Old 16th July 2019, 22:29   #641  |  Link
gonca
Originally Posted by videoh View Post
Look for the MakeAnyVideoBetter() filter.
When are you releasing the MakeAnyVideoBetterNV filter
I could use it
gonca is offline
Old 16th July 2019, 22:36   #642  |  Link
gonca
Originally Posted by Santojob View Post
Thank you very much for your advice ChaosKing that I will definitely try. I do not have much knowledge and time to try other things.
videoh Thank you very much for nothing.
Before you thank someone for nothing look carefully at your question.
You want "a filter" that improves the "final video quality" without increasing size or encode time.
Exactly what is it about your video that requires improvement
Denoising doesn't work on all videos.
In fact there is NO ONE SIZE FITS ALL filters.
Tell us what the issue is and then we can attempt to help you
gonca is offline
Old 16th July 2019, 23:30   #643  |  Link
Santojob
Do you perhaps mean setting(s)?
gonca no doubt you are right in your comments. My English is not good and the translator sometimes does not reflect exactly what I want to say. I usually compress some movie that I like and then store it in a backup HD. I have been compressing lately with Handbrake, but I see that I get a similar quality with StaxRip, but with a very important time reduction in the coding process (currently I use x265 + Nvenc + 10 bit) that I think has very good results.
Currently I only have the encoder (x265-Nvidia) configured in StaxRip and I only use the CROP filter. This configuration compresses fast (I use a bitrate of 4500 VBR).
My question is that filters could improve the final quality of the video, with the configuration mentioned above, without the coding time increasing very much .....
That was the question friends ...
Santojob is offline
Old 16th July 2019, 23:49   #644  |  Link
videoh
Useful n00b
It seems you miss the point entirely. Never mind, sorry for the snark and good luck with your projects.
"very much" is also highly nebulous.
videoh is offline
Old 16th July 2019, 23:57   #645  |  Link
frenchfries
A couple of things.
1. Technically you should be referring to the NVENC implementation of HEVC as H.265, HEVC or MPEG-H Part 2 rather than X265 as that's a very different project and leads to potential confusion in your post.
2. To address your question, rather than filters perhaps you can change some settings in NVENC to have the same final bitrate but a quality improvement such as setting the CRF to 17 or 18, I have no idea what you use, which will make your files larger and then adjust B frames and reference frames up a bit to bring the file back down to the same bitrate hopefully.
I find that quicksync doesn't slow down a lot, if at all, even with 6 B frames and 9 reference frames but it works wonders on some footage, particularly animation.
I haven't really played with NVENC but it may also not suffer from tweaked settings.
Quicksync with the following settings seems to do wonders for me
--codec hevc --quality best --profile main10 --la-quality slow --la-window-size 15 --bframes 6 --ref 9 --b-pyramid --fallback-rc --icq 17
Quality is better than x265 slow or slower, always results in a smaller file size and encodes 4k material at ~12-14fps on my laptop with UHD620 graphics.
EDIT - I just reread your post and you use VBR 4500. I would highly recommend going to some form of constant rate factor rather than VBR.
frenchfries is offline
Old 17th July 2019, 01:23   #646  |  Link
gonca
Try this command line and adjust as necessary
"C:\Program Files (Portable)\NVEncC\NVEncC64.exe" --vbrhq 38400 --codec h265 --preset quality --profile main10 --level 5.1 --output-depth 10 --ref 5 --gop-len 24 --lookahead 32 --qp-init 1 --max-bitrate 38400 --vbr-quality 25 --aq --cuda-schedule auto --mv-precision q-pel --cabac
Note that different NVidia cards have different capabilities
If you a RTX 20xx type you can use b frames
gonca is offline
Old 17th July 2019, 04:34   #647  |  Link
maupassant
Problem using mClean with VS Filters (StaxRip 2.0.2.4)
Script Error :
Python Exception: name 'hnwvsfunc' is not defined
Traceback (most recent call last):
File "src\cython\vapoursynth.pyx", line 1927, in vapoursynth.vpy_evaluateScript
maupassant is offline
Old 18th July 2019, 00:32   #648  |  Link
Santojob
Thanks frenchfries for your advice on VBR and gonca for its command line. The tests I have done have been very good quality. I have had problems compressing m2ts files coming from Bluray with audio & video sync, and I do not know how to solve it. I'm still looking for information on how to fix it ...
Santojob is offline
Old 19th July 2019, 05:51   #649  |  Link
frenchfries
Sync info is embedded within the container and staxrip and mediainfo extract it out for you.
I'm not sure what you're doing but I'd advise you to do a very standard run, ie. with no customistation and see if the output is right. Try a software only transcode and see if it syncs properly. If it does the problem is porbably to do with how you've configured NVENC.
Old 19th July 2019, 15:08   #650  |  Link
Santojob
As it seems, the problem was in the structure of the Bluray that tried to compress (Star Wars I). The process I have done to correct the delay has been to read the structure of the bluray with the GUI MKVToolNix and after selecting the tracks that I have generated an MKV, with this MKV has worked well the compression and synchronization of video and audio.
Santojob is offline
Old 20th July 2019, 01:41   #651  |  Link
Zetti
NVEncC v4.43 is released.
