3rd April 2011, 11:55 | #1201 | Link |
That looks like the same problem i had with LAV CUVID in 0.1, heh.
3rd April 2011, 12:04 | #1202 | Link |
could be also what is visually seen a slice rendering problem as most x264 streams here also in .m2ts don't Bork out and all have in common that they don't use slices or a combination of slices + mbaff
And as V0lt said that hillary Mpeg-2 Stream Freezes with Lav Splitter + any Decoder even LAV CUVID Works fine with MPC-HC Splitter, Haali, Arcsoft Btw that brings me on the question could you add to modular allow to disable libavformat parser in lavsplitter, would make testing easier then to allways register/unregister after the 1000 time you feed up
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 3rd April 2011 at 12:21. |
3rd April 2011, 14:23 | #1204 | Link |
Using Arcsoft video & audio I'm trying to play a VC-1 i & DTS-Hd Blu-ray (folder) when I open the m2ts file the video it's smooth BUT when I'm opening the index.bdmv the video is very choppy (same setting used as before in MPC-HC and LAVSplitter)
The same index.bdmv it's playing smooth with WMVideo Decoder DMO and Frame time correction ON or using internal splitter with any of the video decoders mentioned without any setting changed (except that for WMVideo Decoder DMO I'm using Frame time correction ON) P.S. I'm using your latest LAVSplitter (from today VS2010 SP1 & Win 7.1 SDK) and tested all settings in LAV and MPC-HC
Intel UHD Graphics 750; Win 10 22H2 |
3rd April 2011, 14:32 | #1206 | Link | |
EDIT again "I'm using latest LAVFSplitter-603e79a from today VS2010 SP1 & Win 7.1 SDK"
Intel UHD Graphics 750; Win 10 22H2 Last edited by Mercury_22; 3rd April 2011 at 14:39. |
3rd April 2011, 14:41 | #1207 | Link |
Ok. Then I guess you'll have to wait for Nev to answer that one. I'm guessing there's probably a reason he hasn't released a new version with that support yet.
3rd April 2011, 14:53 | #1208 | Link | ||
Edit: Or try with the latest version (7431d08) Quote:
In any case, i spent alot of time debugging seamless playback over the weekend, and it should be working perfectly now.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 3rd April 2011 at 14:58. |
3rd April 2011, 15:16 | #1209 | Link | |
3rd April 2011, 15:30 | #1210 | Link | |
3rd April 2011, 18:39 | #1211 | Link | |
@nevcairiel
I was asked to report: Quote:
3rd April 2011, 19:44 | #1212 | Link | |
Switching CoreAVC (2.5.1) to software mode or using another DXVA decoder solves the problem. Last edited by Ger; 3rd April 2011 at 20:00. Reason: Grammar |
3rd April 2011, 19:59 | #1213 | Link |
So a heavy major DXVA bug i wonder how Beta Testers could oversee that one as it makes it DXVA mode practically useless, except you watch only non sliced x264 encodes
PS: I wasn't involved in beta testing so please dont hurt me even if im in the Credits, and to make it clear i don't give you your money back either a wait it was free so
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 3rd April 2011 at 20:08. |
3rd April 2011, 20:54 | #1214 | Link | |
This seems to be one of those, a recording of a complete mux/transponder, not just a single channel. Normally LAV Splitter will play the first program/channel with these streams, but apparently not in this case. With the internal MPC-HC splitter you can switch between the HD and SD video tracks. With MediaInfo you can even see the name of the channels KNTV-HD and KNTV-SD, so we know it was probably ATSC recorded in the Bay Area, California. Another interesting thing about this sample is the closed captions. In VLC you can see the lyrics she's singing by enabling the CC subtitles. VLC can handle TeleText and CC, but can't switch between video tracks/programs either and only shows the SD video in this sample. |
3rd April 2011, 22:23 | #1215 | Link |
I have a little feature request (maybe itīs possible manual, I donīt know):
-Selection somewhere which formats should be registered. I do not want to use it for MPEG-TS, because it cannot handle multiple programs. But I want to use it for WMV, because it can seek in incomplete files (I donīt know any other DirectShow splitter able to that), is there any way to change this manually? |
4th April 2011, 02:50 | #1216 | Link |
Alright, I'm trying to get a build env set up finally. Got MSVC 2010 SP1 installed, got GIT integrated, and pulled the source from GIT. When I try to use the GIT link in the readme for ffmpeg I get an error 400. So I pulled it from the main GIT repository. Fine. Libbluray. I don't have an MSVC 2010 solution for it. When I open the LAVSplitter solution that's the error I get. I'm clearly missing something here. Help? I'd love to get this building so maybe I can help out once in a while. Thanks!
