2nd October 2018, 14:52 | #23042 | Link | |
2nd October 2018, 15:56 | #23043 | Link |
@mclingo:
It's set to Automatic (Native) @sneaker_ger: it states "avcodec". Codec is as you describe. My other very lowly computer (core2Quad) is very happy to play it smoothly via GT 1030, drivers are the latest Nvidia 411.70, though not sure about the LAV version, can't get to that comp right now) |
2nd October 2018, 16:01 | #23044 | Link |
thats unusual then, unless you've done what i've done once or twice, installed LAV and a player and then not set LAVs as external filters in the player so you are essentially still using the internal player LAV settings.
LG OLED EF950-YAM RX-V685-RYZEN 3600 - 16GBRAM - WIN10 RX 5700 - https://www.videohelp.com/software/madVR/old-versions |
3rd October 2018, 13:13 | #23045 | Link |
Lo and behold, I just reverted LAV filters to 0.71 and now it's as it should be (DXVA2 and DXVA11 accel taking place for all 4K content, the problem was not just HFR as I first thought)...so there is something wrong with 0.72, at least on my system.
3rd October 2018, 17:37 | #23046 | Link |
Nothing in hardware decoding really changed since 0.71. It makes no sense to me how it would work on one system and not another, and on one resolution and not another. Smells like something on your system to me.
4th October 2018, 10:22 | #23049 | Link | |
However the LAV version that comes internal with MPC-HC does work albeit it doesn't support D3D11 option yet, but with DXVA2 works, as does LAV 0.71. Sample files can be any 4K content, but specifically B.l.y L.nn which is HFR and is obviously too much for the CPU decoding (AMD FX-8320 slightly o.c. to 3.8 Ghz) even with EVR (50-56 fps wen it needs to be 60). |
4th October 2018, 14:22 | #23051 | Link | |
https://github.com/clsid2/LAVFilters/commits/master |
5th October 2018, 09:27 | #23053 | Link | |
5th October 2018, 12:43 | #23054 | Link |
LAV Filters 0.73
LAV Splitter - Changed: Export the description of cover art and attachments for use by players - Fixed: Properly marked the packet allocator as providing read-only packets, to avoid crashes with in-place transform filters LAV Video - NEW: Support for AV1 decoding using libaom - Changed: Enabled VP9 hardware acceleration by default - Fixed: The aspect ratio of certain WMV/VC-1 files was not being properly respected in the WMV9 MFT decoder AV1 Support This is the first officialy LAV Filters release with AV1 support. LAV Splitter can read compliant files, and LAV Video can decode AV1 using the libaom decoder. The alternative dav1d decoder is still under active development, and at this time is not quite ready for widespread use yet. It'll be included in the future, once the dust settles. Otherwise, not much changed. General house keeping and some small corrections. New FFmpeg version of course. As always, please report issues, specifically regressions, in as much detail as possible with a sample file if applicable. Have fun!
5th October 2018, 12:56 | #23055 | Link |
bit a noob question this as its never come up as i've only recently started updating the LAV filters in the KODI DS build, to update the LAV filters you normally just copy the filters from: C:\Program Files (x86)\LAV Filters\x86 to \KODI DS\system\players\dsplayer\LAVFilters - or whereever you have it instsalled.
This time they didnt overwrite as the DLL names have changed, do these always change with major build changes nevcairiel?, I assume I'll just delete the old filters and copy the new ones in there. If you're not sure i'll ask on the DS forum, Cheers for the new version !
5th October 2018, 12:57 | #23056 | Link | |
Are you going to follow their new releases too ? They are probably doing great steps regarding SMT, ASM and SIMD optimizations not in every new release of course, but certainly they haven't stopped development. Also we must have a way to benchmark those two different decoders for AV1. It would be extremely useful to add both decoders in LAV in order to test which is faster as they release new versions.
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all |
5th October 2018, 13:07 | #23057 | Link |
LAV has no real possibility to choose between two decoders based on FFmpeg. If you want to benchmark them, I suggest you use FFmpeg itself - although the dav1d decoder module for FFmpeg has not landed yet, partially because dav1d keeps changing (its just not ready yet).
I'll include whichever ends up better, but just from history I have far more trust in the people working on dav1d to provide the fastest AV1 software decoder. The FFmpeg vp9 decoder, from the same developer, runs leaps around libvpx.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 5th October 2018 at 13:09. |
5th October 2018, 13:14 | #23058 | Link | |
The names change when FFmpeg updates to a newer major version. The old ones should just be deleted.
5th October 2018, 13:16 | #23059 | Link |
I probably had some really old ones in there then I hadnt removed, thanks for the info, I just tested KODI DS and it works fine.
Thanks again for your excellent work.
