQuanBlurCC> <SCDSensitivity>40</SCDSensitivity> <BframeBias>0</BframeBias> <Deblock>true</Deblock> <Cabac>true</Cabac> <WeightedBPrediction>false</WeightedBPrediction> <AdaptiveBFrames>true</AdaptiveBFrames> <BFramePyramid>false</BFramePyramid> <ChromaME>true</ChromaME> <P8x8mv>true</P8x8mv> <B8x8mv>true</B8x8mv> <I4x4mv>true</I4x4mv> <I8x8mv>false</I8x8mv> <P4x4mv>true</P4x4mv> <AdaptiveDCT>false</AdaptiveDCT> <SSIMCalculation>false</SSIMCalculation> <Interlaced>false</Interlaced> <Width>false</Width> <Sar>false</Sar> <aud>false</aud> <nal-hrd>false</nal-hrd> <pulldown>0</pulldown> <aq-mode>false</aq-mode> <aq-strength>false</aq-strength> <psy-rd>false</psy-rd> <deadzone-inter>false</deadzone-inter> <deadzone-intra>false</deadzone-intra> <fpel-cmp>false</fpel-cmp> <me-prepass>false</me-prepass> <QuantizerMatrixType>0</QuantizerMatrixType> Cheers
14th April 2013, 20:18 | #254 | Link | |
Update:
26th April 2013, 15:35 | #257 | Link | |
Update:
faac, mkv, mp4, neroaacenc, x264 |