Zetti is offline
Old 20th July 2019, 07:46   #652  |  Link
ChaosKing
Script Error :
hnwvsfunc is dead. Should be replaced with https://github.com/Helenerineium/G41Fun
ChaosKing is offline
Old 23rd July 2019, 22:37   #653  |  Link
Andy
I'm doing tests with StaxRip, compressing videos in x265 + nVENC, the quality is good and especially the speed very fast. Could you recommend the implementation of a filter that improves the final quality of the x265 video and does not consume or reduce compression times too much?
If you want a good picture, you have to use cpu encoding, not gpu. It has a lot of original details that the image made by graphics does not have. It rather smooths it.
Playing with the psychovisual capabilities of the codec (psy-rd, psy-rdog) often helps. If the source has grain, so it is longer ....
But I convert UHD over NVenc with time reasons, if it's not grain, I add Finesharp (Light) and sometimes MSharpen (50-60%) and the result is excellent.
Andy is offline
Old 24th July 2019, 07:45   #654  |  Link
Atlantis
Question. Just noticed this.
When I encode an AVC 8bit video with x265 10bit, the result is a little brighter and yellower than the original colors.
If I encode the same AVC 8bit video with x265 8bit, the colors look the same.
So how can I encode an AVC 8bit video into x265 10bit and keep the original colors?
I capture images of the same frames and that's how I see that encoding an 8bit source into 10bit changes the colors slightly.
Atlantis is offline
Old 24th July 2019, 10:16   #655  |  Link
sneaker_ger
Is the video using SD resolution? Those often use BT.601 colors. Some players may assume BT.709 colors with 10 bit files. So it's more of a problem of the player or you not setting the proper color flags (if the player can understand and obey those - most do not).
sneaker_ger is offline
Old 24th July 2019, 10:49   #656  |  Link
Atlantis
They are all standard blurays. And all HD.
original video - 8bit encoding - 10bit encoding
You see the image on the far right (10bit) has different colors. When you have the full image and switch between them, the difference is more visible.
Atlantis is offline
Old 24th July 2019, 10:53   #657  |  Link
Atlantis
You can do it yourself, it is very easy and very fast. Take an 8bit AVC short clip and use Staxrip to do 2 encodings. x265 8bit and x265 10bit. Take 3 screenshots and compare them.
In the past I was inclined to do all my encoding in 10bits because of better compression and less banding, but the colors are not accurate and not the original colors.
Atlantis is offline
Old 24th July 2019, 10:58   #658  |  Link
Atlantis
Here are the file info
original video
Video
Format : AVC
Format profile : High@L4.1
Format settings : CABAC / 5 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 18 s 561 ms
Bit rate : 6 326 kb/s
Width : 1 920 pixels
Height : 808 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 (23976/1000) FPS
Original frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.170
Stream size : 14.0 MiB (100%)
Language : English
Default : Yes
Forced : No
8bit encoding
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main@L4@Main
Codec ID : V_MPEGH/ISO/HEVC
Duration : 18 s 560 ms
Bit rate : 662 kb/s
Height : 808 pixels
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.018
Stream size : 1.46 MiB (99%)
Writing library : x265 3.1_RC1+3-3bdf06e3c628:[Windows][MSVC 1921][64 bit] 8bit+10bit+12bit
Encoding settings : cpuid=1111039 / frame-threads=3 / numa-pools=8 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x808 / interlace=0 / total-frames=445 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=3 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=23 / keyint=250 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=20 / lookahead-slices=5 / scenecut=40 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=3 / limit-refs=1 / no-limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=3 / early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=22.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=2 / chromaloc=0 / display-window=0cll=0,0 / min-luma=0 / max-luma=255 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr / no-hdr-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=0 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00
Default : Yes
Forced : No
10bit encoding
Video
Format : HEVC
Format profile : Main 10@L4@Main
Bit rate : 649 kb/s
Height : 808 pixels
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.017
Stream size : 1.44 MiB (99%)
Writing library : x265 3.1_RC1+3-3bdf06e3c628:[Windows][MSVC 1921][64 bit] 10bit
Encoding settings : cpuid=1111039 / frame-threads=3 / numa-pools=8 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x808 / interlace=0 / total-frames=445 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=3 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=23 / keyint=250 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=20 / lookahead-slices=5 / scenecut=40 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=3 / limit-refs=1 / no-limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=3 / early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=22.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=2 / chromaloc=0 / display-window=0cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr / no-hdr-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=0 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00
Default : Yes
Forced : No
Atlantis is offline
Old 24th July 2019, 12:07   #659  |  Link
sneaker_ger
I doubt I can reproduce it that way because I believe it's a problem of your player or the way you take screenshots. If you upload both your 8 bit as well as your 10 bit encode I can take screenshots on my PC to confirm this.
Only way StaxRip could be at fault would be if it would do any color(space) conversion. That is usually not the case with YUV source and output (the StaxRip log should confirm this).
Old 24th July 2019, 12:53   #660  |  Link
Atlantis
I'm not saying it is staxrip, it could be x265. I'm going to do several more tests to find more information and report. I'm going to try taking screenshots with different player, going to try using MeGUI to encode and also try using x265 directly.
Atlantis is offline
aac, hdr, hevc, nvenc, staxrip, x264, x265