EDIT: This is what I get when I try to get from the ffmpeg git link in the readme: Code:
c:\Program Files (x86)\Git\bin\git.exe clone -v --progress --branch refs "http://git.1f0.de/gitweb?p=ffmpeg.git;a=summary" "C:/Users/Samuri/Documents/Visual Studio 2010/Projects/LAVFSplitter/ffmpeg" error: The requested URL returned error: 400 while accessing http://git.1f0.de/gitweb?p=ffmpeg.git;a=summary/info/refs fatal: HTTP request failed Cloning into C:/Users/Samuri/Documents/Visual Studio 2010/Projects/LAVFSplitter/ffmpeg... Done
HTPC: Windows 11, AMD 5900X, RTX 3080, Pioneer Elite VSX-LX303, LG G2 77" OLED Last edited by SamuriHL; 4th April 2011 at 03:08. |
4th April 2011, 03:46 | #1217 | Link |
Tried to encode a fake-interlaced VC-1 clip earlier and the LAV splitter spat out "Interlaced frames/fields support is not implemented" in the command prompt, even though it seemed to encode just fine. Is the part of libavfilter that issued the warning even used? I figured it'd be only for decoding, not for parsing the VC-1 header. Seems strange to show that warning yet still work flawlessly.
4th April 2011, 06:34 | #1218 | Link | |
I use tortoiseGit, but it should work for you, this is the link i sur for ffmpeg : git://git.1f0.de/ffmpeg.git Libbluray : git://git.1f0.de/libbluray.git Lavf : git://github.com/Nevcairiel/LAVFSplitter Edit : LAst version works like a charm for BD
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355. Last edited by Sebastiii; 4th April 2011 at 06:43. |
4th April 2011, 06:51 | #1219 | Link | ||
lav splitter: git://git.1f0.de/lavfsplitter.git (or from GitHub, git://github.com/Nevcairiel/LAVFSplitter.git) ffmpeg: git://git.1f0.de/ffmpeg.git libbluray: git://git.1f0.de/libbluray.git http cloning is not supported from my git hosting page, need to use the git protocol (or ssh if you have access, which only i do ) As an alternative, just checkout LAV Splitter, and then run "git submodule update --init", which will download ffmpeg and libbluray from my repositories in the proper location. It can also be used in the future to keep those two modules updated, when/if i update them. Quote:
This is on my list of things to do. Sadly there is no easy way to do it manually.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 4th April 2011 at 07:04. |
4th April 2011, 14:43 | #1220 | Link |
Thanks guys! I finally got the source downloaded and ffmpeg built with MinGW. (Man that's a chore!) I forgot to install the Win 7.1 SDK (uh, oops) so I've yet to be able to build the MSVC projects, but, I'm making good progress. Hopefully I'll have this built soon so I can start taking a look at it.
EDIT: Or not. My ffmpeg build didn't seem to succeed as well as I thought. I'm missing 'avformat-52.lib'. Guess I have to go work through that again. sigh.
HTPC: Windows 11, AMD 5900X, RTX 3080, Pioneer Elite VSX-LX303, LG G2 77" OLED Last edited by SamuriHL; 4th April 2011 at 14:50. |
